Stylish and portable, this fast Wi-Fi photo printer is ideal for creating unique prints from compatible smart devices, cameras and more
Superfast, lab-quality prints from smart devices and more
Instantly create superb quality, durable prints from compatible smart devices, cameras and more – wherever you go – with this portable Wi-Fi photo printer. Share precious memories in unique ways with a range of layout and 'shuffle' options.
Smart printing
Enjoy fast wireless prints from smart devices with Canon PRINT app, MopriaTM, Apple AirPrintTM and Wi-Fi Button. Combine images from multiple smartphones with Party Shuffle.
Lasting quality
Vibrant and durable superb-quality prints are ready in less than 1 minute with dye sublimation technology. Auto Image Optimize ensures your photos always look their best.
Create unique images
Create and share unique printed images in super-quick time using a wide range of layout and 'shuffle' options, including photo-booth strips and ID print
Print on the go
Small and neat, this printer is easy to carry for fast, reliable, lab-quality photo printing anywhere you go. Print up to 54 photos with the optional high capacity battery.
Beautiful photo quality
Not only will your photos be instantly dry, but they will also look great for many years and are even water resistant! -
Stylish & compact
The sleek, portable design lets you bring the SELPHY CP1300 with you. -
Convenience built-in
With the tilting LCD screen it's easy to choose, edit and print your favorite photos.
- Canon SELPHY CP1300 - printer - colour - dye sublimation
- Printer Type
- Compact photo printer - dye sublimation - colour
- Form Factor
- Portable
- 860 g
- Max Media Size
- 100 x 148 mm
- Max Media Size (Custom)
- 100 mm x 148 mm
- Max Resolution (Colour)
- 300 x 300 dpi
- Interface
- USB, USB host, Wi-Fi
- AirPrint Enabled
- Preview Screen Size
- 3.2"
- Card Reader
- Media Type
- Photo paper, cards, postcards
- Media Handling
- 18-sheet paper cassette
- Printer Features
- 100 Years Print
- System Requirements
- Apple MacOS, Android, Microsoft Windows 7 SP1, Windows 8, Apple iOS, Windows 8.1, Windows 10
- Enclosure Colour
- Pink
- 18.06 cm x 13.59 cm x 6.33 cm
- 2 Years
- Printer Type
- Enclosure Colour
- Pink
Printer
- Built-in Devices
- Preview screen
- 3.2"
- Connectivity Technology
- Wireless
- Interface
- AirPrint Enabled
- 300 x 300 dpi
- Direct Printing Specifications
- PictBridge, DPOF
- Colour Management Features
- Mopria
- Printer Features
- 100 Years Print
- Media Handling
Card Reader
- Card reader
- Supported Flash Memory Cards
- SD Memory Card, SDHC Memory Card, SDXC Memory Card
Media Handling
- Media Type
- Max Media Size
- 100 x 148 mm
- 100 mm x 148 mm
- Media Sizes
- 86 x 54 mm, 17.3 x 22 mm, 50 x 50 mm, 148 x 100 mm
- Connections
- 1 x USB - 4 pin mini-USB Type B , 1 x USB host - 4 pin USB Type A
- Security Slot Type
- Kensington security slot
- Power Device
- Power adapter - external
- 60 Watt
- Power Consumption Stand by
- 4 Watt
- Software Included
- Drivers & Utilities
- OS Required
- 0 °C
- 40 °C
- 20 - 80%
- 18.06 cm
- 13.59 cm
- 6.33 cm
- 860 g
- 2 Years
