Cherry Slimline 83 Key USB/PS2 Keyboard Beige
Quicklinx: 4308WS00 Mfr#: G84-4100LCAGB-0
Recommended Use: Office
Type: Keyboard
Wired / Wireless: Wired
Colour: Beige
Compatibility: PC
Hurry, only 3 left in stock!
£58.82 ex VAT
£70.58 inc VAT
When you don't have much space and need to keep weight down as well, you can't do better than this ultra-low-profile compact keyboard. Useful for applications in, e.g. banking, medical facilities or for portable systems. Equally suitable for 19 inch applications. This keyboard is ideal for Slim Line PCs and notebooks can be enhanced with the G84-4700 numerical block.
  • Efficient connectivity
    The CHERRY G84-4100 Compact Keyboard offers versatile connectivity options with both USB and PS/2 interfaces, ensuring compatibility with a wide range of devices and systems. This feature allows for easy installation and use, regardless of the user's preferred connection method.
  • Optimal operating range
    Designed to perform in a variety of environments, the keyboard operates efficiently within a temperature range of 0°C to 50°C. This wide operating range ensures reliability and performance stability in both cool and warm conditions, making it suitable for use in diverse settings.
CHERRY G84-4100 Compact Keyboard - keyboard - QWERTY - UK Input Device
Keyboard
USB
Wired
Localization and Layout
QWERTY UK
Keys Qty
86
28.2 cm x 13.2 cm x 2.7 cm
0.5 kg
Microsoft Certification
Works with Windows Vista
3-year warranty
Keyboard
USB
Keys Qty
86
QWERTY UK
Region
United Kingdom
Keyboard Technology
Mechanical
28.2 cm
13.2 cm
2.7 cm
0.5 kg
1 x keyboard - generic - 6 pin mini-DIN (PS/2 style) , 1 x USB - 4 pin USB Type A
1 x keyboard cable - 1.7 m , 1 x keyboard adapter
FCC Class B certified, EN55022
MTBF
170,000 hours
Software and devices that carry the Works with Windows Vista logo have been tested for baseline compatibility with PC's running.
Limited warranty - 2 years , Extended warranty - 1 year
50 °C
Type: Keyboard
Colour: Beige
Compatibility: PC
Brand: Cherry
