Powerful 40x optical zoom with zoom framing assist
Whether the action is happening right in front of you or just out of reach, the 40x optical zoom of the PowerShot SX730 HS has you covered. The camera's advanced stabilization technology helps ensure that images and videos can be captured in outstanding quality with Intelligent IS that chooses the stabilization method that matches the shooting conditions. -
Sleek, lightweight and pocket-size camera
The overall size of the PowerShot SX730 HS means you can still fit it in a pocket, ready to capture the action whenever it happens. The large grip on the front and back of the camera, along with the textured surface and slip-resistant shape helps make it feel comfortable in your hand. -
Built-in wireless capability
Thanks to built-in Wi-Fi technology and the Canon Camera Connect app, with the PowerShot SX730 HS you can transfer photos and videos to and from compatible devices, upload directly to various web services and more. Built-in NFC technology means the camera can connect directly to compatible devices by simply touching the NFC icon on the camera to the device. -
20.3 Megapixel CMOS sensor
The PowerShot SX730 HS employs a 20.3 Megapixel High-Sensitivity CMOS sensor, which delivers powerful imaging performance and is optimized for use in select compact cameras. Utilizing a sophisticated light-capturing design, it provides high sensitivity for high ISO capture with reduced noise. It's also incredibly fast, capable of rapidly capturing and moving image data to the processor, as well as enabling fast continuous shooting and fast autofocus. -
DIGIC 6 Image Processor
The DIGIC 6 Image Processor helps boost image quality in both stills and videos for high resolution with minimal noise when shooting in dark conditions, and Dynamic IS that helps create video virtually free of distortion. The processor also enables high-speed, high-quality continuous still image shooting at up to 5.9 frames per second. Video recording is impressive with Full HD at 60p as well as MP4 recording. The DIGIC 6 Image Processor also powers MF Peaking, which displays edges of subjects in color to make manual focusing easier and helps provide a precise focusing tool at your disposal. -
3.0-inch tilt-type (180° up) LCD
Get a unique perspective on the world with the tilt-type, high-resolution screen of the PowerShot SX730 HS. Boasting approx. 922,000 dots, the screen can be tilted upwards 180° to face all the way to the front and ensure you're in the center of the perfect selfie. Alternatively, you can push the screen down 90° to get a lower angle view of the world. -
1080p Full HD video at 60p
The PowerShot SX730 HS is designed to make beautiful, creative video capture easy and fun. Image quality is luminous and lifelike in 1080p Full HD, with selectable frame rates of 60p, 30p and 24p to match various situations. MP4 format, ideal for sharing and playing on mobile devices, is also available. Dynamic IS offers 5-axis image stabilization that can correct camera shake that can occur when you shoot while running or walking backward. -
Self Portrait mode
Self Portrait mode can help you to snap your ideal selfie with you looking incredible. This mode can be easily accessed via the menu, or automatically activated when you tilt the screen to face forwards. When shooting you can make adjustments ranging from smooth skin tones and background blur to brightness and more. Use the customizable self-timer to give you enough time to smile, fix your expression or invite a friend in for the shot. Smooth Skin mode can help perfect your portraits in both Self Portrait mode and other shooting modes so you can look stunning.
- Canon PowerShot SX730 HS - digital camera
- Product Type
- Digital camera - 1080p - compact
- Memory Card Slot
- SD card
- Image Processor
- DIGIC 6
- Wireless Interface
- Wi-Fi, NFC, Bluetooth
- Sensor Resolution
- 20.3 Megapixel
- Max Video Resolution
- 1920 x 1080
- Lens System
- Zoom lens - 40x zoom - 4.3 - 172 mm - f/3.3-6.9
- Focus Adjustment
- Automatic, manual
- Min Focus Distance
- 1 cm
- Digital Zoom
- 4x
- Image Stabiliser
- Optical (Intelligent IS with 5-axis Advanced Dynamic Mode)
- Camera Flash
- Pop-up flash
- Display
- LCD display - 3"
- Supported Battery
- Canon NB-13L Li-ion rechargeable battery (included)
- Interface
- HDMI, USB 2.0
- Black
- 11.01 cm x 3.99 cm x 6.38 cm
- 276 g
- Product Type
- Enclosure Colour
- Black
- Sensor Resolution
