Cisco 1000BASE-SX SFP Transceiver
Quicklinx: 8GNSWS00 Mfr#: GLC-SX-MMD=
Type: Modules
More than 50 In Stock
£208.92 ex VAT
£250.70 inc VAT
The SFP transceiver module is a hot-pluggable I/O device that plugs into module sockets. The transceiver connects the electrical circuitry of the module with the optical or copper network.
  • Enhanced connectivity
    The Cisco SFP (mini-GBIC) transceiver module offers wired connectivity with a high-speed data transfer rate of 1 Gbps, ensuring efficient network performance and fast data transmission.
  • Versatile compatibility
    Designed for a wide range of Cisco devices, this module supports Ethernet 1000Base-SX cabling type, making it a versatile choice for upgrading or expanding your network infrastructure.
  • Reliable performance
    With support for Digital Optical Monitoring (DOM) and hot swap module replacement, this transceiver module ensures reliable performance and easy maintenance, minimizing downtime.
  • Extended operational range
    Capable of operating within a wide temperature range from -5°C to 85°C, this module ensures consistent performance under various environmental conditions.
  • Safe and compliant
    Adhering to IEC 60825-1 and Laser Class 1 standards, the module meets strict safety and quality requirements, ensuring a secure operation within your network.
Cisco - SFP (mini-GBIC) transceiver module - 1GbE
SFP (mini-GBIC) transceiver module - LC/PC multi-mode
Plug-in module
Cabling Type
1000Base-SX
Data Transfer Rate
1 Gbps
Optical Wave Length
850 nm
1GbE
Max Transfer Distance
1 km
1.34 cm x 5.65 cm x 0.85 cm
75 g
1-year warranty
Catalyst ESS9300 Embedded Series
Plug-in module
Wired
Cabling Type
1000Base-SX
1GbE
Data Transfer Rate
1 Gbps
Optical Wave Length
850 nm
1 km
Hot swap module replacement, Digital Optical Monitoring (DOM) support
IEEE 802.3z, IEEE 802.3ah
1 x Ethernet 1000Base-SX - LC/PC multi-mode x 2
Compatible Slots
1 x SFP (mini-GBIC)
Laser Class 1, IEC 60825-1
1.34 cm
5.65 cm
0.85 cm
75 g
Limited warranty - 1 year
-5 °C
85 °C
Cisco Catalyst ESS9300 Embedded Series
Type: Modules
Brand: Cisco
