Canon SELPHY CP910 Compact Photo Printer - White
Quicklinx: 9V37WS00 Mfr#: 8427B012AA
Canon SELPHY CP910
Compact and connected - The simple solution for printing from smartphones and cameras.
The compact photo printer for lab-quality prints anywhere. With Wi-Fi and AirPrint™ support, it is ideal for wirelessly printing from smartphones and digital cameras.
Benefits
  • Ultra-portable photo printer that's perfect for printing anywhere
  • Wi-Fi with AirPrint™ support for easy printing from smartphones and compatible cameras
  • Produce memories that will last with vibrant, durable lab-quality prints
  • Conveniently print photos with a glossy or semi-gloss finish without changing photo paper
  • Simple, straightforward on-screen guidance makes printing easy for all the family
  • Great flexibility with direct printing from memory cards and USB sticks
  • Enjoy peace of mind with defined cost per print
  • Large tilting LCD for easy operation and convenient viewing
  • Extensive ID photo functions with Face Frame Guide and a wide range of accepted sizes
  • Auto Image Optimize intelligently corrects images for superb results
Ultra-compact, portable photo printer
The SELPHY CP910 photo printer fits perfectly anywhere in your home, and it's portable enough to take to parties and family events.
Enhanced Wi-Fi connectivity
Wi-Fi support lets you print quickly and easily from compatible cameras and PCs without a cable.
See it, snap it, print it
In-built wireless access point lets you connect and print directly from your smartphone. For ultimate ease, AirPrint™ support lets you print from compatible Apple devices without installing any software.
Lab-quality printing at home
Anyone can print professional quality, long-lasting photos in less than 1 minute. Dye sublimation technology provides superb depth and colour gradation without the wait.
Memories that last
A special overcoat protects each print against splashes, spills and fading, lasting up to 100 years when stored in an album. You can even apply a semi-gloss finish to further prevent fingerprints and create a similar feel to traditional lab prints without the need to change any consumables.
Simple to use
Anyone can print with the user-friendly design that includes a tilting 6.8 cm (2.7") LCD for easy viewing and intuitive menus with on-screen instructions for simple navigation.
No surprises
Stay in full control of the printing costs with a defined number of prints with every pack of consumables.
Print your way
For quick prints just connect your PictBridge-compatible camera directly to the printer. You can also print from a range of memory cards or from USB flash drives for greater flexibility.
ID Photo Print
Whether for personal or professional use, ID Photo Print with Face Frame Guide lets you create and print ID photos in a wide range of accepted sizes.
Range of print sizes
The printer offers many ways to share your memories including postcard, square or credit card sized prints - all in super-quick time.
Enhance your photos
Auto Image Optimize with Scene and Face Detection ensures superb results. It intelligently corrects image imperfections while reducing unwanted noise, giving your prints extra clarity and richness.
Printing on-the-go
Print on the move indoors or out with the optional rechargeable Battery Pack NB-CP2L (requires CG-CP200 Charger Adapter). A single charge delivers over 36 postcard size prints. Optional Dust Cover DPC-CP100 ensures quality prints even when printing outdoors.
  • Ultra-compact, portable photo printer
  • Enhanced Wi-Fi connectivity
  • Lab-quality printing at home
    Anyone can print professional quality, long-lasting photos in less than 1 minute. Dye sublimation technology provides superb depth and color gradation without the wait.
  • Memories that last
  • Simple to use
  • No surprises
  • Print your way
  • ID photo print
  • Range of print sizes
  • Enhance your photos
    Auto image optimize with scene and face detection ensures superb results. It intelligently corrects image imperfections while reducing unwanted noise, giving your prints extra clarity and richness.
Method
Dye-sublimation thermal transfer printing system
Image Longevity
100 Years Print¹
Print Modes
Easy print (Selection of individual images and number of copies for batch printing), all image print (Selection of all images and number of copies for batch printing), DPOF Image Print, ID Photo Print (Multi-size, Standard, Custom size), cropping
Print Settings
Date, Red-eye correction, Print finish (Glossy, Semi-Gloss (Pattern 1/ Pattern 2)), Bordered, Borderless, Layout (1-up, 2-up, 4-up, 8-up, Index¹, Shuffle), Smooth Skin, My Colors (Off, Vivid, Neutral, Positive Film, Sepia, Black & White), Image optimize, Manual brightness adjustment, Power saving, Exif Print
Direct Printing From a Camera
PictBridge compliant (USB and Wireless LAN)
Direct From a Memory Card
Supported card types: SD, SDHC, SDXC, USB Flash Memory¹, Supported via Adapter²: miniSD, miniSDHC, microSD, microSDHC, microSDXC
Direct From a Camera Phone
Compatitble with smartphones, tablets and portable devices via Wi-Fi (Direct or Infrastructure connection): iOS devices - using Canon Easy-PhotoPrint app & Apple AirPrint. Android devices - using Canon Easy-PhotoPrint app. Windows RT devices - using Canon-Easy-PhotoPrint app
Print From a Computer
Yes, requires standard USB cable or compatible Wi-Fi connection.
Camera
USB type A port on printer, Wi-Fi (PictBridge via WLAN - DPS over IP compatible)
Computer
USB mini-B port on printer, Wi-Fi (IEEE802.11 b/g)
LCD Monitor
6.8 cm (2.7") Colour TFT viewer with multi-language user interface and tilt mechanism
PC
USB connection: Windows 8.1 / 8 / 7 SP1, Wi-Fi connection: Windows 8.1 / 8 / 7 SP1
Macintosh
USB connection: Mac OS X 10.6.8 - 10.9, Wi-Fi connection: Mac OS X 10.6.8 - 10.9
Drivers
Windows / Mac
AC Power Supply
Yes, supplied
Battery Pack
Yes, optional NB-CP2L (Approx. 36 Postcard size prints per full charge. Requires Charge Adapter CG-CP200)¹
Power Consumption
Approx. 4W (standby), approx. 60W (printing)
Operating Environment
5 – 40 °C, 20 – 80% humidity
Dimensions
178.0 x 127.0 x 60.5 mm (printer only without protrusions)
810g (Excluding Ink Cartridge and Paper Cassette)
PRINTING SYSTEM
Method
Maximum Resolution
300 x 300 dpi
Colours
3 colour inks with protective over coating, 256 levels per colour (24 bit colour depth)
MEDIA & CARTRIDGE
Postcard Size
148 x 100 mm - [KP-36IP, KP-72IN, KP-108IN]
Credit Card Size
86 x 54 mm - [KC-36IP]¹
Credit Card Size Stickers
86 x 54 mm - [KC-18IF]¹
Square Stickers
50 x 50 mm - [KC-18IS]¹
Mini Stickers
22.0 x 17.3 mm (x8 stickers on one sheet) - [KC-18IL]¹
Ink Cartridge
Included with media
Image Longevity
100 Years Print¹
MEDIA INPUT
Sheet Feeder
Auto feed from paper cassette
PRINT SPEEDS
Postcard Size
approx. 47 sec¹
Credit Card Size
approx. 27 sec¹
approx. 27 sec¹
Mini Stickers
approx. 27 sec¹
PRINTING
Print Modes
Print Settings
PRINT METHOD
INTERFACE
Camera
Computer
LCD Monitor
SUPPORTED OPERATING SYSTEM
PC
Macintosh
SOFTWARE
Drivers
Windows / Mac
POWER SOURCE
AC Power Supply
Yes, supplied
Battery Pack
Power Consumption
PHYSICAL SPECIFICATIONS
Dimensions
