Smart TV
Watch Internet based media on the Cello Smart TV. As well as channels such as YouTube and iPlayer the iViewer can access popular social networks and home media files.
Freeview
Freeview is a free digital TV service. It provides 50 digital TV channels and 24 radio stations with no need for a subscription. All Cello TVs include Freeview as standard.
HDMI
HDMI connections provide superior, uncompressed digital video and audio quality. Ideal for connecting your TV to devices such as satellite boxes and Blu-ray disc players.
USB
USB recording feature - Simply insert a USB memory stick (not supplied). Highlight the programme to record on the 7 day EPG and press record. You can also pause live TV.
T2 Hi Definition Freeview Channels
View all Freeview T2 Hi Definition channels
- Cello C32227DVBIPTVT2-LED 32" LED-backlit LCD TV - HD
- Product Type
- LED-backlit LCD TV
- Diagonal Class
- 32"
- Resolution
- 1366 x 768
- Display Format
- 720p
- Video Interface
- Component, composite, HDMI, SCART
- HDMI Ports Qty
- 2 ports
- PC Interface
- VGA (HD-15)
- LCD Backlight Technology
- LED backlight
- Analogue TV Tuner
- PAL, SECAM
- Commercial Features
- Built-in clock, Lock Mode
- Speaker System
- 2 speakers
- USB
- 3 ports
- Included Accessories
- Remote control
- Voltage
- AC 120/230 V
- Energy Class
- Class A
- Power Consumption (On mode)
- 35 W
- Power Consumption Stand by
- 0.5 Watt
- Energy Consumption per Year
- 52 kWh
- Dimensions (WxDxH) - without stand
- 73.8 cm x 9.2 cm x 44 cm
- 9.7 kg
- Product Type
- Energy Class
- Class A
- 35 W
- 52 kWh
- Diagonal Class
- 32"
- TV Tuner Presence
- Video Interface
- HDMI Ports Qty
- 2 ports
- PC Interface
- VGA (HD-15)
- Modes
- Dynamic Picture Mode, user mode
- Timer Functions
- Sleep
- Dimensions
- Without stand
- 73.8 cm
- 9.2 cm
- 44 cm
- 9.7 kg
Display
- Resolution
- 1366 x 768
- Display Format
- 720p
- LED backlight
- Image Contrast Ratio
- 1200:1
- Brightness
- 210 cd/m²
- Time-shift
Stands & Mounts
- Stand
- Included
- Stand Design
- Tabletop
- Flat Panel Mount Interface
- 200 x 100 mm
TV Tuner
- Analogue TV Tuner
- PAL, SECAM
- Conditional Access
- Common Interface (CI) slot
- Reception System
- SECAM-D, SECAM-B, SECAM-K, PAL-B, SECAM-G, PAL-G, PAL-D, PAL-K
Video Features
- Supported Computer Resolutions
- 1024 x 768 (XGA), 640 x 480 (VGA), 800 x 600 (SVGA), 1360 x 768
- Teletext
- Electronic Programme Guide
- Digital EPG
- Parental Channel Lock
Media Player
- Supported Video Formats
- MPEG-1, MPEG-2, MPEG-4, WMV, AVI, H.264
- Supported Audio Formats
- WMA, AC3, AAC
- USB Port
- USB Ports Qty
- 3
Remote Control
- Remote control
- Sleep timer
Audio System
- Speaker System
- 2 speakers
- Output Power / Total
- 16 Watt
- Speakers
- 2 x main channel speaker - 8 Watt
- Connector Type
- 2 x HDMI input - rear , Component video input - rear , VGA input - side , Audio line-in - side , SCART - rear , Composite video/audio input - rear , Digital audio output (coaxial) - rear , Headphones - rear , 3 x USB - side , LAN - rear
- Cables Included
- Network cable
- EN 61000-3-3:2008, Directive 2006/66/EC, EN 61000-3-2:2006+A1:2009+A2:2009, EN 55020:2007, EN 55013:2001+A1:2003+A2:2006, EN 55024:1998+A1:2001+A2:2003, EN 55022:2006+A1:2007
- Power Device
- Power adapter
- Input Voltage
- AC 120/230 V
- 0.5 Watt
Dimensions & Weight Details
- Dimensions & Weight Details
- Panel without stand - 73.8 cm x 9.2 cm x 44 cm x 9.7 kg , Panel with stand - 73.8 cm x 20.4 cm x 49 cm
- 0 °C
- 40 °C
