The PowerShot G11 is a compact camera that will find favor with professionals and advanced amateur photographers due to its superb image quality, full manual control of settings, and RAW shooting capability. If it's not practical or safe to carry a large DSLR a high-specification compact such as the PowerShot G11 is a fantastic choice. It's great for photographers looking to capture high resolution, high quality, and low light images without having to carry a large SLR system in their kit bags.
The G11 features face detection technology that can detect and track numerous faces within the frame to ensure the correct exposure and focus for them. An enhanced i-Contrast system optimizes the dynamic range of subjects to deliver shadow details whilst avoiding highlight blow outs.
5x zoom lens
The 5x zoom lens on the PowerShot G11 extends down to a 28mm equivalent in 35mm format, making it perfect for capturing wide-angle scenes, and zooms in to the equivalent of 140mm. Combined with an optical 4-stop IS mechanism this ensures sharp images even when the camera is hand held in low light and at longer focal lengths. -
Dual anti-noise system
As seen in the Canon DSLR models, like the EOS 5D Mark II and EOS 50D, the DIGIC 4 processor carries out image processing in-camera and in combination with the high-sensitivity 10.0 Megapixel delivers full resolution shooting up to ISO 3200 for exceptional performance in all lighting conditions. -
2.8-inch vari-angle PureColor II VA LCD
The LCD screen has 461,000 dots giving a clear and sharp view on images either when shooting or in playback mode. It includes a real time histogram display so you can easily view conditions and alter your shooting settings if required. -
RAW shooting
Many professionals prefer to shoot in RAW mode rather than shooting JPEGs. The PowerShot G11 features a RAW recording mode so that you can obtain the highest quality images possible from the camera and integrate the G11 easily into your RAW workflow. -
Auto white balance
A technology from the EOS DSLR series the G11 has a white balance correction feature that allows you to adjust white balance correction in-camera so you can fine-tune for the colors you want in your pictures.
- Canon PowerShot G11 - digital camera
- Product Type
- Digital camera - compact
- Memory Card Slot
- SD card
- Image Processor
- DIGIC 4
- Sensor Resolution
- 10.0 Megapixel
- Lens System
- Zoom lens - 5x zoom - 6.1 - 30.5 mm - f/2.8-4.5
- Focus Adjustment
- Automatic, manual
- Min Focus Distance
- 50 cm
- Digital Zoom
- 4x
- Image Stabiliser
- Optical
- Camera Flash
- Built-in flash
- Viewfinder
- Optical - real-image zoom
- Display
- LCD display - 2.8"
- Supported Battery
- Li-ion rechargeable battery (included)
- Interface
- Composite video/audio, HDMI, USB 2.0
- 11.2 cm x 4.8 cm x 7.6 cm
- 355 g
- Product Type
- Sensor Resolution
- 10.0 Megapixel
- Optical Sensor Type
- CCD
- Total Pixels
- 10,400,000 pixels
- Effective Sensor Resolution
- 10,000,000 pixels
- Optical Sensor Size
- 1/1.7"
- ISO (Max)
- 12800
- Optical Zoom
- 5x
- Digital Zoom
- 4x
- Image Processor
- DIGIC 4
- Image Stabiliser
- Optical
- Built-in Optical Image Stabiliser
- Face Detection
- Print Standard
- Direct print, DPOF support, Exif Print support, PictBridge support
- Auto Focus
- TTL contrast detection
- Auto Focus Points (Zones) Qty
- 9
- AE/AF Control
- FlexiZone
- Digital Video Format
- H.264
- Image Recording Format
- JPEG, RAW, RAW + JPEG
- Interface
Exposure & White Balance
- Light Sensitivity
- ISO 100, ISO 800, ISO 400, ISO 200, ISO 80, ISO 1600, ISO 3200, ISO auto
- Exposure Metering
- Evaluative, spot AF area, centre-weighted, spot
- Exposure Modes
- Programme, automatic, manual, aperture-priority, shutter-priority
- Shooting Programs
- Landscape, portrait mode, stitch assist, fireworks, low light, night scene, Underwater, sports mode, sunset, indoor, foliage, beach, kids & pets, night snapshot, snow, aquarium
- Special Effects
- Black & White, Sepia, Neutral, Vivid, Custom Effect, Colour Accent, Colour Swap, Lighter Skin Tone, Darker Skin Tone, Vivid Green, vivid blue, Vivid Red, Positive Film
- White Balance
- Custom, automatic, presets
- White Balance Presets
- Fluorescent, cloudy, tungsten light, Flash, daylight, Underwater
- Max Shutter Speed
- 1/4000 sec
- Min Shutter Speed
- 15 sec
- Exposure Compensation
- ±2 EV range, in 1/3 EV steps
- Auto Exposure Bracketing
- 3 steps
- X-sync Speed
- 1/2000 sec
Lens System
- Focal Length Equivalent to 35mm Camera
- 28 - 140mm
- Focus Adjustment
- Automatic, manual
- 50 cm
- Macro Focus Range
- 1-50cm
- Zoom Adjustment
- Motorised drive
- Lens Construction
- 9 groups / 11 elements
- Built-in lens shield, aspherical lens
Camera Flash
- Camera Flash
- Built-in flash
- Flash Modes
- Fill-in mode, rear curtain sync, slow synchro, auto mode, flash OFF mode, red-eye reduction
- Red-Eye Reduction
- AF illuminator, flash +/- compensation
- Effective Flash Range
- 0.5 m - 7 m
Additional Features
- Continuous Shooting Speed
- 0.8 frames per second, 0.7 frames per second, 1.1 frames per second
- Self-Timer Delay
- 10 sec, 2sec
- Flash Terminal
- Hot shoe
- Additional Features
- Audio recording, RGB primary colour filter, digital noise reduction, sharpness control, digital image rotation, camera orientation detection, histogram display, AE lock, AF lock, FE lock, cropping an image, resizing an image, saturation control, Face Detection AF/AE/FE/WB, Face Detection Self-timer, i-Contrast (Intelligent Contrast Correction) system, in-camera red-eye fix, automatic face tracking technology, digital tele-converter, safety zoom, Blink Detection technology, Motion Detection Technology
Viewfinder
- Viewfinder Type
Display
- 2.8" LCD display
- Display Format
- 461,000 pixels
- Display Form Factor
- Rotating
- Display Features
- Contrast control
Microphone
- Microphone Operation Mode
- Mono
- Connector Type
- USB , Composite video/audio output , HDMI output
Software
- Software
- Drivers & Utilities, Canon PhotoStitch, Canon ZoomBrowser EX, Canon ImageBrowser, Canon Remote Capture
- Included Accessories
- Battery charger, neck strap, USB cable, audio / video cable
- Battery Type
- Canon NB-7L Lithium Ion
- Details
Memory / Storage
- Memory Card Slot
- SD card
- Supported Memory Cards
- MultiMediaCard, SD Memory Card, SDHC Memory Card, MultiMediaCardplus
- Image Storage
- RAW 3648 x 2736 , JPEG 3648 x 2736 , JPEG 3648 x 2048 , JPEG 2816 x 2112 , JPEG 2272 x 1704 , JPEG 1824 x 1368 , JPEG 1600 x 1200 , JPEG 640 x 480
- Video Capture
- H.264 - 640 x 480 - 30 fps , H.264 - 320 x 240 - 30 fps
- 11.2 cm
- 4.8 cm
- 7.6 cm
- 355 g
- 0 °C
- 40 °C
