Canon PowerShot SX730 HS Camera Silver 20.3MP 40x Zoom FHD WiFi
Quicklinx: CXPWWS00 Mfr#: 1792C011AA
Resolution: 20.3Megapixel
Optical Zoom: 40
Colour: Silver
23 in stock
£257.54 ex VAT
£309.04 inc VAT
Marketing description is not available.
  • Powerful 40x optical zoom with zoom framing assist
    Whether the action is happening right in front of you or just out of reach, the 40x optical zoom of the PowerShot SX730 HS has you covered. The camera's advanced stabilization technology helps ensure that images and videos can be captured in outstanding quality with Intelligent IS that chooses the stabilization method that matches the shooting conditions.
  • Sleek, lightweight and pocket-size camera
    The overall size of the PowerShot SX730 HS means you can still fit it in a pocket, ready to capture the action whenever it happens. The large grip on the front and back of the camera, along with the textured surface and slip-resistant shape helps make it feel comfortable in your hand.
  • Built-in wireless capability
    Thanks to built-in Wi-Fi technology and the Canon Camera Connect app, with the PowerShot SX730 HS you can transfer photos and videos to and from compatible devices, upload directly to various web services and more. Built-in NFC technology means the camera can connect directly to compatible devices by simply touching the NFC icon on the camera to the device.
  • 20.3 Megapixel CMOS sensor
    The PowerShot SX730 HS employs a 20.3 Megapixel High-Sensitivity CMOS sensor, which delivers powerful imaging performance and is optimized for use in select compact cameras. Utilizing a sophisticated light-capturing design, it provides high sensitivity for high ISO capture with reduced noise. It's also incredibly fast, capable of rapidly capturing and moving image data to the processor, as well as enabling fast continuous shooting and fast autofocus.
  • DIGIC 6 Image Processor
    The DIGIC 6 Image Processor helps boost image quality in both stills and videos for high resolution with minimal noise when shooting in dark conditions, and Dynamic IS that helps create video virtually free of distortion. The processor also enables high-speed, high-quality continuous still image shooting at up to 5.9 frames per second. Video recording is impressive with Full HD at 60p as well as MP4 recording. The DIGIC 6 Image Processor also powers MF Peaking, which displays edges of subjects in color to make manual focusing easier and helps provide a precise focusing tool at your disposal.
  • 3.0-inch tilt-type (180° up) LCD
    Get a unique perspective on the world with the tilt-type, high-resolution screen of the PowerShot SX730 HS. Boasting approx. 922,000 dots, the screen can be tilted upwards 180° to face all the way to the front and ensure you're in the center of the perfect selfie. Alternatively, you can push the screen down 90° to get a lower angle view of the world.
  • 1080p Full HD video at 60p
    The PowerShot SX730 HS is designed to make beautiful, creative video capture easy and fun. Image quality is luminous and lifelike in 1080p Full HD, with selectable frame rates of 60p, 30p and 24p to match various situations. MP4 format, ideal for sharing and playing on mobile devices, is also available. Dynamic IS offers 5-axis image stabilization that can correct camera shake that can occur when you shoot while running or walking backward.
  • Self Portrait mode
    Self Portrait mode can help you to snap your ideal selfie with you looking incredible. This mode can be easily accessed via the menu, or automatically activated when you tilt the screen to face forwards. When shooting you can make adjustments ranging from smooth skin tones and background blur to brightness and more. Use the customizable self-timer to give you enough time to smile, fix your expression or invite a friend in for the shot. Smooth Skin mode can help perfect your portraits in both Self Portrait mode and other shooting modes so you can look stunning.
