Canon Scanfront 400 Network Scanner
Quicklinx: D7SHWS00 Mfr#: 1255C003
Type: Document scanner
Form Factor: Desktop
Max Paper Size: 216 x 3048 mm
Interface: USB 2.0, LAN
Compatibility: PC
Hurry, only 2 left in stock!
£1,040.66 ex VAT
£1,248.79 inc VAT
imageFORMULA ScanFront 400 is a powerful high-speed network scanner ideal for shared or decentralized scanning.
  • Dedicated network scanner
    The Canon imageFORMULA ScanFront 400 is a network scanner for streamlining document workflows. The simple interface allows quick and easy scanning to e-mail, network folders, FTP, USB memory, fax, or printers directly from the scanner's bright and responsive 10.1" TFT touchscreen - no additional hardware or software required.
  • Ideal for every business
    Its desk-friendly size, elegant design and quiet operation make it perfect for both back office use and consumer-facing countertops in retail, banking, healthcare and the legal profession. Small businesses can share the device across the office, while large corporations can integrate the scanner into existing infrastructures for both central department scanning and decentralized scanning in branch offices.
  • Wide range of media
    Make light work of scanning all kinds of documents, from A4, A5, and business cards to long document rolls and even plastic cards, passports and A3 documents - ideal for HR departments, hotels and banks. The device automatically detects paper size and adjusts as required.
  • Customization and integration
    The ScanFront 400's OS brings the power and flexibility to integrate with your document workflow. Create and send customized metadata index files with every scan, allowing for easy document classification into back office systems.
Canon imageFORMULA ScanFront 400 - document scanner - desktop - USB 2.0, LAN
Document scanner - desktop
Interface Type
USB 2.0, LAN
Scanning Sensor Type
CMOS / CIS
Light Source
RGB LED array
Additional Functions
Scan to print, scan to USB, scan to FTP, scan to folder, scan to fax
Max Supported Document Size
216 x 3048 mm
Input Type
Grayscale / Color Depth (External)
8-bit (256 grey levels) / 24-bit (16.7 million colours)
Optical Resolution
600 dpi x 600 dpi
Max Document Scan Speed
45 ppm (mono) / 45 ppm (colour)
Max Document Size
216 mm x 3048 mm
Automatic Duplexing
Supported Document Type
Plain paper, business card, embossed card
Document Feeder Type
Automatic
Document Storage Capacity
60 sheets
Duty Cycle
6000 scans per day
30.5 cm x 23 cm x 28.2 cm
4.5 kg
Environmental Standards
ENERGY STAR Qualified
2 Years
Interface Type
USB 2.0, LAN
216 x 3048 mm
Scanner
Input Type
Grayscale Depth (External)
Colour Depth (External)
Optical Resolution
600 dpi x 600 dpi
Automatic Duplexing
CMOS / CIS
Bulb / Light Source Type
RGB LED array
Max Document Scan Speed B/W
45 ppm
Max Document Scan Speed Colour
45 ppm
Duty Cycle
6000 scans per day
Scanner Speed Details
45 ppm - black & white , 45 ppm - colour
Scanner Features
Color Dropout, Ultrasonic Double Feed Detection, Bleed-through reduction, Shadow Removal, Error Diffusion, automatic colour detection, blank page skipping, Text Enhancement, Text Orientation Recognition, Smooth Background, Double Feed Release (DFR), Deskew, Color Enhancement, Long Document Scanning, Folio Mode, 10.1" touch screen TFT display
Scan File Formats
JPEG, PNG, TIFF, PDF
Media Handling
Max Document Size
216 mm x 3048 mm
Automatic
60 sheets
3 x USB 2.0 , LAN
Roller cleaning kit, Exchange Roller Kit
RoHS
ENERGY STAR Certified
Power Consumption Operational (Standby)
40 Watt
Power Consumption Sleep
2 Watt
Software Included
Drivers & Utilities, Canon ScanFront Administration Tool, Web Application Toolkit
30.5 cm
23 cm
28.2 cm
4.5 kg
10 °C
32.5 °C
20 - 80%
Service and Support
2 Years
Interface: USB 2.0
Interface: LAN
Compatibility: PC
Brand: Canon
Price Range Ex VAT: £1000 - £1500
