With its incredible 65x Optical Zoom, image stabilization of up to 5 stops and 4K video recording, the PowerShot SX70 HS camera has you covered. From fun-filled family moments to once-in-a-lifetime travels and adventures, capture everything including faraway sights, ultra-wide vistas and spectacular, frame-filling, close-up macro shots like never before with a PowerShot SX-series camera. A bright and detailed electronic viewfinder combined with intuitive controls enable you to capture incredible moments as the opportunity presents itself.
 - Canon PowerShot SX70 HS - digital camera
- Product Type
 - Digital camera - 4K - compact
- Memory Card Slot
 - SD card
- Image Processor
 - DIGIC 8
- Wireless Interface
 - Wi-Fi, Bluetooth
- Sensor Resolution
 - 20.3 Megapixel
- Max Video Resolution
 - 3840 x 2160
- Lens System
 - Zoom lens - 65x zoom - 3.8 - 247 mm - f/3.4-6.5
- Focus Adjustment
 - Automatic, manual
- Min Focus Distance
 - 0 m
- Digital Zoom
 - 4x
- Image Stabiliser
 - Optical (Intelligent IS with 5-axis Enhanced Dynamic Mode)
- Camera Flash
 - Pop-up flash
- Viewfinder
 - Electronic - 0.39" - colour - OLED
- Display
 - LCD display - 3"
- Supported Battery
 - Canon LP-E12 Li-ion rechargeable battery (included)
- Interface
 - HDMI, USB 2.0
 - 12.7 cm x 11.66 cm x 9.09 cm
 - 576 g
 - 2-year warranty
- Product Type
- Sensor Resolution
 - 20.3 Megapixel
- Optical Sensor Type
 - BSI-CMOS
- Total Pixels
 - 21,100,000 pixels
- Effective Sensor Resolution
 - 20,300,000 pixels
- Optical Sensor Size
 - 1/2.3"
- Frame Rate (Max Resolution)
 - 30 fps
- ISO (Max)
 - 3200
- Optical Zoom
 - 65x
- Digital Zoom
 - 4x
- Image Processor
 - DIGIC 8
- Image Stabiliser
- Built-in Optical Image Stabiliser
- Face Detection
- Print Standard
 - Direct print, Exif Print support, PictBridge support
- Auto Focus
 - TTL contrast detection
- Auto Focus Points (Zones) Qty
 - 9
- AE/AF Control
 - Face-priority AF, Subject-tracking AF
- Digital Video Format
 - H.264
- Image Recording Format
 - JPEG, RAW, RAW + JPEG
 - 3840 x 2160
- Auto Focus Features
 - Focus Peaking function
- Interface
 - HDMI, USB 2.0, IEEE 802.11b/g/n, Bluetooth
- Connectivity Features
 - Remote control via mobile devices
Exposure & White Balance
- Light Sensitivity
 - ISO auto (100-800), ISO 100-3200
- Exposure Metering
 - Evaluative, centre-weighted, spot
- Exposure Modes
 - Programme, automatic, manual, aperture-priority, shutter-priority
- White Balance
 - Custom, automatic, presets
- White Balance Presets
 - Fluorescent, cloudy, tungsten light, Flash, daylight, shade
- Max Shutter Speed
 - 1/2000 sec
- Min Shutter Speed
 - 15 sec
- Exposure Compensation
 - ±3 EV range, in 1/3 EV steps
Lens System
- Focal Length Equivalent to 35mm Camera
 - 21 - 1365mm
- Focus Adjustment
 - Automatic, manual
 - 0 m
- Zoom Adjustment
 - Motorised drive
- Lens Construction
 - 11 groups / 15 elements
 - UD glass, Ultrasonic Motor (USM), aspherical lens
Camera Flash
- Camera Flash
 - Pop-up flash
- Flash Modes
 - Fill-in mode, slow synchro, auto mode, flash OFF mode, red-eye reduction
- Red-Eye Reduction
 - Flash +/- compensation
- Effective Flash Range
 - 0.5 m - 5 m (wide lens) , 2 m - 2.5 m (tele lens)
Additional Features
- Continuous Shooting Speed
 - 5.7 frames per second, 10 frames per second, 2 frames per second (3MP)
- Self-Timer Delay
 - 10 sec, 2sec
- Additional Features
 - Built-in speaker, auto power save, digital image rotation, histogram display, cropping an image, resizing an image, in-camera red-eye fix, Zoom Framing Assist, Smart AUTO, primary colour filter, GPS via mobile
Viewfinder
- Viewfinder Type
 - Electronic - OLED
- Viewfinder Colour Support
- Viewfinder Diagonal Size
 - 0.39"
- Viewfinder Resolution
 - 2,360,000 pixels
- Optical Viewfinder Field Coverage
 - 100%
Display
 - 3" LCD display
- Display Format
 - 920,000 pixels
- Display Form Factor
 - Rotating
- Display Features
 - Display brightness control
Microphone
- Microphone Operation Mode
 - Stereo
- Microphone Features
 - Wind noise reduction
- Connector Type
 - USB 2.0 (5 pin Micro-USB Type B) , HDMI output (19 pin micro HDMI Type D)
- Included Accessories
 - Battery charger, lens cap, neck strap, carrying case, lens cap strap
- Battery Type
 - Canon LP-E12 Lithium Ion
- Details
- Battery Life Details
 - Photo shooting - 325 shots (LCD Monitor on) , Photo shooting - 255 shots (EVF on) , Photo shooting - 405 shots (ECO mode) , Playback - 6 hours , Video recording - 85 minutes (LCD Monitor on)
Memory / Storage
- Memory Card Slot
 - SD card
- Supported Memory Cards
 - SD Memory Card, SDXC Memory Card, SDHC Memory Card, SDHC UHS-I Memory Card, SDXC UHS-I Memory Card
- Memory Card
 - 32 GB SDHC
- Memory Card Included
- Image Storage
 - JPEG 5184 x 2912 , JPEG 5184 x 3456 , JPEG 5184 x 3888 , JPEG 3648 x 2048 , JPEG 3648 x 2432 , JPEG 3648 x 2736 , JPEG 2432 x 1824 , JPEG 2432 x 1616 , JPEG 2432 x 1368 , JPEG 3888 x 3888 , JPEG 2736 x 2736 , JPEG 1824 x 1824
- Video Capture
 - H.264 - 3840 x 2160 p - 29.97 fps , H.264 - 1920 x 1080 p - 119.9 fps , H.264 - 1920 x 1080 p - 59.94 fps , H.264 - 1920 x 1080 p - 29.97 fps , H.264 - 1280 x 720 p - 59.94 fps
 - Limited warranty - 2 years
 - 12.7 cm
 - 11.66 cm
 - 9.09 cm
 - 576 g
- Weight Details
 - Camera only: 576 g , Camera with battery and memory card: 608 g
 - 0 °C
 - 40 °C
 - 10 - 90%
