Canon XEEDSX80 SXGA+ Projector
Quicklinx: 6LL4WS00 Mfr#: 4232B006AA
  • High-Definition Multimedia Interface (HDMI)
With SXGA+ resolution and 3000 lumens, the XEED SX80 Mark II produces crystal-clear images. Superb connectivity enables projection from almost any source, including DVI, HDMI and even USB flash drives.
  • Native SXGA+ resolution
    With native SXGA+ resolution (1400 x 1050 pixels), the XEED SX80 Mark II reproduces images with amazing clarity and sufficient levels of detail even for specialist applications. Canon LCOS technology avoids common projection image drawbacks, reproducing detailed images without the unwanted "lattice" or "rainbow" effects.
  • Exceptional brightness and contrast
    With a generous 3000 lumens brightness and 900:1 contrast ratio, the XEED SX80 Mark II delivers clear, well defined images. Canon's AISYS optical system maximizes the performance of the highly efficient AC projector lamp, for powerful projection. Displaying deep blacks and vivid colors, every subtle gradation is reproduced with clarity and precision.
  • Easy placement
    The SX80 Mark II is fitted with a Canon 1.5x powered zoom projection lens, specially designed to combat distortion and deliver perfect image geometry. In addition, the 10:0 lens offset makes installation exceptionally easy.
  • PHOTO image mode
    The SX80 Mark II features a 'Photo' image mode, specially designed for the optimum reproduction of sRGB photographic images. By taking into account the color tone and brightness of the ambient light, photos can be reproduced with superb color accuracy, regardless of variations in lighting conditions.
  • Fully automatic set-up
    At the touch of a button, the projector automatically configures four key settings: Focus, Keystone Correction, Input Selection and Screen Color Correction.
  • PC-free presentations
    The XEED SX80 Mark II utilizes USB technology, for direct projection of image files from USB flash drives. Photographs, slides and other images in JPEG format can be projected directly from the flash drive. In addition, direct image display is possible from PictBridge-compatible digital cameras.
  • Comprehensive Connectivity
    The SX80 Mark II is equipped with DVI and HDMI terminals, with full HDCP support. In addition, an on-board RJ-45 port is provided, for direct connection to a network. Control and monitoring is then possible, through integration with industry-standard AV control systems.
  • Quiet operation
    Running at levels of just 31dBA in Quiet Mode, the projector won't distract your audience with fan noise. Quiet Mode also extends lamp lifetime - up to a maximum of 3000 hours.
  • Convenient design
    The sleek, gloss white bodyshell of the XEED SX80 Mark II blends perfectly into any office or boardroom.
Canon XEED SX80 Mark II - LCOS projector
LCOS projector
Built-in Devices
Speaker
Ethernet, Fast Ethernet
Brightness
3000 lumens
Contrast Ratio
900:1
Resolution
SXGA+ (1400 x 1050)
Native Aspect Ratio
4:3
Bulb type
NSHA 230 Watt
Video Input
RGB, S-Video, composite video, component video (NTSC, SECAM, PAL, PAL-N, PAL-M, NTSC 4.43)
Digital Video Standard
Digital Visual Interface (DVI), High-Definition Multimedia Interface (HDMI)
Video Modes
480p, 720p, 1080i, 1080p, 480i, 1035i, 576i, 576p
Video Output
RGB
Speakers
Speaker(s) - integrated
330 Watt
33.2 cm x 34 cm x 12.1 cm
5.2 kg
3-year warranty
LCOS projector
Built-in Devices
Speaker
Ethernet
Projector
Brightness
3000 lumens
Brightness (Reduced)
2400 lumens
Contrast Ratio
900:1
Image Size
102 cm - 762 cm
Projection Distance
1.2 m - 9.1 m
Throw Ratio
1.48 - 2.18:1
Uniformity
88 %
Digital Zoom Factor
12x
Resolution
SXGA+ - SXGA+ (1400 x 1050)
Native Aspect Ratio
4:3
Video Bandwidth
170 MHz
Display Format
1,470,000 pixels
Max Sync Rate (V x H)
85 Hz x 75 kHz
Bulb type
NSHA 230 Watt
Controls & Adjustments
Gamma correction, tilt
sRGB colour profile, Deep Color, PictBridge
Lens
Focus Type
Powered
Lens Aperture
F/1.95-2.6
Zoom Type
Powered
Zoom Factor
1.5x
Keystone Correction Type
Digital
Keystone Correction Direction
Vertical
Vertical Keystone Correction
-20 / +20
Video Input
TV System
Analogue video Signal
Video Interfaces
VGA, composite video, S-Video, DVI
Video Modes
Video Output
Analogue Video Signal
RGB
Speakers
Integrated
Sound Output Mode
Mono
Output Power / Channel
1 Watt
Speakers
1 x mixed channel
Input Device
External
1 x DVI-I input - 24+5 pin combined DVI , 1 x component video / RGB input - 15 pin HD D-Sub (HD-15) , 1 x composite video input - RCA , 1 x S-video input - 4 pin mini-DIN , 1 x component video / RGB input - BNC x 5 , 1 x network - RJ-45 , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x remote control - 9 pin D-Sub (DB-9)
Carrying case, lens cover, wireless remote control
1 x DVI-VGA cable , 1 x component video cable
330 Watt
Power Consumption Operational (Standby)
15 Watt
33.2 cm
34 cm
12.1 cm
5.2 kg
Limited warranty - 3 years
5 °C
35 °C
5 - 90%
Sound Emission
35 dB
31 dB
