With this TV you can connect three external devices using the three available HDMI connections. The Digital TV technology brings you digital broadcast signals and an electronic program guide (EPG) allowing you to view TV listings up to 7 days in advance. You can also playback music, films and photos using the USB port.
HDMI
HDMI connections provide superior, uncompressed digital video and audio quality. Ideal for connecting your TV to devices such as satellite boxes and Blu-ray disc players. -
USB
Highlight the program to record on the 7 day EPG and press record. You can also pause live TV. -
HD ready
Cello HD ready TVs can display a picture of 1920 by 1080 pixels - well over 2 million - which adds clarity to images never before possible with analog or standard definition digital.
- Cello C32227DVB 32" LED-backlit LCD TV - HD
- Product Type
- LED-backlit LCD TV
- Diagonal Class
- 32"
- Resolution
- 1366 x 768
- Display Format
- 720p
- Video Interface
- Component, composite, HDMI, SCART
- HDMI Ports Qty
- 3 ports
- PC Interface
- VGA (HD-15)
- HDCP Compatible
- LCD Backlight Technology
- LED backlight
- Digital TV Tuner
- DVB-T, QAM
- Analogue TV Tuner
- PAL, SECAM
- Speaker System
- 2 speakers
- Stereo Reception System
- NICAM, A2
- USB
- Voltage
- AC 120/230 V
- Energy Class
- Class A
- Power Consumption (On mode)
- 35 W
- Power Consumption Stand by
- 0.5 Watt
- Energy Consumption per Year
- 52 kWh
- Dimensions (WxDxH) - without stand
- 73.8 cm x 9.2 cm x 44 cm
- Product Type
- Energy Class
- Class A
- 35 W
- 52 kWh
- Diagonal Class
- 32"
- TV Tuner Presence
- Video Interface
- HDMI Ports Qty
- 3 ports
- PC Interface
- VGA (HD-15)
- HDCP Compatible
- Dimensions
- Without stand
- 73.8 cm
- 9.2 cm
- 44 cm
Display
- Resolution
- 1366 x 768
- Display Format
- 720p
- LED backlight
- Image Contrast Ratio
- 3000:1
- Brightness
- 250 cd/m²
- Comb Filter
- 3D digital
- 3D Noise Reduction, 3D De-interlace
TV Tuner
- Analogue TV Tuner
- PAL, SECAM
- Conditional Access
- Common Interface (CI) slot
- NICAM, A2
Digital TV Tuner
- Digital TV Tuner
- DVB-T, QAM
- Digital TV Service
- FREEVIEW, SAORVIEW
- MPEG Profiles and Levels
- MPEG2 MP@HL
Video Features
- Electronic Programme Guide
- Digital EPG
Media Player
- USB Port
- USB Ports Qty
- 1
Audio System
- Speaker System
- 2 speakers
- Output Power / Total
- 16 Watt
- Speakers
- 2 x main channel speaker - 8 Watt
- Connector Type
- 3 x HDMI input , Component video input , VGA input , Audio line-in , SCART , Composite video/audio input , Digital audio output (coaxial) , Headphones , USB 2.0
- Plug and Play
- Input Voltage
- AC 120/230 V
- 0.5 Watt
Dimensions & Weight Details
- Dimensions & Weight Details
- Panel without stand - 73.8 cm x 9.2 cm x 44 cm , Panel with stand - 73.8 cm x 20.4 cm x 49 cm x 6 kg
