For the ultimate high definition experience, Cello Full HD TV delivers 1080 horizontal lines per frame, bringing you the ultimate in TV viewing picture quality.
HDMI connections provide superior, uncompressed digital video and audio quality. Ideal for connecting your TV to devices such as satellite boxes and Blu-ray disc players.
USB recording feature - simply insert a USB memory stick. Highlight the program to record on the 7 day EPG and press record. You can also pause live TV.
Full HD
For the ultimate high definition experience, Cello Full HD TV delivers 1080 horizontal lines per frame, bringing you the ultimate in TV viewing picture quality. -
HDMI
HDMI connections provide superior, uncompressed digital video and audio quality. Ideal for connecting your TV to devices such as satellite boxes and Blu-ray disc players. -
USB
- Cello C40227DVB-LED 40" LED-backlit LCD TV - Full HD
- Product Type
- LED-backlit LCD TV
- Diagonal Class
- 40"
- Resolution
- 1920 x 1080
- Display Format
- 1080p
- Video Interface
- Component, composite, HDMI, SCART
- HDMI Ports Qty
- 3 ports
- PC Interface
- VGA (HD-15)
- LCD Backlight Technology
- LED backlight
- Analogue TV Tuner
- PAL, SECAM
- Speaker System
- 2 speakers
- USB
- Included Accessories
- Remote control
- Voltage
- AC 120/230 V (50/60 Hz)
- Energy Class
- Class A
- Power Consumption (On mode)
- 62 W
- Power Consumption Stand by
- 0.5 Watt
- Energy Consumption per Year
- 91 kWh
- Dimensions (WxDxH) - without stand
- 93.2 cm x 8.8 cm x 56.1 cm
- 9.6 kg
- Product Type
- Energy Class
- Class A
- 62 W
- 91 kWh
- Diagonal Class
- 40"
- TV Tuner Presence
- Video Interface
- HDMI Ports Qty
- 3 ports
- PC Interface
- VGA (HD-15)
- Dimensions
- Without stand
- 93.2 cm
- 8.8 cm
- 56.1 cm
- 9.6 kg
Display
- Resolution
- 1920 x 1080
- Display Format
- 1080p
- LED backlight
- Image Contrast Ratio
- 3000:1
- Brightness
- 230 cd/m²
Stands & Mounts
- Stand
- Included
- Stand Design
- Tabletop
- Flat Panel Mount Interface
- 200 x 200 mm
TV Tuner
- Analogue TV Tuner
- PAL, SECAM
- Conditional Access
- Common Interface (CI) slot
- Reception System
- SECAM-D, SECAM-B, SECAM-K, PAL-B, SECAM-G, PAL-G, PAL-D, PAL-K
Video Features
- Electronic Programme Guide
- Digital EPG
Media Player
- USB Port
- USB Ports Qty
- 1
Remote Control
- Remote control
Audio System
- Speaker System
- 2 speakers
- Output Power / Total
- 16 Watt
- Speakers
- 2 x main channel speaker - 8 Watt
- Connector Type
- 3 x HDMI input - rear , VGA input - side , SCART - rear , USB 2.0 - side , Composite video input - side , Component video input - side , Audio line-in - side , Digital audio output (coaxial) - side , Headphones - rear
- Power Device
- Power supply
- Input Voltage
- 0.5 Watt
Dimensions & Weight Details
- Dimensions & Weight Details
- Panel without stand - 93.2 cm x 8.8 cm x 56.1 cm x 9.6 kg , Panel with stand - 93.2 cm x 23 cm x 60.1 cm
- 0 °C
- 40 °C