- 20.3 Megapixel
- Optical Sensor Type
- CMOS
- Total Pixels
- 21,100,000 pixels
- Effective Sensor Resolution
- 20,300,000 pixels
- Optical Sensor Size
- 1/2.3"
- Frame Rate (Max Resolution)
- 60 fps
- ISO (Max)
- 3200
- Optical Zoom
- 40x
- Digital Zoom
- 4x
- Image Processor
- DIGIC 6
- Image Stabiliser
- Built-in Optical Image Stabiliser
- Face Detection
- Print Standard
- Direct print, DPOF support, Exif Print support, PictBridge support
- Auto Focus
- TTL contrast detection
- Auto Focus Points (Zones) Qty
- 9
- AE/AF Control
- Face-priority AF, Subject-tracking AF
- Face Detection
- Face Detection AF/AE/FE/WB, Face Detection Self-timer, Wink Self-timer, Smile Shutter
- Digital Video Format
- H.264
- Image Recording Format
- JPEG
- 1920 x 1080
- Auto Focus Features
- Focus Peaking function
- Interface
- HDMI, USB 2.0, IEEE 802.11b/g/n, NFC (Near Field Communication), Bluetooth 4.1
- Computer Connectivity
- Mac, Windows
- Connectivity Features
- Remote control via mobile devices, remote live view
Exposure & White Balance
- Light Sensitivity
- ISO 100, ISO 800, ISO 400, ISO 200, ISO 80, ISO 1600, ISO 3200, ISO auto (80-1600)
- Exposure Metering
- Evaluative, centre-weighted, spot
- Exposure Modes
- Programme, automatic, manual, aperture-priority, shutter-priority
- Shooting Programs
- Portrait mode, slow shutter, self-portrait, fireworks, low light, sports mode, super vivid, poster effect, hi-speed burst, smart shutter, fisheye effect, miniature effect, smooth skin, toy camera effect, soft focus, monochrome, creative shot, handheld night scene
- Special Effects
- Black & White, Sepia, Neutral, Vivid, fisheye, soft focus, monochrome, Lighter Skin Tone, Darker Skin Tone, Vivid Green, vivid blue, Vivid Red, miniature, Positive Film, Toy camera, Posterisation, Super Vivid
- White Balance
- Custom, automatic, presets
- White Balance Presets
- Fluorescent, cloudy, tungsten light, daylight, fluorescent light (warm white)
- Max Shutter Speed
- 1/3200 sec
- Min Shutter Speed
- 15 sec
- Exposure Compensation
- ±2 EV range, in 1/3 EV steps
- X-sync Speed
- 1/2000 sec
Lens System
- Focal Length Equivalent to 35mm Camera
- 24 - 960mm
- Focus Adjustment
- Automatic, manual
- 1 cm
- Macro Focus Range
- 1-50cm
- Zoom Adjustment
- Motorised drive
- Lens Construction
- 11 groups / 13 elements
- UD glass, built-in lens shield, aspherical lens
Camera Flash
- Camera Flash
- Pop-up flash
- Flash Modes
- Fill-in mode, slow synchro, auto mode, flash OFF mode, red-eye reduction
- Red-Eye Reduction
- Flash +/- compensation
- Effective Flash Range
- 0.5 m - 4 m (wide lens) , 2 m (tele lens)
Additional Features
- Continuous Shooting Speed
- 2.3 frames per second, 4.6 frames per second, 5.9 frames per second
- Self-Timer Delay
- 10 sec, 2sec
- Additional Features
- Digital image rotation, camera orientation detection, histogram display, AE lock, AF lock, FE lock, in-camera red-eye removal, cropping an image, resizing an image, i-Contrast (Intelligent Contrast Correction) system, digital tele-converter, USB charging, HS System, Zoom Framing Assist, GPS via mobile, Hybrid Auto
Display
- 3" LCD display
- Display Format
- 922,000 pixels
- Display Form Factor
- Folding
- Display Features
- Display brightness control
Microphone
- Microphone Operation Mode
- Stereo
- Connector Type
- USB 2.0 (5 pin Micro-USB Type B) , HDMI output (19 pin micro HDMI Type D)
- Included Accessories
- Battery charger, wrist strap
- Battery Type
- Canon NB-13L Lithium Ion
- Details
- Battery Life Details
- Photo shooting - 250 shots , Photo shooting - 355 shots (ECO mode) , Video recording - 0.83 hours , Playback - 5 hours
Memory / Storage
- Memory Card Slot
- SD card
- Supported Memory Cards
- SD Memory Card, SDXC Memory Card, SDHC Memory Card, SDHC UHS-I Memory Card, SDXC UHS-I Memory Card
- Memory Card Included
- No
- Image Storage
- JPEG 5184 x 3888 , JPEG 5184 x 3456 , JPEG 5184 x 2912 , JPEG 3648 x 2736 , JPEG 3648 x 2432 , JPEG 3648 x 2048 , JPEG 2048 x 1536 , JPEG 2048 x 1368 , JPEG 2592 x 1944 , JPEG 1920 x 1080 , JPEG 640 x 480 , JPEG 640 x 424 , JPEG 640 x 360 , JPEG 3888 x 3888 , JPEG 2736 x 2736 , JPEG 1536 x 1536 , JPEG 480 x 480
- Video Capture
- H.264 - 1920 x 1080 p - 60 fps , H.264 - 1920 x 1080 p - 30 fps , H.264 - 1280 x 720 p - 30 fps , H.264 - 640 x 480 p - 30 fps
- 11.01 cm
- 3.99 cm
- 6.38 cm
- 276 g
- Weight Details
- Camera only: 276 g , Camera with battery and memory card: 300 g
- 0 °C
- 40 °C
- 10 - 90%
