2-1 Virtual-Surround-Systems
Increasing picture resolution, decreasing sound quality: Anyone who buys a flat screen TV today usually needs an additional external sound solution. Here the combination of stereo system and home cinema system is becoming more and more popular.
Powerful 2-1 virtual surround systems combine numerous connection options with outstanding film and HiFi sound.
Advantages
- 2-1 virtual surround sound
- Clear improvement on TV sound
- HiFi stereo sound
- Easy connection
- Wide variety of designs and equipment
Simple to use
The TV companions (DM 100, DM 75, DM 55, DM 9, DM 900) can be controlled via their own remote controls or the television remote. All of the system's remote control functions can be programmed to the television remote control codes in just a few steps. That means that only one remote control is required for both devices.
Setup presets
For placement that is flexible in terms of space and that offers optimal sound, the TV companions (DM 100, DM 75, DM 55, DM 9, DM 900) are furnished with three sound presets. These adjust the sound according to the selected setup location.
Discreet technologies
The LipSync function balances out the technical delays in the transmission of the picture and sound automatically and there by ensures optimal film viewing pleasure.
Bluetooth®
The Bluetooth® capable loudspeakers enable music to be transferred simply and via a wireless connection from your Smartphone or laptop at optimal quality.
Glass surface
Inspired by the world of exclusive furniture and fitted with an elegant glass surface, the new DM systems (DM 100, DM 75, DM 55) have an elegant, contemporary look and will form an eye-catching feature in any living room.
Solid bass foundation
Depending on the system, a powerful active subwoofer is integrated in the DM system or can be set up unobtrusively in the room as external subwoofer with its own cabinet. With their wireless subwoofers and up to four integrated woofers, the compact systems for TVs ensure a solid bass foundation.
- Canton Digital Movie DM 55 - sound stand - for home theatre - wireless
- Product Type
- Sound stand - for home theatre
- Enclosure Design
- Bass reflex
- Speaker Type
- 3-way - active
- Continuous Power
- 200 Watt
- Frequency Response
- 40 - 23000 Hz
- Amplifier
- Integrated
- Bluetooth
- Speaker Details
- Sound stand - stereo x 2 - active , Sound stand - subwoofer - active
- Black lacquer, black glass
- Built-in Decoders
- Dolby Digital, DTS TruSurround
- Sound Effects
- 2.1 virtual surround sound
- Power
- AC 120/230 V (50/60 Hz)
- 54.5 cm x 30 cm x 6.8 cm
- 5.3 kg
- 2-year warranty
- Product Type
- Enclosure Colour
- Enclosure Design
- Bass reflex
- Enclosure Material
- Glass, high-density fibreboard (HDF)
- Design Features
- Maximum load 40kg
Speaker System
- Speaker Type
- 3-way - active
- Continuous Power
- 200 Watt
- 40 - 23000 Hz
- Crossover Frequency
- 3000Hz, 170Hz
- Amplifier
- Integrated
- Sound Effects
- Bluetooth 3.0
- Bluetooth Profiles
- Advanced Audio Distribution Profile (A2DP)
- Bluetooth Audio Codec
- aptX
- Transmission Range
- 10 m
- Recommended Placing
- Under-the-TV
- Built-in Decoders
Speaker System Details
- Speaker Details
- Driver Details
- Sound stand: 2 x woofer driver - 4" , Sound stand: 2 x mid-range driver - 2" , Sound stand: 2 x tweeter driver - 0.75" - fabric
- Connector Type
- Audio line-in (RCA x 2) , SPDIF input (TOS Link) , SPDIF input (RCA) , Subwoofer output (RCA) , Service
- Included Accessories
- Audio cable, remote control, power cable, audio (digital) cable, audio (optical) cable
- Power Source
- Integrated power supply
- Voltage Required
- 150 Watt
- 54.5 cm
- 30 cm
- 6.8 cm
- 5.3 kg
- Limited warranty - 2 years
