Casio XJ-UT310WN WXGA/XGA DLP 3100 Lumens Projector
Quicklinx: BPVQWS00 Mfr#: XJUT310WN
The XJ-UT310WN's advanced LampFree light source combined with the Ultra-Short throw lens system produces 3100 lumens of brightness and boast WXGA (1280 x 800) resolution which is ideal for displaying HD content from video and computer sources. The 16:10 widescreen aspect ratio ensures your content is viewed without distortion.
The XJ-UT310WN boasts a full suite of inputs including, Video, Computer and HDMI terminals with audio. It is equipped with a powerful 16 watts speaker and a dedicated dynamic microphone input ensures everyone can hear. Network (RJ-45) and local RS-232 connections provide control and remote status monitoring capabilities while close captioning used in conjunction with Crestron RoomView allow direct email alerts and much more.
  • Ultra short throw lens
    With its ultra-short throw lens the XJ-UT310WN can project brilliant, shadow-free images up to 110" diagonal. The built-in short throw lens and advanced mirror system provides an extremely close throw ratio (0.28:1) and enables you to project an 80" image from just 1.5 feet away.
  • Brightness and resolution
  • Connectivity
Casio XJ-UT310WN - DLP projector - 3D - 802.11g/n wireless
DLP projector - 720p
3D Capable
Yes (3D glasses sold separately)
Built-in Devices
Speaker
Brightness
3100 lumens
Contrast Ratio
1800:1
Resolution
WXGA (1280 x 800)
Native Aspect Ratio
16:10
Colour Support
16.7 million colours
Bulb type
Laser/LED
Bulb life cycle
Up to 20000 hour(s)
Video Input
RGB, S-Video, component video (NTSC, SECAM, PAL, PAL-N, PAL-M, PAL 60), IEEE 802.11g/n wireless - MPEG-4, AVI, MJPEG, H.264, MOV
Storage Capacity
2 GB Flash
Video Modes
1080p
Speakers
Speaker(s) - integrated
230 Watt
33.8 cm x 33.3 cm x 15.3 cm
5.5 kg
3D Capable
Built-in Devices
Speaker
802.11b/g/n, Ethernet
Projector
Brightness
3100 lumens
Contrast Ratio
1800:1
Image Size
127 cm - 279 cm
Projection Distance
0.06 m
Throw Ratio
0.28:1
Resolution
WXGA - WXGA (1280 x 800) (native) / 1920 x 1080 (resized)
Native Aspect Ratio
16:10
Display Format
1,024,000 pixels
Colour Support
Bulb type
Laser/LED
Bulb life cycle
Up to 20000 hour(s)
Controls & Adjustments
Keystone correction
JPEG photo playback, High-bandwidth Digital Content Protection System (HDCP), DLP 3D Ready, Hybrid Light Source, BMP photo playback, 4:3 aspect ratio support, Image Freeze Function, Ultra Short Throw Technology, Direct Power On, blank screen, PNG photo playback, AAC playback, GIF photo playback, USB Display, Intelligent Brightness Control, Eco Mode
Lens
Focus Type
Manual
Lens Aperture
F/2.3
Keystone Correction Direction
Vertical
Vertical Keystone Correction
-5/ +5
Video Input
TV System
Analogue video Signal
Video Interfaces
VGA, HDMI, component video, composite video, S-Video
Video Modes
1080p
Digital Video Format
LAN and Wireless Image Transferring Protocols
IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Media Player
Storage Capacity
2 GB Flash
Speakers
Integrated
Sound Output Mode
Mono
Output Power / Channel
16 Watt
Speakers
1 x mixed channel
2 x component video / RGB input - 15 pin HD D-Sub (HD-15) , 1 x RGB output - 15 pin HD D-Sub (HD-15) , 1 x HDMI input - 19 pin HDMI Type A , 1 x composite video input - RCA , 1 x S-video input - 4 pin mini-DIN , 1 x audio line-in - RCA x 2 , 2 x audio line-in - mini-phone stereo 3.5 mm , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x microphone - mini-phone mono 3.5 mm , 1 x USB - 4 pin USB Type A , 1 x USB - 4 pin USB Type B , 1 x serial RS-232C - 9 pin D-Sub (DB-9) (management) , 1 x network - RJ-45 (management)
USB wireless network adapter, 2 x AAA batteries, wireless remote control
1 x VGA cable
Security Features
Security lock slot (cable lock sold separately), password protection
230 Watt
Power Consumption Stand by
0.23 Watt
33.8 cm
33.3 cm
15.3 cm
5.5 kg
