Casio XJ-V110W-UJ 3500LM WXGA DLP Technology Printer
Quicklinx: C4DLWS00 Mfr#: XJ-V110W-UJ
With TCO substantially reduced by their long-life light source, low energy consumption and filter-free design, CASIO Lamp Free projectors afford a wide range of value for use in everything from business to education.
  • Light control
    Brightness is automatically adjusted to the optimal level for room brightness, which reduces electrical power costs. Adjustment is one of 7 brightness levels and Manual adjustment is also supported.
  • Freely configurable projection orientation
    There is a wide variety of projection setup to meet various uses, however almost mainstream projectors are capable of only two orientations, Desktop and Ceiling mounted. XJ-V110W realized more configuration freedom, and it supports a wide range of applications.
  • Stylish compact design
    The structure with its square form and flowing curves exemplifies contemporary design excellence. The compact projector body assures easy portability for every user.
Casio Core XJ-V110W - DLP projector - white
DLP projector
White
Brightness
3500 ANSI lumens
Contrast Ratio
20000:1
Resolution
WXGA (1280 x 800)
Native Aspect Ratio
16:10
Bulb type
Laser/LED
Bulb life cycle
Up to 20000 hour(s)
Video Input
RGB, component video
165 Watt
29.9 cm x 29.9 cm x 9.7 cm
3.5 kg
DLP projector
Enclosure Colour
White
Projector
Brightness
3500 ANSI lumens
Contrast Ratio
20000:1
Image Size
89 cm - 762 cm
Throw Ratio
1.32 - 1.93:1
Resolution
WXGA - WXGA (1280 x 800)
Native Aspect Ratio
16:10
Bulb type
Laser/LED
Bulb life cycle
Up to 20000 hour(s)
Controls & Adjustments
Keystone correction
Intelligent Brightness Control, instant on/off
Lens
Focus Type
Manual
Zoom Type
Manual
Zoom Factor
1.5x
Keystone Correction Direction
Vertical
Vertical Keystone Correction
-30 / +30
Video Input
Analogue video Signal
Video Interfaces
VGA, HDMI
1 x component video / RGB input - 15 pin HD D-Sub (HD-15) , 1 x serial RS-232C - 9 pin D-Sub (DB-9) (management) , 1 x HDMI input - 19 pin HDMI Type A , 1 x audio line-in - mini-phone stereo 3.5 mm , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x USB - 5 pin Micro-USB Type B
2 x AAA batteries, remote control
1 x VGA cable
165 Watt
Power Consumption Stand by
0.23 Watt
29.9 cm
29.9 cm
9.7 cm
3.5 kg
