This model in the Pro series is perfect for large meeting rooms and school halls. Intelligent Brightness Control adjusts the light output according to the levels of ambient light, which minimizes power consumption - and running costs - by ensuring that the brightness delivered is no more than actually required.
- Casio Pro XJ-H1700-UJ - DLP projector - 3D - white
- DLP projector
- 3D Capable
- White
- Built-in Devices
- Speaker
- Brightness
- 4000 ANSI lumens
- Contrast Ratio
- 1400:1
- Resolution
- XGA (1024 x 768)
- Native Aspect Ratio
- 4:3
- Bulb type
- Laser/LED
- Bulb life cycle
- Up to 20000 hour(s)
- Video Input
- RGB, composite video
- Video Modes
- 480p, 1080p
- Speakers
- Speaker(s) - integrated
- 350 Watt
- 40 cm x 32.3 cm x 10.6 cm
- 7.1 kg
- 5-year warranty
- DLP projector
- 3D Capable
- Built-in Devices
- Speaker
- Enclosure Colour
- White
Projector
- Brightness
- 4000 ANSI lumens
- Contrast Ratio
- 1400:1
- Image Size
- 69 cm - 762 cm
- Throw Ratio
- 1.6 - 1.91:1
- Resolution
- XGA - XGA (1024 x 768)
- 4:3
- Bulb type
- Laser/LED
- Bulb life cycle
- Controls & Adjustments
- Keystone correction
- DLP 3D Ready
Lens
- Focus Type
- Manual
- Zoom Type
- Manual
- Zoom Factor
- 1.2x
- Keystone Correction Type
- Digital
- Keystone Correction Direction
- Vertical
- Vertical Keystone Correction
- -30 / +30
Video Input
- Analogue video Signal
- Video Interfaces
- VGA, HDMI, composite video, S-Video
- Video Modes
- 480p, 1080p
Speakers
- Integrated
- Sound Output Mode
- Mono
- Output Power / Channel
- 10 Watt
- Speakers
- 1 x mixed channel
- 2 x VGA / component video input - 15 pin HD D-Sub (HD-15) , 1 x HDMI input - 19 pin HDMI Type A , 1 x audio line-in - RCA x 2 , 2 x audio line-in - mini-phone stereo 3.5 mm , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x composite video input - RCA , 1 x S-video input - 4 pin mini-DIN , 1 x serial RS-232C - 9 pin D-Sub (DB-9) (management)
- Included Accessories
- Carrying case, wireless remote control
- Cables Included
- 1 x VGA cable
- 350 Watt
- Power Consumption Stand by
- 0.4 Watt
- 40 cm
- 32.3 cm
- 10.6 cm
- 7.1 kg
- Limited warranty - 5 years
- Sound Emission
- 33 dB
- Sound Emission (Economic Mode)
- 28 dB
