The XJ-V10X uses the cost-effective, environmentally friendly Casio laser and LED hybrid light source, boasting a brightness of 3000 ANSI lumens. The XJ-V10X offers outstanding low total cost of ownership for high-quality, impactful presentations.
Incredible light source
This projector is able to function without the use of toxic mercury and greatly reduce power consumption. -
A durable light source
Thanks to the use of mercury-free lighting technology, the XJ-V10X is able to function for extended periods without replacing the lamp. -
Outstanding color rendition
The incredible laser and LED hybrid light source guarantees clear and brilliant color reproduction for projectors - even in daylight. -
Kind to the environment
The light source fitted in the XJ-V10X projector is mercury-free and environmentally friendly. -
Great performance - minimal consumption
This projector delivers brilliant results with a low power consumption. -
Connection via HDMI
Thanks to the existing HDMI interface, the projectors can be easily connected to external components, such as a suitably equipped laptop. -
Fit for continuous use
Thanks to the special light source and DLP technology, this projector is suitable for continuous use.
- Casio Core XJ-V10X - DLP projector - white
- DLP projector
- White
- Brightness
- 3300 ANSI lumens
- Contrast Ratio
- 20000:1
- Resolution
- XGA (1024 x 768)
- Native Aspect Ratio
- 4:3
- Colour Support
- 1.07 billion colours
- Bulb type
- Laser/LED
- Bulb life cycle
- Up to 20000 hour(s)
- Video Input
- RGB, component video
- Video Modes
- 480p, 1080p
- 155 Watt
- 29.9 cm x 29.9 cm x 9.7 cm
- 3.5 kg
- DLP projector
- Enclosure Colour
- White
Projector
- Brightness
- 3300 ANSI lumens
- Contrast Ratio
- 20000:1
- Image Size
- 76 cm - 762 cm
- Projection Distance
- 0.83 m
- Throw Ratio
- 1.66 - 2.42:1
- Resolution
- XGA - XGA (1024 x 768) (native) / 1920 x 1200 (resized)
- 4:3
- Colour Support
- Bulb type
- Laser/LED
- Bulb life cycle
- Controls & Adjustments
- Keystone correction
- Freeze frame, Direct Power On, Direct Power Off, Intelligent Brightness Control, rear projection, instant on/off
Lens
- Focus Type
- Manual
- Zoom Type
- Manual
- Zoom Factor
- 1.5x
- Keystone Correction Direction
- Vertical
- Vertical Keystone Correction
- -30 / +30
Video Input
- Analogue video Signal
- Video Interfaces
- VGA, HDMI, component video
- Video Modes
- 480p, 1080p
- 1 x component video / RGB input - 15 pin HD D-Sub (HD-15) , 1 x audio line-in - mini-phone stereo 3.5 mm , 1 x HDMI input - 19 pin HDMI Type A , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x USB - Micro-USB Type B , 1 x serial RS-232C - 9 pin D-Sub (DB-9) (management)
- Included Accessories
- 2 x AAA batteries, remote control
- Cables Included
- 1 x VGA cable
- Security Features
- Password protection
- 155 Watt
- Power Consumption Stand by
- 0.23 Watt
- 29.9 cm
- 29.9 cm
- 9.7 cm
- 3.5 kg
- 5 °C
- 35 °C
