Chief Professional Mounting PF1UB Large Flat Panel Floor AV Stand
Quicklinx: BKLHWS00 Mfr#: PF1UB
£625.56 ex VAT
£750.67 inc VAT
The all PF1-U Black Flat Panel Display Floor Stand features a lightweight, collapsible design to meet a wide range of applications. Innovative new features include a telescoping height-adjustment mechanism, integrated cable management, and a modular design that allows for fast disassembly.
  • Adjustable design
    Featuring a telescopic design with Centris Technology, this stand allows for easy pitch adjustments, ensuring optimal viewing angles for any display size within 42-86 inches.
  • Durable construction
    Crafted from high-quality aluminum, the stand offers a sturdy and reliable solution for floor-standing display setups, supporting flat panels up to 74.7 kg.
  • Versatile placement
    Designed for flexibility, this floor-standing mount can be placed in various locations, providing a stable and secure platform for large flat panel displays.
Chief Large Flat Panel Floor Stand Display Mount - For Displays 42-86" - Black stand - telescopic - for flat panel - black
Stand (telescopic) - floor-standing
72.6 cm x 78.4 cm
Adjustable Height
121.9-213.4 cm
Adjustments
Pitch
Recommended Use
Flat panel
Max Load Weight
74.7 kg
Material
Aluminium
72.6 cm
78.4 cm
Adjustable Height
121.9-213.4 cm
Material
Aluminium
AV Furniture
Stand
Design
Telescopic
Recommended Use
Flat panel
Placing / Mounting
Floor-standing
Adjustments
Pitch
Max Load Weight
74.7 kg
Adjustable height, Centris Technology
