The CAT B25 is an ultra-rugged phone that was built to take some abuse. It's got the features you want like a 2-megapixel camera, fm radio and flashlight, plus the features you need like 2G web connectivity, SMS/MMS capability and even a speakerphone.
Compact and straightforward
Cased in durable rubber and designed to ensure a comfortable feel in the hand, the CAT B25 is a resilient phone that can keep you connected. It puts the tools you need at tips of your fingers. -
Not afraid of dust or water
IP67 certified, the CAT B25 is waterproof for up to 30 min in 1 m of water so whether it's hit by a splash or ends up in a puddle it keeps working. -
Long lasting battery
Powered by large capacity battery, the CAT B25 can support long hours of continuous conversation; making it a great choice for people who go longer periods of time between charges.
- CAT B25 -
- Rear-facing camera, voice recorder
- Rear Camera
- Focus: automatic
- Front Camera
- 2 Megapixel
- Service Provider
- Not specified
- Form Factor
- Rugged
- Messaging Services
- SMS
- Form Factor
- Touch - Rugged
- Integrated Components
Cellular
- Service Provider
- Not specified
- Input Device
- Multi-touch
Messaging & Internet
- SMS
- Supported Social Networks and Blogs
Communications
- Data Transmission
- GPRS, EDGE
Phone Features
- Phone Functions
- Call timer, conference call
Front Camera
- Sensor Resolution
- 2 Megapixel
Rear Camera
- Focus Adjustment
- Automatic
- IP67
- Included Accessories
- Power adapter
- Max Depth of Water Resistance
- 1 m
