Casio XJ-H1650-EJ XGA LED 3500 Lumens Laser Hybrid Projector
Quicklinx: 9B3HWS00 Mfr#: XJ-H1650-EJ
The Casio Pro model projectors have increased I/O connectivity, are 3-D ready and have auto brightness adjustment to save power and reduce eye fatigue.
USB model is Interactive White Board capable IWB is built-in. It also includes RJ-45 wired LAN, wireless presentations and Mobi-show, WLAN presentations from smart phones and mobile devices and presentations from your thumb drive.
  • Casio hybrid light source
    By combining a laser, a fluorescent element and an LED Casio has created an original mercury-free hybrid light source capable of generating high brightness. Casio has achieved high brightness output of green light, which until now, has been considered difficult with conventional semiconductor light sources, by efficiently converting blue laser light into green light using a fluorescent element.
  • Mercury free light source
    Provides 10X longer light source life than Casio mercury lamp while being more economical based on lamp replacement. The Casio Hybrid Light Source projector features quick startup and shutdown. The projector reaches its maximum brightness in a minimum of 8 seconds and requires no cooling down period.
  • Wireless presentations
    Up to 32 PCs can be connected at one time with 4 simultaneously active on screen!
  • Superior color, high brightness
    The Casio Hybrid Light Source projectors deliver a 50 percent increase in color spectrum for high impact presentations due to improvements in LED and laser technology. Superior color reproduction enhances color purity allowing visual effects to appear brighter and offering powerful images that conventional projectors cannot match.
  • Casio projectors are ready for 3-d projection
    Add the excitement of dynamic 3D projection to your business and education applications. Casio projectors can display 3D content from a 3D capable computer and with the optional 2D-3D conversion software convert and view 2D composite video content. 3-D glasses and software required and sold separately.
  • Automatic brightness adjustment
    Auto brightness adjustment saves power and reduce eye fatigue.
Casio Pro XJ-H1650 - DLP projector - 3D - 802.11g/n wireless - white
DLP projector
3D Capable
White
Built-in Devices
Speaker
IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Brightness
3500 lumens
Contrast Ratio
1400:1
Resolution
XGA (1024 x 768)
Native Aspect Ratio
4:3
Colour Support
16.7 million colours
Bulb life cycle
Up to 20000 hour(s)
Video Input
RGB, composite video, component video (NTSC, SECAM, PAL, PAL-N, PAL-M, PAL 60), IEEE 802.11g/n wireless
Digital Video Standard
High-Definition Multimedia Interface (HDMI)
Video Modes
480p, 720p, 1080i, 1080p, 480i, 576i, 576p
Speakers
Speaker(s) - integrated
430 Watt
40 cm x 32.3 cm x 10.6 cm
7.1 kg
3-year warranty
DLP projector
3D Capable
Built-in Devices
Speaker
802.11b/g/n
Enclosure Colour
White
Projector
Brightness
3500 lumens
Contrast Ratio
1400:1
Image Size
69 cm - 762 cm
Projection Distance
0.85 m
Throw Ratio
1.6 - 1.91:1
Resolution
XGA - XGA (1024 x 768) (native) / 1600 x 1200 (resized)
Native Aspect Ratio
4:3
Colour Support
Bulb life cycle
Up to 20000 hour(s)
Controls & Adjustments
Keystone correction
OSD Languages
Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Swedish, Russian, Spanish, Turkish, Japanese, Korean
MobiShow technology, USB host function, DLP 3D Ready, Wireless Ready, Hybrid Light Source, Image Freeze Function, Direct Power On, Direct Power Off, blank screen, Mercury-free illumination technology, Brilliant brightness, Interactive Whiteboard Capable
Lens
Focus Type
Manual
Zoom Type
Manual
Zoom Factor
1.2x
Keystone Correction Type
Digital
Keystone Correction Direction
Vertical
Vertical Keystone Correction
-30 / +30
Video Input
TV System
Analogue video Signal
Video Interfaces
VGA, HDMI, composite video, S-Video
Video Modes
LAN and Wireless Image Transferring Protocols
Speakers
Integrated
Sound Output Mode
Mono
Output Power / Channel
10 Watt
Speakers
1 x mixed channel
Input Device
External
Movement Detection Technology
Infrared
2 x component video / RGB input - 15 pin HD D-Sub (HD-15) , 1 x audio line-in - RCA x 2 , 1 x composite video input - RCA , 2 x audio line-in - mini-phone stereo 3.5 mm , 1 x S-video input - 4 pin mini-DIN , 1 x serial RS-232C - 9 pin D-Sub (DB-9) (management) , 1 x component video / RGB output - 15 pin HD D-Sub (HD-15) , 1 x HDMI input - 19 pin HDMI Type A , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x network - RJ-45 , 1 x USB downstream - 4 pin USB Type A , 1 x USB upstream - 4 pin USB Type B
Carrying case, USB wireless network adapter, wireless remote control
1 x VGA cable , 1 x composite video cable
Security Features
Security lock slot (cable lock sold separately), password protection
430 Watt
Power Consumption Operational (Standby)
0.4 Watt
Software Included
Wireless Connection 3, EZ Converter FA, ArcSoft MediaConverter 3
40 cm
32.3 cm
10.6 cm
7.1 kg
Limited warranty - parts and labour - 3 years , Limited warranty - lamp - 3 years / 6000 hours
5 °C
35 °C
20 - 80% (non-condensing)
Sound Emission
33 dB
28 dB
