Canon Telephoto Lens - 85 mm - F/1.8 - EF
Quicklinx: 9V3QWS00 Mfr#: 2519A012AA
A short telephoto focal length, combined with a large maximum aperture and fast autofocus speed, make the EF 85 mm f/1.8 USM an ideal optic for any photographer shooting portraiture.
The EF 85 mm f/1.8 USM produces images that are sharp and clear at all apertures. A virtually circular aperture diaphragm gives out-of-focus regions a softer, more even feel, and lets in-focus subjects stand out against a blurred background. The lens features a non-rotating front element during focusing, enabling specialist filters to be used.
  • A practical and portability telephoto lens
  • Large f/1.8 aperture
    A large maximum aperture of f/1.8 lets photographers shoot hand-held in difficult, low-light conditions, as well as restrict depth-of-field for creative effects.
  • Compressed perspective in portraiture
    The short telephoto focal length of the lens slightly compresses perspective, reducing the size of prominent facial features for a flattering result.
  • Ultrasonic focusing
    A ring-type ultrasonic motor drives autofocus extremely quickly, and in near silence. Excellent holding torque ensures the point of focus is reached accurately, without overshooting. Furthermore, full-time manual override is available, making it possible to adjust focus without leaving AF mode.
  • Super Spectra coating
    Super Spectra coatings ensure accurate color balance and enhance contrast. They also reduce flare and ghosting - a common problem caused by light bouncing off a camera's sensor.
  • Integration with E-TTL II flash metering
    The lens passes distance information back to a compatible EOS camera's E-TTL II flash system to ensure optimal flash metering.
Canon EF telephoto lens - 85 mm
Lens System
Telephoto lens
Intended For
Digital SLR, full-frame digital SLR
Mounting Type
Canon EF
Lens Aperture
F/1.8
Focal Length
85 mm
Min Focus Distance
85 cm
Focus Adjustment
Automatic, manual
Lens Construction
7 groups / 9 elements
Special Functions
Tele
Filter Size
58 mm
Length
7.2 cm
425 g
Length
7.2 cm
Diameter
7.5 cm
425 g
Lens System
Telephoto lens
Special Functions
Tele
Intended For
Focal Length
85 mm
Lens Aperture
F/1.8
Minimum Aperture
F/22
Magnification
0.13
Min Focus Distance
85 cm
Focus Adjustment
Automatic, manual
Max View Angle
28.5 degree(s)
Lens Construction
Filter Size
58 mm
Diaphragm Blades
8
Mounting Type
Canon EF
Internal focusing system, Ultrasonic Motor (USM), full-time manual focusing, rear focusing system
Dust cap, lens cap
