Chief Professional Mounting Fusion 32"-55" Universal Micro Adjustable Wall Mount
Quicklinx: DM8MWS00 Mfr#: MTM1U
Hurry, only 3 left in stock!
£161.73 ex VAT
£194.07 inc VAT
Chief upgraded fixed wall mounts based on installer feedback and direct observations of installers in the field. Many features join Fusion favorites like Centerless shift, Centris tilt and ClickConnect latching. The benefits included added stability, faster install, improved lateral shift, easier cable management and enhanced security. Installer-inspired Fusion tilt mount solves top flat panel installation problems, offering flexible adjustments for large displays with a low-profile display mounting solution.
  • Effortless adjustment
    With features like Centris tilt and Controlzone Leveling, adjusting your TV to the perfect viewing angle has never been easier. The Centris tilt mechanism allows for smooth tilt adjustments from -12° to 2°, ensuring an optimal viewing experience, while Controlzone Leveling offers precision leveling for a perfectly positioned display.
  • Sleek design
    The Fusion Medium Tilt TV Wall Mount boasts a low-profile design that ensures your TV blends seamlessly with your interior decor. Integrated cable management keeps cables neatly organized, contributing to a clean and uncluttered look.
  • Secure installation
    Thanks to the ClickConnect Latching feature, your flat panel is securely attached to the wall mount, providing peace of mind. The inclusion of 2 interface brackets further enhances stability, supporting displays up to 57 kg in weight.
Chief Fusion Medium Tilt TV Wall Mount - For Displays 32-65" - Black mounting kit - for flat panel - black
Mounting kit - wall-mountable
Mounting Components
Tilt wall mount, 2 interface brackets
65.4 cm x 5.1 cm x 43.2 cm
Tilt
-12° to 2°
Recommended Use
Flat panel
Recommended Display Size
26"-47"
VESA Mounting Interface
100 x 100 mm
Max Mounting Pattern Size
600 x 400 mm
Max Load Weight
57 kg
10 years warranty
65.4 cm
5.1 cm
43.2 cm
AV Furniture
Mounting kit
Mounting Components
Recommended Use
Flat panel
Placing / Mounting
Wall-mountable
100 x 100 mm
600 x 400 mm
Cable Management
26"-47"
Tilt
-12° to 2°
Max Load Weight
57 kg
Landscape function, low profile, Controlzone Leveling, Centreless Shift, ClickConnect Latching, Centris tilt
Limited warranty - 10 years
Brand: Chief Professional Mounting
