With its incredible 65x Optical Zoom, image stabilization of up to 5 stops and 4K video recording, the PowerShot SX70 HS camera has you covered. From fun-filled family moments to once-in-a-lifetime travels and adventures, capture everything including faraway sights, ultra-wide vistas and spectacular, frame-filling, close-up macro shots like never before with a PowerShot SX-series camera. A bright and detailed electronic viewfinder combined with intuitive controls enable you to capture incredible moments as the opportunity presents itself.
- Canon PowerShot SX70 HS - digital camera
- Product Type
- Digital camera - 4K - compact
- Memory Card Slot
- SD card
- Image Processor
- DIGIC 8
- Wireless Interface
- Wi-Fi, Bluetooth
- Sensor Resolution
- 20.3 Megapixel
- Max Video Resolution
- 3840 x 2160
- Lens System
- Zoom lens - 65x zoom - 3.8 - 247 mm - f/3.4-6.5
- Focus Adjustment
- Automatic, manual
- Min Focus Distance
- 0 m
- Digital Zoom
- 4x
- Image Stabiliser
- Optical (Intelligent IS with 5-axis Enhanced Dynamic Mode)
- Camera Flash
- Pop-up flash
- Viewfinder
- Electronic - 0.39" - colour - OLED
- Display
- LCD display - 3"
- Supported Battery
- Canon LP-E12 Li-ion rechargeable battery (included)
- Interface
- HDMI, USB 2.0
- 12.7 cm x 11.66 cm x 9.09 cm
- 576 g
- 2-year warranty
- Product Type
- Sensor Resolution
- 20.3 Megapixel
- Optical Sensor Type
- BSI-CMOS
- Total Pixels
- 21,100,000 pixels
- Effective Sensor Resolution
- 20,300,000 pixels
- Optical Sensor Size
- 1/2.3"
- Frame Rate (Max Resolution)
- 30 fps
- ISO (Max)
- 3200
- Optical Zoom
- 65x
- Digital Zoom
- 4x
- Image Processor
- DIGIC 8
- Image Stabiliser
- Built-in Optical Image Stabiliser
- Face Detection
- Print Standard
- Direct print, Exif Print support, PictBridge support
- Auto Focus
- TTL contrast detection
- Auto Focus Points (Zones) Qty
- 9
- AE/AF Control
- Face-priority AF, Subject-tracking AF
- Digital Video Format
- H.264
- Image Recording Format
- JPEG, RAW, RAW + JPEG
- 3840 x 2160
- Auto Focus Features
- Focus Peaking function
- Interface
- HDMI, USB 2.0, IEEE 802.11b/g/n, Bluetooth
- Connectivity Features
- Remote control via mobile devices
Exposure & White Balance
- Light Sensitivity
- ISO auto (100-800), ISO 100-3200
- Exposure Metering
- Evaluative, centre-weighted, spot
- Exposure Modes
- Programme, automatic, manual, aperture-priority, shutter-priority
- White Balance
- Custom, automatic, presets
- White Balance Presets
- Fluorescent, cloudy, tungsten light, Flash, daylight, shade
- Max Shutter Speed
- 1/2000 sec
- Min Shutter Speed
- 15 sec
- Exposure Compensation
- ±3 EV range, in 1/3 EV steps
Lens System
- Focal Length Equivalent to 35mm Camera
- 21 - 1365mm
- Focus Adjustment
- Automatic, manual
- 0 m
- Zoom Adjustment
- Motorised drive
- Lens Construction
- 11 groups / 15 elements
- UD glass, Ultrasonic Motor (USM), aspherical lens
Camera Flash
- Camera Flash
- Pop-up flash
- Flash Modes
- Fill-in mode, slow synchro, auto mode, flash OFF mode, red-eye reduction
- Red-Eye Reduction
- Flash +/- compensation
- Effective Flash Range
- 0.5 m - 5 m (wide lens) , 2 m - 2.5 m (tele lens)
Additional Features
- Continuous Shooting Speed
- 5.7 frames per second, 10 frames per second, 2 frames per second (3MP)
- Self-Timer Delay
- 10 sec, 2sec
- Additional Features
- Built-in speaker, auto power save, digital image rotation, histogram display, cropping an image, resizing an image, in-camera red-eye fix, Zoom Framing Assist, Smart AUTO, primary colour filter, GPS via mobile
Viewfinder
- Viewfinder Type
- Electronic - OLED
- Viewfinder Colour Support
- Viewfinder Diagonal Size
- 0.39"
- Viewfinder Resolution
- 2,360,000 pixels
- Optical Viewfinder Field Coverage
- 100%
Display
- 3" LCD display
- Display Format
- 920,000 pixels
- Display Form Factor
- Rotating
- Display Features
- Display brightness control
Microphone
- Microphone Operation Mode
- Stereo
- Microphone Features
- Wind noise reduction
- Connector Type
- USB 2.0 (5 pin Micro-USB Type B) ¦ HDMI output (19 pin micro HDMI Type D)
- Included Accessories
- Battery charger, lens cap, neck strap, carrying case, lens cap strap
- Battery Type
- Canon LP-E12 Lithium Ion
- Details
- Battery Life Details
- Photo shooting - 325 shots (LCD Monitor on) , Photo shooting - 255 shots (EVF on) , Photo shooting - 405 shots (ECO mode) , Playback - 6 hours , Video recording - 85 minutes (LCD Monitor on)
Memory / Storage
- Memory Card Slot
- SD card
- Supported Memory Cards
- SD Memory Card, SDXC Memory Card, SDHC Memory Card, SDHC UHS-I Memory Card, SDXC UHS-I Memory Card
- Memory Card
- 32 GB SDHC
- Memory Card Included
- Image Storage
- JPEG 5184 x 2912 , JPEG 5184 x 3456 , JPEG 5184 x 3888 , JPEG 3648 x 2048 , JPEG 3648 x 2432 , JPEG 3648 x 2736 , JPEG 2432 x 1824 , JPEG 2432 x 1616 , JPEG 2432 x 1368 , JPEG 3888 x 3888 , JPEG 2736 x 2736 , JPEG 1824 x 1824
- Video Capture
- H.264 - 3840 x 2160 p - 29.97 fps , H.264 - 1920 x 1080 p - 119.9 fps , H.264 - 1920 x 1080 p - 59.94 fps , H.264 - 1920 x 1080 p - 29.97 fps , H.264 - 1280 x 720 p - 59.94 fps
- Limited warranty - 2 years
- 12.7 cm
- 11.66 cm
- 9.09 cm
- 576 g
- Weight Details
- Camera only: 576 g , Camera with battery and memory card: 608 g
- 0 °C
- 40 °C
- 10 - 90%
