The CHERRY MW 3000 is cutting-edge CHERRY technology in an ergonomic, modern design. It is an attractive, practical and high-quality mouse from CHERRY.
Ergonomic design
Designed specifically for right-handed users, this mouse offers an ergonomic shape that fits comfortably in your hand, reducing fatigue during long periods of use. The inclusion of rubber side grips ensures a firm hold, enhancing precision and control. -
High precision tracking
With its infrared movement detection technology and a switchable resolution of up to 1750 DPI, users can enjoy high precision tracking. The real-time sensitivity switching between 1000 and 1750 DPI allows for seamless adjustment to different tasks' demands. -
Convenient connectivity
The CHERRY MW 3000 mouse offers hassle-free wireless connectivity via a 2.4 GHz interface, ensuring a reliable connection without the clutter of cables. The included USB wireless receiver facilitates easy Plug-and-Play setup. -
Effortless control
Featuring a scrolling wheel and an on/off power switch, this mouse is designed for ease of use. The scrolling wheel allows for smooth navigation through documents and web pages, while the power switch helps conserve battery life when not in use.
- CHERRY MW 3000 - mouse - 2.4 GHz - black
- Mouse
- Connectivity Technology
- Wireless - 2.4 GHz
- Black
- Orientation
- Right-handed
- 6.8 cm x 10.6 cm x 3.9 cm
- 126 g
- Wireless Receiver
- USB wireless receiver
- Movement Detection Technology
- Infrared
- Buttons Qty
- 5
- Movement Resolution
- 1750 dpi
- Performance
- Realtime sensitivity switching 1000/1750 dpi
- Scrolling wheel, rubber side grips, switchable resolution, on/off power switch
- Battery
- 2 x AAA type
- Microsoft Certification
- Compatible with Windows 7
- 3-year warranty
- Mouse
- Wireless Receiver
- Orientation
- Right-handed
- 6.8 cm
- 10.6 cm
- 3.9 cm
- 126 g
- Black
Input Device
- Wireless
- Interface
- 2.4 GHz
- Max Operating Distance
- Up to 5 m
- Infrared
- Buttons Qty
- 5
- 1750 dpi
- Performance
- 1 x USB - 4 pin USB Type A
- Plug and Play, C-Tick, FCC, cTUVus
- AAA type
- Installed Qty
- 2
- Limited warranty - 2 years ¦ Extended warranty - 1 year
- 0 °C
- 40 °C
