The TC-80N3 Timer Remote Controller is a remote switch with a 2.6ft cord and a self-timer, interval timer, long-exposure timer, and exposure-count setting feature. The timer can be set anywhere from 1 second to 99 hours. A new dial enables you to easily enter the numeric settings with a single thumb. The LCD panel can also be illuminated. It has the new N-3 type connector, which locks with a simple push. The rear of the Controller has a slot to store the camera's remote control socket cap.
Efficient control
The Canon TC 80N3 features a cable remote control technology, offering users precise and immediate command over their photography sessions without the need for direct contact with the camera. This functionality is ideal for reducing camera shake and for situations where the photographer needs to maintain a distance, such as wildlife photography or complex studio setups. -
Versatile compatibility
Designed to seamlessly integrate with a wide range of Canon cameras, this remote control extends its utility across various models, ensuring that photographers can enjoy enhanced control and flexibility, regardless of the specific Canon camera they are using.
- Canon TC-80N3 camera remote control
- Camera remote control
- 4 cm x 1.4 cm x 2 cm
- 85 g
- Localisation
- English
- Connectivity Technology
- Cable
- Supported Device Qty
- 1
- Supported Devices
- Digital photo camera, photo camera
- Display
- LCD
- Battery
- 1 x standard - CR2032 lithium
- Designed For
- EOS 1, 10D, 1D, 1Ds, 1N, 1V, 2000D, 200D, 20D, 20Da, 250D, 3, 30D, 40D, 50D, 5D, 5DS, 6D, 77D, 7D, 850D, 9000D, 90D, D30, D60, Kiss X10, Kiss X10i, Kiss X9, Kiss X90, M6, R, Rebel SL2, Rebel SL3, Rebel T7, Rebel T7+, Rebel T8i; PowerShot G1
- 4 cm
- 1.4 cm
- 2 cm
- 85 g
- Localisation
- English
- Cable
- 1
- Supported Devices
- Jog dial, shutter-release lock
Display
- Display
- LCD
- Connector Type
- 1 x remote control
- Cables Included
- 1 x remote control cable - integrated - 80 cm
- Included Accessories
- CR2032 battery
- Battery
- Included Qty
- 1
- Run Time (Up To)
- 3 years
- Designed For
- Canon EOS 1, 10D, 1D, 1D C, 1D Mark II, 1D Mark II N, 1D Mark III, 1D Mark IV, 1D X, 1Ds, 1Ds Mark II, 1Ds Mark II N, 1Ds Mark III, 1N, 1N DP, 1N HS, 1N RS, 1V, 1V HS, 1V HS HUS, 1V HUS, 2000D, 200D, 20D, 20Da, 250D, 3, 3 HUS, 30D, 40D, 50D, 5D, 5D Mark II, 5D Mark III, 5D Mark IV, 5DS, 5DS R, 6D, 6D (N), 6D Mark II, 77D, 7D, 7D Mark II, 850D, 9000D, 90D, D30, D60, Kiss X10, Kiss X10i, Kiss X9, Kiss X90, M6, R, Rebel SL2, Rebel SL3, Rebel T7, Rebel T7+, Rebel T8i , Canon PowerShot G1 X Mark III
