Canon XF100 FHD CFx2 Professional Camcorder
Quicklinx: 8QKCWS00 Mfr#: 4889B006AA
Compact in size, light weight and fully featured, the Canon XF100 Professional Camcorder can be tailored to fit a wide range of individual needs.
The XF100 utilizes Canon's XF codec - a file-based MPEG-2 compression with an MXF file wrapper that ensures the widest compatibility with existing industry infrastructure, metadata and non-linear editing (NLE) systems. The codec's 4:2:2 color sampling provides ultra-fine transitions in tone and color for maintaining the highest image quality needed for advanced post production processing.
  • MPEG-2 4:2:2 50Mbps codec (Canon XF codec)
    MPEG-2 compression is both highly reliable and versatile. Developed by the Moving Pictures Expert Group (MPEG), it is one of the most widely used compression schemes in the industry for camera acquisition, over the air broadcast, cable and satellite TV. Canon's adaptation of MPEG-2 for the XF100 Professional Camcorder, named the Canon XF codec, ensures the widest compatibility with existing industry infrastructure and non-linear editing (NLE) systems. As well, by using an MXF file wrapper, video and audio can be wrapped in a single file along with important metadata.
  • Record to affordable Compact Flash cards
    Unlike other camcorders which use proprietary memory systems, the XF100 Professional Camcorder records to cost-effective Compact Flash (CF) cards. The camcorder features two CF card slots and offers versatile recording functions.
  • Major NLE software compatibility
    Canon's XF codec is supported by the industry's leading manufacturers: Adobe, Apple, Avid and Grass Valley. This ensures the widest compatibility with existing infrastructure and non-linear editing (NLE) software.
  • Genuine Canon 10x HD video lens
    Canon's optical expertise is clearly seen in the XF100's Genuine Canon 10x HD video lens. It delivers flexibility in image capture with a zoom range of 30.4-304mm (35mm equivalent).
  • Canon native 1920 x 1080 CMOS image sensor
    The XF100 Professional Camcorder incorporates a native 1/3-inch, 1920 x 1080 CMOS image sensor, delivering superb Full HD video recording with minimal noise. The high sensitivity and wide dynamic range of this sensor are what demanding users expect from Canon. Slow and fast motion shooting is supported for greater flexibility in creative choice and its compactness contributes greatly to the small, super handy size of the XF100 and its outstanding usability in the field.
  • Multiple recording bit rates, resolutions, and variable frame rates
    Multiple recording modes, resolutions and frame rates make the XF100 Professional Camcorder creatively flexible and able to work in virtually any production environment. From the highest quality 50Mbps Full HD to the HDV compatible 25Mbps, users will find the camcorder capable of taking on any job.
Canon XF100 - camcorder - storage: flash card
Camcorder - 1080p - widescreen
Media Type
Flash card
Memory Card Slot
CompactFlash Card, SD card
Image Processor
DIGIC DV III
Sensor Resolution
2.37 MP
Effective Sensor Resolution
Video: 2.07 MP - Photo: 2.07 MP
Lens System
Zoom lens - 10x zoom - 4.25 - 42.5 mm - f/1.8-2.8
Focus Adjustment
Automatic, manual
Min Focus Distance
60 cm
Digital Zoom
6x
Image Stabiliser
Optical
Viewfinder
Built-in - 0.24" - colour - electronic - 16:9
Display
LCD display - 3.5"
Supported Battery
1 x Li-ion rechargeable battery (included)
Composite video/audio, HDMI, USB 2.0
13.9 cm x 26.8 cm x 19.1 cm
1.02 kg
Camcorder - 1080p
Camcorder Type
Professional
Camcorder Sensor Resolution
2.37 MP
Sensor Qty
1 CMOS
Effective Video Resolution
2.07 MP
Effective Photo Resolution
2.07 MP
Widescreen Video Capture
Camcorder Media Type
Flash card
Optical Sensor Type
CMOS
Optical Sensor Size
1/3"
Optical Zoom
10x
Digital Zoom
6x
Image Processor
DIGIC DV III
Image Stabiliser
Optical
Built-in Optical Image Stabiliser
Face Detection
SMPTE Colour Bars, selectable frame rates, SMPTE Time Code, zebra pattern, waveform monitor
Auto Focus
TTL contrast detection
Digital Video Format
MPEG-2
Image Recording Format
JPEG
Audio Signal Format
PCM
Exposure & White Balance
Min Illumination
0.7 lux
Exposure Modes
Programme, automatic, manual
White Balance
Custom, automatic, presets
White Balance Presets
Tungsten light, daylight, 2000K - 15000K (100K steps)
Max Shutter Speed
1/2000 sec
Min Shutter Speed
1/18 sec
Gain Selection
+12 dB, +18 dB, +3 dB, +6 dB, 0 dB, -3 dB, + 9 dB, +15 dB, +24 dB, +21 dB, +33 dB
Lens System
Focal Length Equivalent to 35mm Camera
30.4 - 304mm
Focus Adjustment
Automatic, manual
Min Focus Distance
60 cm
Macro Focus Range
2cm
Zoom Adjustment
Motorised drive
Lens Construction
10 groups / 12 elements
Filter Size
58 mm
Built-in neutral density filter
Additional Features
Low Lux / Night Mode
Additional Features
Digital noise reduction, interval shooting mode, takes photos while film recording, Pre-Rec function, face detection, 25p Cinema Mode
Viewfinder
Viewfinder Type
Built-in - electronic
Viewfinder Colour Support
Viewfinder Diagonal Size
0.24"
Viewfinder Resolution
260,000 pixels
Optical Viewfinder Field Coverage
100%
Optical Viewfinder Dioptric Correction Range
-5 to +2
Image Aspect Ratio
16:9
Tilting
Display
3.5" LCD display
Display Format
920,000 pixels
Display Form Factor
Rotating
Microphone
Microphone Operation Mode
Stereo
Microphone Features
Sensitivity control
Connector Type
Headphones , Audio input , USB 2.0 , Composite video/audio output , Component video output , HDMI , DC power input , Control-L (LANC)
Lens hood, camcorder shoulder strap, lens cap, microphone holder, component video cable, IR remote control, power adapter with battery charger
Battery Type
Lithium Ion - manufacturer-specific
Details
Memory / Storage
Memory Card Slot
Supported Memory Cards
CompactFlash
Image Storage
JPEG 1920 x 1280 , JPEG 1280 x 720
13.9 cm
26.8 cm
19.1 cm
1.02 kg
-5 °C
45 °C
