The SELPHY CP1200 wireless compact photo printer is so much fun to use, you'll want to take it everywhere with you - and you can! Thanks to its compact design and multiple ways to print wirelessly, you can print just about anywhere. But there is more to it than that. It's actually fun to print with the SELPHY CP1200. You can print on postcard-size paper, label size and even several little stickers at a time. And before you print you can dress up your photos with fun borders and effects. Do you ever need a picture for an ID or passport? Don't go to the convenience store, just print your favorite picture of yourself. The SELPHY CP1200 has many built-in ID sizes so you can print just the right size for your needs. On top of all this, you can print to the SELPHY CP1200 however you want - wirelessly from your computer, via USB, from a camera or a memory card... the list goes on. With it, it's so convenient, fun and easy to print your favorite photos whenever you want to!
- Canon SELPHY CP1200 - printer - colour - dye sublimation
- Printer Type
- Compact photo printer - dye sublimation - colour
- Form Factor
- Portable
- 860 g
- Max Media Size
- 148 x 100 mm
- Min Media Size (Custom)
- 100 mm x 148 mm
- Max Media Size (Custom)
- 100 mm x 148 mm
- Print Speed
- Up to 0.78 min/page - 148 x 100 mm
- Max Resolution (Colour)
- 300 x 300 dpi
- Interface
- USB, USB host, Wi-Fi
- AirPrint Enabled
- Preview Screen Size
- 2.7"
- Card Reader
- Media Type
- Postcards
- Printer Features
- Borderless printing, smooth skin, 100 Years Print, My Colors, Auto Power Off, Red-Eye Correction
- System Requirements
- Apple MacOS, Android, Microsoft Windows 7 SP1, Windows 8, Apple iOS, Windows 8.1
- Enclosure Colour
- Black
- 18.06 cm x 13.59 cm x 6.33 cm
- Printer Type
- Enclosure Colour
- Black
Printer
- Print Speed
- Built-in Devices
- Preview screen
- 2.7"
- Connectivity Technology
- Wireless
- Interface
- AirPrint Enabled
- 300 x 300 dpi
- Direct Printing Specifications
- PictBridge, DPOF
- Printer Features
Card Reader
- Card reader
- Supported Flash Memory Cards
- SD Memory Card, SDHC Memory Card, SDXC Memory Card
Media Handling
- Media Type
- Postcards
- Max Media Size
- 148 x 100 mm
- 100 mm x 148 mm
- 100 mm x 148 mm
- Media Sizes
- 148 x 100 mm
- Media Feeders
- 1 x automatic
- Connections
- 1 x USB - 4 pin USB Type B , 1 x USB host - 4 pin USB Type A
- Included Accessories
- Paper cassette
- Power Device
- Power adapter - external
- 60 Watt
- Power Consumption Stand by
- 4 Watt
- Software Included
- Drivers & Utilities
- OS Required
- 5 °C
- 40 °C
- 20 - 80%
- 18.06 cm
- 13.59 cm
- 6.33 cm
- 860 g
Ink (1)
Canon KP 36IP Print Cartridge/Paper Kit - 36 sheets | In Stock | £10.42 |
Other bundles (2)
C2G 5m USB 2.0 A/B Cable - Black | In Stock | £5.74 |
C2G 12m USB 2.0 A/A Active Extension Cable | In Stock | £18.86 |
