Canon Zoemini S2 Pocket Size 2-in-1 - Pearl White
Quicklinx: GYV9WS00 Mfr#: 4519C007
Colours:
  • microSD Card
Take a selfie with the mirror and ring-light, and check your pose with a live view from the Canon Mini Print app. Out of paper? Save your faves for printing later to the Micro SD card.
  • Mini moments, big stories
    Snap selfies with the mirror and ring-light, and check your pose with a live view via the Canon Mini Print app. With a battery life of up to 25 photos and a Micro SD card slot for when you run low on paper, it's easy to make memories on the go.
  • Shoot, edit, share
    Put power in your palm with this 2 in 1 mini photo printer camera.
  • Cool combo
    Snap and print from one device. With an 8MP camera, Zink tech and the ability to save photos to a Micro SD card for later, it's the ideal partner for improve photo-ops.
  • On-point photos
    Create slick snaps with a mirror and ring-light and add flair with the Effects and Frames buttons - simply set your faves via the Canon Mini Print app.
  • Smart shoots
    Use Bluetooth and the Canon Mini Print app to print from your smartphone, check the live view and add cool customization, including advanced collages.
  • Stick and style
    Load up with up to 10 sheets of sticky-backed Zink Photo Paper and print, peel and stick your favorite shots onto all your stuff, from the phone to the fridge.
Canon Zoemini S2 - digital camera
Digital camera - compact with instant photo printer
Memory Card Slot
microSD card
Printing Technology
ZINK
Printing Resolution
314 x 600 dpi
Wireless Interface
Bluetooth, NFC
Sensor Resolution
8.0 Megapixel
Focus Adjustment
Focus free
Min Focus Distance
30 cm
Viewfinder
Optical - real-image
Supported Battery
Li-Polymer rechargeable battery - 700 mAh (included)
USB 2.0
Pearl white
12.1 cm x 2.15 cm x 8.03 cm
188 g
Built-in Light
LED ring light
Enclosure Colour
Pearl white
Sensor Resolution
8.0 Megapixel
ISO (Max)
1600
Image Recording Format
JPEG, GIF, HEIC, PNG
USB 2.0, Bluetooth 5.0, NFC (Near Field Communication)
Connectivity Features
Remote control via mobile devices, wireless image printing, remote live view
Exposure & White Balance
Light Sensitivity
ISO auto (100-1600)
Exposure Modes
Automatic
White Balance
Automatic
Lens System
Focus Adjustment
Focus free
Min Focus Distance
30 cm
Printer
Printing Technology
ZINK
Printing Resolution
314 x 600 dpi
Media Size
50 x 76 mm
Max Media Capacity
10 sheets
Borderless printing
Additional Features
Additional Features
Auto power save, integrated selfie mirror, USB charging
Viewfinder
Viewfinder Type
Connector Type
USB 2.0 (5 pin Micro-USB Type B)
Wrist strap, micro-USB cable, 10 sheets Canon ZINK Photo Paper
Battery Type
Lithium polymer - integrated
Details
Battery Life Details
Photo printing - 25 shots
Memory / Storage
Memory Card Slot
microSD card
Supported Memory Cards
microSD Card, microSDHC Card, microSDXC Card
Memory Card Included
No
Memory Card Max Supported Size
256 GB
12.1 cm
2.15 cm
8.03 cm
188 g
5 °C
0 - 70%
