Enjoy 720p performance anywhere on Cello's C2822DVB 28 Inch Freeview LED TV. The HD Ready screen provides the pinnacle of picture quality with unprecedented clarity and vibrant colours - all the while ensuring that energy consumption is kept to a minimum. It's the only way to experience your Blu-ray and HD gaming. Watch the best of British TV for absolutely FREE on the C2822DVB LED TV. Enjoy a huge selection of free digital TV and radio channels, including BBC Three and ITV 2 without the need for an extra set top box. If there's nothing on the box then simply pop a DVD into the side of the TV and make it a movie night in. Cello's C2822DVB LED TV boasts an extensive range of connectivity options for you to maximise you viewing experience; the HDMI ports allows for easy connection to your games console or other HD devices, while the PC input lets you to connect your PC and use the TV as a PC monitor. The USB port enables you to connect a digital camera or MP3 player to the TV and playback your photos and stored music directly on the TV screen. You can also use a USB device to record and catch up on TV programmes you may have missed.
- Cello C28227DVB 28" LED-backlit LCD TV - HD
- Product Type
- LED-backlit LCD TV
- Diagonal Class
- 28"
- Resolution
- 1366 x 768
- Display Format
- 720p
- Video Interface
- Component, composite, HDMI, SCART
- HDMI Ports Qty
- 3 ports
- PC Interface
- VGA (HD-15)
- LCD Backlight Technology
- LED backlight
- Digital TV Tuner
- DVB-T
- Analogue TV Tuner
- PAL, SECAM
- Speaker System
- 2 speakers
- Stereo Reception System
- NICAM, A2
- USB
- Included Accessories
- Remote control
- Voltage
- AC 120/230 V
- Energy Class
- Class A+
- 31 Watt
- Power Consumption Stand by
- 0.5 Watt
- 64.5 cm x 20 cm x 45.2 cm
- 4.5 kg
- Product Type
- Energy Class
- Class A+
- 31 Watt
- Diagonal Class
- 28"
- TV Tuner Presence
- Video Interface
- HDMI Ports Qty
- 3 ports
- PC Interface
- VGA (HD-15)
- Dimensions
- With stand
- 64.5 cm
- 20 cm
- 45.2 cm
- 4.5 kg
Display
- Resolution
- 1366 x 768
- Display Format
- 720p
- LED backlight
- Image Contrast Ratio
- 3000:1
- Brightness
- 220 cd/m²
- Comb Filter
- 3D digital
- 3D Noise Reduction, 3D De-interlace
Stands & Mounts
- Flat Panel Mount Interface
- 200 x 100 mm
TV Tuner
- Analogue TV Tuner
- PAL, SECAM
- Conditional Access
- Common Interface (CI) slot
- NICAM, A2
Digital TV Tuner
- Digital TV Tuner
- DVB-T
- Digital TV Service
- FREEVIEW
Video Features
- Electronic Programme Guide
- Digital EPG
Media Player
- USB Port
- USB Ports Qty
- 1
Remote Control
- Remote control
Audio System
- Speaker System
- 2 speakers
- Output Power / Total
- 10 Watt
- Speakers
- 2 x main channel speaker - 5 Watt
- Connector Type
- VGA input , SCART , 3 x HDMI , Component video input , Composite video/audio input , Audio line-in , Digital audio output (coaxial) , Headphones , USB 2.0
- Power Device
- Power supply
- Input Voltage
- AC 120/230 V
- 0.5 Watt
Dimensions & Weight Details
- Dimensions & Weight Details
- Panel without stand - 64.5 cm x 7.4 cm x 40.3 cm , Panel with stand - 64.5 cm x 20 cm x 45.2 cm x 4.5 kg
