Cherry Gentix Optical Mouse Mac/PC Grey/White
Quicklinx: BYKBWS00 Mfr#: JM-0300-0
Type: Mouse
Wired / Wireless: Wired
Colour: Grey, White
Compatibility: Mac, PC
35 In Stock
£8.95 ex VAT
£10.74 inc VAT
Modern design, accurate scroll wheel action and precise mouse key pressure points make this product unique in its price class. The solid rubber sides make the mouse comfortable to use and ensure smooth, accurate cursor control even in hectic situations. The GENTIX mouse can be connected quickly and easily to any Notebook, PC or Mac via the 1.8-meter cable with USB connection.
  • Ergonomic design
    Designed with comfort in mind, the CHERRY GENTIX mouse features rubber side grips that ensure a secure and comfortable hold, even during extended use.
  • Precise navigation
    Equipped with advanced optical movement detection technology, this mouse offers precise and smooth cursor control, enhancing your productivity and gaming experience.
CHERRY GENTIX - mouse - USB - grey, white
Mouse
Wired - USB
Grey, white
Orientation
Right and left-handed
6.86 cm x 11.15 cm x 3.5 cm
120 g
Movement Detection Technology
Optical
Buttons Qty
3
Movement Resolution
1000 dpi
Scrolling wheel, rubber side grips
Cable Length
1.8 m
Microsoft Certification
Compatible with Windows 7
3-year warranty
Mouse
Orientation
6.86 cm
11.15 cm
3.5 cm
120 g
Grey, white
Input Device
Wired
USB
Optical
Buttons Qty
3
Movement Resolution
1000 dpi
Cable Length
1.8 m
1 x USB - 4 pin USB Type A
Plug and Play, C-Tick, BSMI, FCC, VDE GS, cTUVus
Limited warranty - 2 years , Extended warranty - 1 year
Type: Mouse
Colour: Grey
Colour: White
Compatibility: Mac
Compatibility: PC
Brand: Cherry
