The Green Slim series is the perfect choice for customers looking to upgrade their existing installed projectors. The 2x optical zoom means that a Green Slim model will replace any installed projector seamlessly, without having to change the ceiling brackets. This will help to keep budgets under control and disruption to a minimum. The Green Slim series offers brightness level which is more than enough for even a large, bright classroom or meeting room. This product has HDMI connectivity, allowing users to present HD content for rich and vivid presentations. It's also light and portable, so that it can be moved easily between rooms.
- Casio Green Slim XJ-A252-UJ - DLP projector - portable - white
- DLP projector - 720p
- White
- Built-in Devices
- Speaker
- Brightness
- 3000 ANSI lumens
- Contrast Ratio
- 1800:1
- Resolution
- WXGA (1280 x 800)
- Native Aspect Ratio
- 16:10
- Bulb type
- Laser/LED
- Bulb life cycle
- Up to 20000 hour(s)
- Video Input
- RGB, composite video
- Storage Capacity
- 2 GB Flash
- Video Modes
- 480p, 1080p
- Speakers
- Speaker(s) - integrated
- 165 Watt
- 29.7 cm x 21 cm x 4.3 cm
- 2.3 kg
- 5-year warranty
- Built-in Devices
- Speaker
- Enclosure Colour
- White
Projector
- Brightness
- 3000 ANSI lumens
- Contrast Ratio
- 1800:1
- Image Size
- 38.1 cm - 762 cm
- Throw Ratio
- 1.15 - 2.3:1
- Resolution
- WXGA - WXGA (1280 x 800)
- 16:10
- Bulb type
- Laser/LED
- Bulb life cycle
- Controls & Adjustments
- Keystone correction
- Mercury-free illumination technology, Quick-Start
Lens
- Focus Type
- Powered
- Zoom Factor
- 2x
- Keystone Correction Direction
- Vertical
- Vertical Keystone Correction
- -30 / +30
Video Input
- Analogue video Signal
- Video Interfaces
- VGA, HDMI, composite video
- Video Modes
- 480p, 1080p
Media Player
- Storage Capacity
- 2 GB Flash
Speakers
- Integrated
- Sound Output Mode
- Mono
- Output Power / Channel
- 1 Watt
- Speakers
- 1 x mixed channel
- 1 x VGA / component video input - 15 pin HD D-Sub (HD-15) , 1 x HDMI input - 19 pin HDMI Type A , 1 x composite video input - RCA , 1 x USB - 4 pin USB Type A , 2 x USB - 5 pin Micro-USB Type B
- Included Accessories
- Carrying case, wireless remote control
- Cables Included
- 1 x VGA cable
- Power Source
- AC
- 165 Watt
- Power Consumption Stand by
- 0.23 Watt
- 29.7 cm
- 21 cm
- 4.3 cm
- 2.3 kg
- Limited warranty - 5 years
- Sound Emission (Economic Mode)
- 35 dB
