Cherry MW 3000 2.4GHz Wireless Mouse with Nano USB Receiver
Quicklinx: 8P35WS00 Mfr#: JW-T0100
Type: Mouse
Wired / Wireless: Wireless
Colour: Black
Compatibility: PC
Hurry, only 3 left in stock!
£28.81 ex VAT
£34.57 inc VAT
The CHERRY MW 3000 is cutting-edge CHERRY technology in an ergonomic, modern design. It is an attractive, practical and high-quality mouse from CHERRY.
  • Ergonomic design
    Designed specifically for right-handed users, this mouse offers an ergonomic shape that fits comfortably in your hand, reducing fatigue during long periods of use. The inclusion of rubber side grips ensures a firm hold, enhancing precision and control.
  • High precision tracking
    With its infrared movement detection technology and a switchable resolution of up to 1750 DPI, users can enjoy high precision tracking. The real-time sensitivity switching between 1000 and 1750 DPI allows for seamless adjustment to different tasks' demands.
  • Convenient connectivity
    The CHERRY MW 3000 mouse offers hassle-free wireless connectivity via a 2.4 GHz interface, ensuring a reliable connection without the clutter of cables. The included USB wireless receiver facilitates easy Plug-and-Play setup.
  • Effortless control
    Featuring a scrolling wheel and an on/off power switch, this mouse is designed for ease of use. The scrolling wheel allows for smooth navigation through documents and web pages, while the power switch helps conserve battery life when not in use.
CHERRY MW 3000 - mouse - 2.4 GHz - black
Mouse
Wireless - 2.4 GHz
Orientation
Right-handed
6.8 cm x 10.6 cm x 3.9 cm
126 g
Wireless Receiver
Movement Detection Technology
Infrared
Buttons Qty
5
Movement Resolution
1750 dpi
Performance
Realtime sensitivity switching 1000/1750 dpi
Scrolling wheel, rubber side grips, switchable resolution, on/off power switch
2 x AAA type
Microsoft Certification
Compatible with Windows 7
3-year warranty
Mouse
Wireless Receiver
Orientation
Right-handed
6.8 cm
10.6 cm
3.9 cm
126 g
Input Device
Wireless
2.4 GHz
Max Operating Distance
Up to 5 m
Infrared
Buttons Qty
5
Movement Resolution
1750 dpi
Performance
1 x USB - 4 pin USB Type A
Plug and Play, C-Tick, FCC, cTUVus
AAA type
Installed Qty
2
Limited warranty - 2 years ¦ Extended warranty - 1 year
Type: Mouse
Colour: Black
Compatibility: PC
Brand: Cherry
