Cello 32 LED SMART HI DEF
Quicklinx: BS3SWS00 Mfr#: C32227DVBIPTVT2
Smart TV
Watch Internet based media on the Cello Smart TV. As well as channels such as YouTube and iPlayer the iViewer can access popular social networks and home media files.
Freeview
Freeview is a free digital TV service. It provides 50 digital TV channels and 24 radio stations with no need for a subscription. All Cello TVs include Freeview as standard.
HDMI
HDMI connections provide superior, uncompressed digital video and audio quality. Ideal for connecting your TV to devices such as satellite boxes and Blu-ray disc players.
USB
USB recording feature - Simply insert a USB memory stick (not supplied). Highlight the programme to record on the 7 day EPG and press record. You can also pause live TV.
T2 Hi Definition Freeview Channels
View all Freeview T2 Hi Definition channels
Cello C32227DVBIPTVT2-LED 32" LED-backlit LCD TV - HD
LED-backlit LCD TV
Diagonal Class
32"
Resolution
1366 x 768
Display Format
720p
Video Interface
Component, composite, HDMI, SCART
HDMI Ports Qty
2 ports
PC Interface
VGA (HD-15)
LCD Backlight Technology
LED backlight
Analogue TV Tuner
PAL, SECAM
Commercial Features
Built-in clock, Lock Mode
Speaker System
2 speakers
USB
3 ports
Remote control
Voltage
AC 120/230 V
Energy Class
Class A
Power Consumption (On mode)
35 W
Power Consumption Stand by
0.5 Watt
Energy Consumption per Year
52 kWh
73.8 cm x 9.2 cm x 44 cm
9.7 kg
LED-backlit LCD TV
Energy Class
Class A
35 W
52 kWh
Diagonal Class
32"
TV Tuner Presence
Video Interface
HDMI Ports Qty
2 ports
PC Interface
VGA (HD-15)
Modes
Dynamic Picture Mode, user mode
Timer Functions
Sleep
Dimensions
Without stand
73.8 cm
9.2 cm
44 cm
9.7 kg
Display
Resolution
1366 x 768
Display Format
720p
LED backlight
Image Contrast Ratio
1200:1
Brightness
210 cd/m²
Commercial Features
Time-shift
Stands & Mounts
Stand
Included
Stand Design
Tabletop
Flat Panel Mount Interface
200 x 100 mm
TV Tuner
Analogue TV Tuner
PAL, SECAM
Conditional Access
Common Interface (CI) slot
Reception System
SECAM-D, SECAM-B, SECAM-K, PAL-B, SECAM-G, PAL-G, PAL-D, PAL-K
Video Features
Supported Computer Resolutions
1024 x 768 (XGA), 640 x 480 (VGA), 800 x 600 (SVGA), 1360 x 768
Teletext
Electronic Programme Guide
Digital EPG
Parental Channel Lock
Media Player
Supported Video Formats
MPEG-1, MPEG-2, MPEG-4, WMV, AVI, H.264
Supported Audio Formats
WMA, AC3, AAC
USB Port
USB Ports Qty
3
Remote Control
Remote control
Sleep timer
Audio System
Speaker System
2 speakers
Output Power / Total
16 Watt
Speakers
2 x main channel speaker - 8 Watt
Connector Type
2 x HDMI input - rear , Component video input - rear , VGA input - side , Audio line-in - side , SCART - rear , Composite video/audio input - rear , Digital audio output (coaxial) - rear , Headphones - rear , 3 x USB - side , LAN - rear
Network cable
EN 61000-3-3:2008, Directive 2006/66/EC, EN 61000-3-2:2006+A1:2009+A2:2009, EN 55020:2007, EN 55013:2001+A1:2003+A2:2006, EN 55024:1998+A1:2001+A2:2003, EN 55022:2006+A1:2007
Power adapter
Input Voltage
AC 120/230 V
0.5 Watt
Dimensions & Weight Details
Panel without stand - 73.8 cm x 9.2 cm x 44 cm x 9.7 kg , Panel with stand - 73.8 cm x 20.4 cm x 49 cm
