Cello C50238DVBT2 50-inch Widescreen Full HD 1080p LED with High Def Freeview
This slim line 1080p 50" Full HD TV is and asset for any living area. Watch your Freeview programmes on the 1920 x 1080 resolution screen including all T2 Hi Definition Freeview channels. Connect your external devices to the 3 x HDMI ports, you can also record TV, play music and video files or show photos and text files by connecting a USB Device to the USB port on the TV. The Electronic Programme Guide (EPG) allows you to view TV listings up to 7 days in advance also with reminder and timer record options.
Freeview is a free digital TV service. It provides 50 digital TV channels and 24 radio stations with no need for a subscription. All Cello TVs include Freeview as standard.
HDMI connections provide superior, uncompressed digital video and audio quality. Ideal for connecting your TV to devices such as satellite boxes and Blu-ray disc players.
For the ultimate high definition experience, Cello Full HD TV delivers 1080 horizontal lines per frame, bringing you the ultimate in TV viewing picture quality.
USB recording feature - Simply insert a USB memory stick (not supplied). Highlight the programme to record on the 7 day EPG and press record. You can also pause live TV.
View all Freeview T2 Hi Definition channels
What's in the box?
- Box Contains 1 X 50-inch LED TV
Full HD
For the ultimate HD experience, Cello Full HD TV delivers 1080 horizontal lines per frame, bringing you the ultimate in TV viewing picture quality. -
HDMI
HDMI connections provide superior, uncompressed digital video and audio quality. Ideal for connecting your TV to devices such as satellite boxes and Blu-ray disc players. -
USB
USB recording feature - simply insert a USB memory stick. Highlight the program to record on the 7 day EPG and press record. You can also pause live TV.
- Cello C50238DVBT2 50" LED-backlit LCD TV - Full HD
- Product Type
- LED-backlit LCD TV
- Diagonal Class
- 50"
- Resolution
- 1920 x 1080
- Display Format
- 1080p
- Input Video Formats
- 480p, 720p, 1080i, 1080p, 480i, 576i, 576p
- Video Interface
- Component, composite, HDMI, SCART
- HDMI Ports Qty
- 3 ports
- PC Interface
- VGA (HD-15)
- HDCP Compatible
- LCD Backlight Technology
- LED backlight
- Image Aspect Ratio
- 16:9
- Digital TV Tuner
- DVB-T2
- Analogue TV Tuner
- PAL, SECAM
- Speaker System
- 2 speakers
- Stereo Reception System
- NICAM, A2
- USB
- Included Accessories
- Remote control
- Voltage
- AC 120/230 V
- Energy Class
- Class A
- Power Consumption (On mode)
- 93 W
- Power Consumption Stand by
- 0.5 Watt
- Energy Consumption per Year
- 136 kWh
- 113.6 cm x 26 cm x 72.7 cm
- 20.5 kg
- Product Type
- Energy Class
- Class A
- 93 W
- 136 kWh
- Diagonal Class
- 50"
- TV Tuner Presence
- Extended PVR
- Video Interface
- HDMI Ports Qty
- 3 ports
- PC Interface
- VGA (HD-15)
- HDCP Compatible
- Timer Functions
- Sleep, record
- Dimensions
- With stand
- 113.6 cm
- 26 cm
- 72.7 cm
- 20.5 kg
Display
- Resolution
- 1920 x 1080
- Display Format
- 1080p
- 16:9
- LED backlight
- Image Contrast Ratio
- 5000:1
- Brightness
- 250 cd/m²
- Widescreen Modes
- Conventional 4:3, Full, Zoom, 16:9
- Comb Filter
- 3D digital
- Colour Temperature Control
- Yes (Standard/Cool/Warm)
- 3D Noise Reduction, time-shift, 3D De-interlace
Stands & Mounts
- Stand
- Included
- Stand Design
- Tabletop
- Flat Panel Mount Interface
- 400 x 400 mm
TV Tuner
- Analogue TV Tuner
- PAL, SECAM
- Conditional Access
- Common Interface (CI) slot
- Reception System
- SECAM-D, SECAM-B, SECAM-K, PAL-B, SECAM-G, PAL-G, PAL-I, PAL-D, PAL-K
- NICAM, A2
Digital TV Tuner
- Digital TV Tuner
- DVB-T2
- Digital TV Service
- FREEVIEW, SAORVIEW
- MPEG Profiles and Levels
- MPEG2 MP@HL, MPEG2 MP@ML
Video Features
- Supported Computer Resolutions
- 1024 x 768 (XGA), 640 x 480 (VGA), 800 x 600 (SVGA), 1360 x 768, 1920 x 1080
- Teletext
- Electronic Programme Guide
- Digital EPG
Media Player
- Supported Video Formats
- MPEG-1, MPEG-2, MPEG-4, WMV, AVI, H.264
- Supported Audio Formats
- MP3, WMA, WAV, AC3, AAC
- Supported Pictures Formats
- BMP, JPG, GIF, TIFF, PNG
- USB Port
- USB Ports Qty
- 1
Remote Control
- Remote control
Audio System
- Audio Controls
- Sound mode, balance, bass, treble
- Speaker System
- 2 speakers
- Output Power / Total
- 16 Watt
- Speakers
- 2 x main channel speaker - 8 Watt
- Connector Type
- VGA input - side , Composite video/audio input - bottom , Component video input - bottom , 3 x HDMI input - bottom , Headphones - bottom , Digital audio output (coaxial) - bottom , USB 2.0 - side , Audio line-in - side , SCART - bottom
- EN55022, EN55013, EN 61000-3-3:2008, EN 61000-3-2:2006+A1:2009+A2:2009, EN 55020:2007, EN 55024-2:1998+A1:2001+A2:2003
- Power Device
- Power adapter
- Input Voltage
- AC 120/230 V
- 0.5 Watt
Dimensions & Weight Details
- Dimensions & Weight Details
- Panel with stand - 113.6 cm x 26 cm x 72.7 cm x 20.5 kg , Panel without stand - 113.6 cm x 7.8 cm x 67 cm
- 0 °C
- 40 °C
