Cisco 10/100 VPN 8-Port Router
Quicklinx: 5C7QWS00 Mfr#: RV082-UK
The Cisco 10/100 8-Port VPN Router is an advanced Internet-sharing network solution for your small business needs. Like any router, it lets multiple computers in your office share an Internet connection. But the unique dual Internet ports on the 10/100 8-Port VPN Router let you connect a second Internet line as a backup to insure that you're never disconnected. Or, use both Internet ports at the same time, and let the router balance your office's requirements between them for maximum bandwidth efficiency.
The 10/100 8-Port VPN Router also features a built-in 8-port full-duplex 10/100 Ethernet switch to connect eight PCs directly, or you can connect more hubs and switches to create as big a network as you need.
The Virtual Private Network (VPN) capability creates encrypted "tunnels" through the Internet, allowing up to 50 remote offices or traveling users to securely connect into your office network from off-site. Users connecting through a VPN tunnel are attached to your company's network - with secure access to files, e-mail, and your intranet - just as if they were in the building. You can also use the VPN capability to allow users on your small office network to securely connect out to a corporate network.
The 10/100 8-Port VPN Router can serve as a DHCP Server, and has a powerful SPI firewall to protect your PCs against intruders and most known Internet attacks. It can be configured to filter internal users' access to the Internet, and has IP address filtering so you can specify exactly who has access to your network. Configuration is a snap with the web browser-based configuration utility.
As the heart of your small office network, the connection-redundant Linksys 10/100 8-Port VPN Router gives you the connection reliability your business needs.
Cisco Small Business RV082 - router - desktop
Router - 8-port switch (integrated)
Enclosure Type
Desktop
WAN Ports Qty
2
Ethernet, Fast Ethernet
Performance
NAT throughput: 200 Mbps , VPN throughput (IPSec): 97 Mbps
IPSec VPN tunnels: 100 , PPTP VPN tunnels: 5 , VPN tunnels (remote access): 50
Network / Transport Protocol
PPTP, L2TP, IPSec, PPPoE, DHCP, Bonjour, DDNS
Routing Protocol
RIP-1, RIP-2, static IP routing
Remote Management Protocol
SNMP 1, SNMP 2c, HTTP, HTTPS
Firewall protection, switching, DMZ port, routing, NAT support, VPN support, PAT support, load balancing, VLAN support, SPI, content filtering, QoS, IPv4 support
IEEE 802.3, IEEE 802.3u, UPnP
AC 120/230 V (50 - 60 Hz)
27.9 cm x 24.1 cm x 4.45 cm
1.5 kg
United Kingdom
Enclosure Type
Desktop
Wired
Performance
Routing Protocol
Encryption Algorithm
DES, Triple DES, MD5, AES, SHA-1
Authentication Method
RADIUS
IEEE 802.3, IEEE 802.3u, UPnP, FCC Class B certified
Status Indicators
System, WAN, LAN, DMZ, DMZ/Internet, diagnostic
LAN: 8 x 10Base-T/100Base-TX - RJ-45 , WAN: 1 x 10Base-T/100Base-TX - RJ-45 , WAN / DMZ: 1 x 10Base-T/100Base-TX - RJ-45
Internal power supply
1 x power cable
United Kingdom
OS Provided
Linux
Software Included
Cisco QuickVPN Client
27.9 cm
24.1 cm
4.45 cm
1.5 kg
Limited warranty - lifetime
10 - 85%
5C7Q C2G 5m Cat6 550 MHz Snagless Patch Cable - Grey In Stock £8.56
5C7Q C2G 10m Cat6 550 MHz Snagless Patch Cable - Black In Stock £10.73
