Cello 40" LED TV Black 1920 x 1080 Resolution Built-in DVD
Built-in DVD Player and 3 x USB Ports
Quicklinx: 9H0QWS00 Mfr#: C40227FT2
Screen Size: 40in
Screen Resolution: 1080p (Full HD)
HDMI Inputs: 2
Interface: Component, Composite, HDMI, SCART
Screen Technology: LED
  • FREEVIEW
  • 1080p (Full HD)
£185.97 ex VAT
£223.16 inc VAT
This slimline 1080p Full HD TV is and asset for any living area.
Watch your Freeview programmes on the 1920 x 1080 resolution screen.
Connect your external devices to the 3 x HDMI ports, you can also record TV, play music and video files or show photos and text files by connecting a USB Device to the USB port on the TV.
The Electronic Programme Guide (EPG) allows you to view TV listings up to 7 days in advance also with reminder and timer record options.
Watch and enjoy your favorite films on the High grade intergrated DVD player.
The SRS TruSurround option will enhance your audio experience.
  • DVD
    Integrating a DVD player into the TV is a great way to combine two units into one neat package. As well as saving space it means less cables and one remote control.
  • Full HD
    For the ultimate high definition experience, Cello Full HD TV delivers 1080 horizontal lines per frame, bringing you the ultimate in TV viewing picture quality.
  • USB
    USB recording feature - simply insert a USB memory stick. You can also pause live TV.
  • HDMI
    HDMI connections provide superior, uncompressed digital video and audio quality. Ideal for connecting your TV to devices such as satellite boxes and Blu-ray Disc players.
Cello C40227FT2 40" LED TV
LED-backlit LCD TV with built-in DVD player
Diagonal Class
40"
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Video Interface
Component, composite, HDMI, SCART
HDMI Ports Qty
3 ports
PC Interface
VGA (HD-15)
LCD Backlight Technology
LED backlight
Digital TV Tuner
DVB-T2
Analogue TV Tuner
PAL, SECAM
Speaker System
2 speakers
Stereo Reception System
NICAM, A2
DVD
DVD player
USB
Remote Control
Standard remote
Voltage
Energy Class
Class A
Power Consumption (On mode)
62 W
Power Consumption Stand by
0.5 Watt
Energy Consumption per Year
91 kWh
93.2 cm x 8.8 cm x 56.1 cm
9.6 kg
LED-backlit LCD TV
Energy Class
Class A
62 W
91 kWh
Diagonal Class
40"
Combined with
Built-in DVD player
TV Tuner Presence
Video Interface
HDMI Ports Qty
3 ports
PC Interface
VGA (HD-15)
Dimensions
Without stand
93.2 cm
8.8 cm
56.1 cm
9.6 kg
Display
Resolution
1920 x 1080
Display Format
1080p (Full HD)
LED backlight
Image Contrast Ratio
3000:1
Brightness
230 cd/m²
Comb Filter
3D digital
3D Noise Reduction, 3D De-interlace
Stands & Mounts
Stand
Included
Stand Design
Tabletop
VESA Mounting Interface
200 x 200 mm
DVD
DVD player
TV Tuner
Analogue TV Tuner
PAL, SECAM
Conditional Access
Common Interface (CI) slot
NICAM, A2
Digital TV Tuner
Digital TV Tuner
DVB-T2
Digital TV Service
FREEVIEW, SAORVIEW
MPEG Profiles and Levels
MPEG2 MP@HL, MPEG4 AVC/H.264
Video Features
Digital EPG
Media Player
USB Port
USB Ports Qty
1
Remote Control
Standard remote
Audio System
Speaker System
2 speakers
Output Power / Total
16 Watt
SRS TruSurround HD
Speakers
2 x main channel speaker - built-in - 8 Watt
Connector Type
3 x HDMI input , VGA input , SCART , USB 2.0 , Composite video input , Component video input , Audio line-in , Digital audio output (coaxial) , Headphones
Plug and Play
Power supply
Nominal Voltage
0.5 Watt
Dimensions & Weight Details
Panel without stand - 93.2 cm x 8.8 cm x 56.1 cm x 9.6 kg , Panel with stand - 93.2 cm x 23 cm x 60.1 cm
Screen Size: 40in
HDMI Inputs: 2
Interface: Composite
Interface: HDMI
Interface: SCART
Brand: Cello
Price Range Ex VAT: 150 - 300
