The Accuratus AccuMed range of medical grade keyboards and mice have the Nanoarmor-2 dual layer antibacterial protection impregnated in the silicone and coated on the surface to aid in deactivating germs/build up of bacteria and virus's.
The range are specifically designed for environments which have to meet very high hygienic requirements such as hospitals, dental practices, cosmetic surgeries, doctors, vets, laboratories and in food and pharmaceutical production areas. Not only could these keyboards be used in hygienic areas, they would also be perfect in dusty, dirty and wet situations like workshops, boats and in vehicles.
The AccuMed range have all been designed so that there are no areas around the keys and buttons where dirt and germs can collect, this combined with the Nanoarmor-2 antibacterial technology is the perfect combination to aid with bacteria, virus, fungi and algae control.
- Ceratech Accuratus - mouse - PS/2, USB - white
- Mouse
- Connectivity Technology
- Wired - PS/2, USB
- White
- Orientation
- Right and left-handed
- 6.8 cm x 15.8 cm x 4.2 cm
- 155 g
- Movement Detection Technology
- Optical
- Buttons Qty
- 5
- Movement Resolution
- 800 dpi
- Washable, waterproof, status led, silicone cover, NANOARMOUR-2 antibacterial protection, chemical-resistant, dirt-resistant
- Cable Length
- 1.5 m
- OS Required
- Apple MacOS X, Microsoft Windows 98SE/2000/ME/XP/Vista/7
- 1-year warranty
- Mouse
- Orientation
- 6.8 cm
- 15.8 cm
- 4.2 cm
- 155 g
- White
Input Device
- Wired
- Interface
- PS/2, USB
- Optical
- Buttons Qty
- 5
- 800 dpi
- Cable Length
- 1.5 m
- 1 x USB - 4 pin USB Type A ¦ 1 x mouse - generic - 6 pin mini-DIN (PS/2 style)
- Plug and Play, FCC, RoHS, WEEE, IP67, JIS Z 2801:2001
- OS Required
- Limited warranty - 1 year
- -20 °C
- 50 °C