Canon PowerShot SX730 HS - digital camera
Digital camera - 1080p - compact
Memory Card Slot
SD card
Image Processor
DIGIC 6
Wireless Interface
Wi-Fi, NFC, Bluetooth
Sensor Resolution
20.3 Megapixel
Max Video Resolution
1920 x 1080
Lens System
Zoom lens - 40x zoom - 4.3 - 172 mm - f/3.3-6.9
Focus Adjustment
Automatic, manual
Min Focus Distance
1 cm
Digital Zoom
4x
Image Stabiliser
Optical (Intelligent IS with 5-axis Advanced Dynamic Mode)
Camera Flash
Pop-up flash
Display
LCD display - 3"
Supported Battery
1 x Canon NB-13L Li-ion rechargeable battery (included)
HDMI, USB 2.0
Silver
11.01 cm x 3.99 cm x 6.38 cm
276 g
Enclosure Colour
Silver
Sensor Resolution
20.3 Megapixel
Optical Sensor Type
CMOS
Total Pixels
21,100,000 pixels
Effective Sensor Resolution
20,300,000 pixels
Optical Sensor Size
1/2.3"
Frame Rate (Max Resolution)
60 fps
ISO (Max)
3200
Optical Zoom
40x
Digital Zoom
4x
Image Processor
DIGIC 6
Image Stabiliser
Built-in Optical Image Stabiliser
Face Detection
Print Standard
Direct print, DPOF support, Exif Print support, PictBridge support
Auto Focus
TTL contrast detection
Auto Focus Points (Zones) Qty
9
AE/AF Control
Face-priority AF, Subject-tracking AF
Face Detection
Face Detection AF/AE/FE/WB, Face Detection Self-timer, Wink Self-timer, Smile Shutter
Digital Video Format
H.264
Image Recording Format
JPEG
1920 x 1080
Auto Focus Features
Focus Peaking function
HDMI, USB 2.0, IEEE 802.11b/g/n, NFC (Near Field Communication), Bluetooth 4.1
Computer Connectivity
Mac, Windows
Connectivity Features
Remote control via mobile devices, remote live view
Exposure & White Balance
Light Sensitivity
ISO 100, ISO 800, ISO 400, ISO 200, ISO 80, ISO 1600, ISO 3200, ISO auto (80-1600)
Exposure Metering
Evaluative, centre-weighted, spot
Exposure Modes
Programme, automatic, manual, aperture-priority, shutter-priority
Shooting Programs
Portrait mode, slow shutter, self-portrait, fireworks, low light, sports mode, super vivid, poster effect, hi-speed burst, smart shutter, fisheye effect, miniature effect, smooth skin, toy camera effect, soft focus, monochrome, creative shot, handheld night scene
Special Effects
Black & White, Sepia, Neutral, Vivid, fisheye, soft focus, monochrome, Lighter Skin Tone, Darker Skin Tone, Vivid Green, vivid blue, Vivid Red, miniature, Positive Film, Toy camera, Posterisation, Super Vivid
White Balance
Custom, automatic, presets
White Balance Presets
Fluorescent, cloudy, tungsten light, daylight, fluorescent light (warm white)
Max Shutter Speed
1/3200 sec
Min Shutter Speed
15 sec
Exposure Compensation
±2 EV range, in 1/3 EV steps
X-sync Speed
1/2000 sec
Lens System
Focal Length Equivalent to 35mm Camera
24 - 960mm
Focus Adjustment
Automatic, manual
Min Focus Distance
1 cm
Macro Focus Range
1-50cm
Zoom Adjustment
Motorised drive
Lens Construction
11 groups / 13 elements
UD glass, built-in lens shield, aspherical lens
Camera Flash
Camera Flash
Pop-up flash
Flash Modes
Fill-in mode, slow synchro, auto mode, flash OFF mode, red-eye reduction
Red-Eye Reduction
Flash +/- compensation
Effective Flash Range
0.5 m - 4 m (wide lens) , 2 m (tele lens)
Additional Features
Continuous Shooting Speed
2.3 frames per second, 4.6 frames per second, 5.9 frames per second
Self-Timer Delay
10 sec, 2sec
Additional Features
Digital image rotation, camera orientation detection, histogram display, AE lock, AF lock, FE lock, in-camera red-eye removal, cropping an image, resizing an image, i-Contrast (Intelligent Contrast Correction) system, digital tele-converter, USB charging, HS System, Zoom Framing Assist, GPS via mobile, Hybrid Auto
Display
3" LCD display
Display Format
922,000 pixels
Display Form Factor
Folding
Display Features
Display brightness control
Microphone
Microphone Operation Mode
Stereo
Connector Type
USB 2.0 (5 pin Micro-USB Type B) , HDMI output (19 pin micro HDMI Type D)
Battery charger, wrist strap
Battery Type
Canon NB-13L Lithium Ion - manufacturer-specific
Details
Battery Life Details
Photo shooting - 250 shots , Photo shooting - 355 shots (ECO mode) , Video recording - 0.83 hours , Playback - 5 hours
Memory / Storage
Memory Card Slot
SD card
Supported Memory Cards
SD Memory Card, SDXC Memory Card, SDHC Memory Card, SDHC UHS-I Memory Card, SDXC UHS-I Memory Card
Image Storage
JPEG 5184 x 3888 , JPEG 5184 x 3456 , JPEG 5184 x 2912 , JPEG 3648 x 2736 , JPEG 3648 x 2432 , JPEG 3648 x 2048 , JPEG 2048 x 1536 , JPEG 2048 x 1368 , JPEG 2592 x 1944 , JPEG 1920 x 1080 , JPEG 640 x 480 , JPEG 640 x 424 , JPEG 640 x 360 , JPEG 3888 x 3888 , JPEG 2736 x 2736 , JPEG 1536 x 1536 , JPEG 480 x 480
Video Capture
H.264 - 1920 x 1080 p - 60 fps , H.264 - 1920 x 1080 p - 30 fps , H.264 - 1280 x 720 p - 30 fps , H.264 - 640 x 480 p - 30 fps
11.01 cm
3.99 cm
6.38 cm
276 g
Weight Details
Camera only: 276 g , Camera with battery and memory card: 300 g
10 - 90%
Optical Zoom: 40
Colour: Silver
Brand: Canon
Price Range Ex VAT: 150 - 300
