Whether for numerical inputs, controls or for frequent number entry - the programmable keyboard is the ideal accessory for notebooks. All keys can be user-defined with up to 24 characters per key.
Durable construction
The CHERRY ML4700 boasts an MTBF of 100,000 hours, making it a dependable choice for extensive usage, whether in an office or at home. -
Programmable keys
Featuring 21 keys, each key can be programmed to perform specific functions, transforming how users interact with their computing setup. -
Stable wired connectivity
The integrated keyboard cable provides a direct connection, eliminating concerns over wireless interference while ensuring fast response times. -
Wide operational range
Designed to function effectively in various environments, the keypad operates smoothly between temperatures of 0°C and 50°C, accommodating different operating conditions. -
VDE compliant standards
This keypad meets VDE standards, assuring users of its safety and compliance with established quality benchmarks.
- CHERRY ML4700 - keypad - US - black Input Device
- Keypad
- Interface
- USB
- Connectivity Technology
- Wired
- Localization and Layout
- US
- Keys Qty
- 21
- Hot Keys Function
- Programmable
- Cherry ML technology
- Black
- 9 cm x 13.2 cm x 3.6 cm
- 3-year warranty
- Keypad
- Interface
- USB
- Keys Qty
- 21
- Hot Keys Function
- Programmable
- US
- Region
- United States
- 9 cm
- 13.2 cm
- 3.6 cm
- Connections
- 1 x USB - 4 pin USB Type A
- Black
- Cables Included
- 1 x keyboard cable - 1.8 m
- FCC Class B certified, CSA, VCCI, C-Tick, BSMI, GOST, VDE, WHQL
- MTBF
- 100,000 hours
- Included Software
- Drivers & Utilities, CHERRY Tools
- OS Required
- Microsoft Windows 98/ME/2000/XP
- Limited warranty - 2 years , Extended warranty - 1 year
- 0 °C
- 50 °C
