The STRAIT keyboard is designed to perfection. The premium keyboard from Cherry distinguishes itself with its pure elegance and impressive visual appearance. Its chrome finish, ultra-flat design and high-quality workmanship make it unique and truly eye-catching.
Effortless compatibility
Designed to seamlessly integrate with PC systems, ensuring a Plug-and-Play experience that eliminates the hassle of software installation. -
Enhanced productivity
Features 5 strategically placed buttons to enhance user productivity, allowing for easy navigation and functionality without the need for additional hardware. -
Reliable connectivity
Utilizes a wired connection through USB interface, providing a stable and reliable link between the keyboard and the PC without the worries of battery life or wireless interference.
- CHERRY STRAIT Corded - keyboard - UK - black
- Keyboard
- Interface
- USB
- Connectivity Technology
- Wired
- Localization and Layout
- UK
- Keys Qty
- 109
- Hot Keys Qty
- 5
- Hot Keys Function
- Multimedia, volume
- Splash water resistant, illuminated keys, low noise keys
- Black
- 44.1 cm x 16.1 cm x 1.45 cm
- 724 g
- 5-year warranty
- Keyboard
- Interface
- USB
Input Device
- Keys Qty
- 109
- Hot Keys Qty
- 5
- Hot Keys Function
- UK
- Region
- United Kingdom
- 44.1 cm
- 16.1 cm
- 1.45 cm
- 724 g
- Black
- Cables Included
- 1 x USB cable - 1.8 m
- Plug and Play, C-Tick, FCC
- Limited warranty - 5 years
- 0 °C
- 50 °C
