Ceratech Sleek Rechargeable Bluetooth Keyboard - Windows Layout - Black
Quicklinx: BFMWWS00 Mfr#: KYB-MINIMUS-BTWB
The Accuratus Minimus Bluetooth wireless mini keyboard is the ideal partner for your sleek portable device. This Bluetooth keyboard has an excellent range of several meters! The Minimus is designed with style in mind, with an ultra sleek stainless steel surround and bottom case, a keyboard low thickness and no wires, even the most style conscious wont be disappointed.
The Minimus keyboard has a mini layout, which means it has all the usual qwerty and number keys with just the removal of the number pad that usually sits on the right hand side. It also has one touch multimedia and Internet keys along the top. The Minimus even has an internal lithium rechargeable battery so you will never have to go out of your way to buy replacement battery.
Accuratus Minimus - keyboard - QWERTY - UK - black
Keyboard
Bluetooth
Localization and Layout
QWERTY UK
Power saving automatic sleep function, on/off power switch, battery LED indicator, status LED indicator
Image Colour Disclaimer
The displayed product image may be a different colour
20.5 cm x 8.2 cm x 0.58 cm
143 g
Keyboard
Bluetooth
Max Operating Distance
Up to 10 m
Input Device
QWERTY UK
Keyboard Technology
Scissors
20.5 cm
8.2 cm
0.58 cm
143 g
1 x charging cable
FCC, RoHS
Microsoft Windows Vista / XP / 7 / 8
Lithium Ion
