PC-free models offer convenience and facilitate fluent presentations by allowing presentations to be accessed via USB drives. Load your PowerPoint presentations onto a thumb drive, plug it into a USB compatible model, and simplify presentations. Starting off the presentation in an organized and professional manner will set the tone for the remainder of it or organization and professional appearance is essential for executing effective presentations. Leave your at laptop home and make your presentation from your mobile device. Presentations and teaching materials can thus be prepared on a computer and then presented from your mobile device whenever desired.
Hybrid light engine
By combining a laser, a fluorescent element and an LED Casio has created an original mercury-free hybrid light source capable of generating high brightness. Casio has achieved high brightness output of green light, which until now, has been considered difficult with conventional semiconductor light sources, by efficiently converting blue laser light into green light using a fluorescent element. -
Mercury free light source
It provides 10x longer light source life than Casio mercury lamp while being more economical based on lamp replacement. The Slim projector features quick startup and shutdown. The projector reaches its maximum brightness in a minimum of 8 seconds and requires no cooling down period - an advantage for keeping presentations focused and smooth. -
Superior color, high brightness
The Slim projector delivers a 50-percent increase in color spectrum for high impact presentations due to improvements in LED and laser technology. Superior color reproduction enhances color purity allowing visual effects to appear brighter and offering powerful images that conventional projectors cannot match. -
Cost effective
Compared with conventional high-brightness projectors employing mercury lamps, Slim technology cuts costs as well as the time and effort involved in lamp exchange while maintain clear, high-quality images over an extended period. -
2x optical zoom
Whether you are in a small office or a large boardroom the 2x power zoom lens gives you the flexibility to easily position the projector. -
Automatic brightness adjustment
The automatic brightness adjustment, which adjusts lumen output based on the level of ambient light in the room, saves power, which saves money (and saves you from eye strain as well). -
HDMI
A built-in HDMI (High Definition Multimedia Interface) input provides a direct digital input and allows connectivity with many Widescreen Notebooks now shipping with HDMI outputs. Compatible with HD video formats, HD video sources including Blu-ray players, cable converter boxes and gaming systems can be connected to the Slim projector.
- Casio Slim XJ-A147 - DLP projector - portable - white
- DLP projector - 720p
- White
- Built-in Devices
- Speaker
- Brightness
- 2500 ANSI lumens
- Contrast Ratio
- 1800:1
- Resolution
- WXGA (1280 x 800)
- Native Aspect Ratio
- 16:10
- Bulb type
- Laser/LED
- Bulb life cycle
- Up to 20000 hour(s)
- Video Input
- RGB, composite video
- Storage Capacity
- 2 GB Flash
- Video Modes
- 480p, 1080p
- Speakers
- Speaker(s) - integrated
- 165 Watt
- 29.7 cm x 21 cm x 4.3 cm
- 2.3 kg
- 5-year warranty
- Built-in Devices
- Speaker
- Enclosure Colour
- White
Projector
- Brightness
- 2500 ANSI lumens
- Contrast Ratio
- 1800:1
- Image Size
- 38.1 cm - 762 cm
- Throw Ratio
- 1.15 - 2.3:1
- Resolution
- WXGA - WXGA (1280 x 800)
- 16:10
- Bulb type
- Laser/LED
- Bulb life cycle
- Controls & Adjustments
- Keystone correction
- Mercury-free illumination technology, Quick-Start
Lens
- Focus Type
- Powered
- Zoom Factor
- 2x
- Keystone Correction Direction
- Vertical
- Vertical Keystone Correction
- -30 / +30
Video Input
- Analogue video Signal
- Video Interfaces
- VGA, HDMI, composite video
- Video Modes
- 480p, 1080p
Media Player
- Storage Capacity
- 2 GB Flash
Speakers
- Integrated
- Sound Output Mode
- Mono
- Output Power / Channel
- 1 Watt
- Speakers
- 1 x mixed channel
- 1 x VGA / component video input - 15 pin HD D-Sub (HD-15) , 1 x HDMI input - 19 pin HDMI Type A , 1 x composite video input - RCA , 1 x USB - 4 pin USB Type A , 2 x USB - 5 pin Micro-USB Type B
- Included Accessories
- Carrying case, wireless remote control
- Cables Included
- 1 x VGA cable
- Power Source
- AC
- 165 Watt
- Power Consumption Stand by
- 0.23 Watt
- 29.7 cm
- 21 cm
- 4.3 cm
- 2.3 kg
- Limited warranty - 5 years
