Canon Powershot A2600 Silver 16MP 5xZoom 3.0LCD 4GB SD Card & Case
Quicklinx: 9CKTWS00 Mfr#: 8158B024AA
  • SDHC Memory Card
Simple shooting in superb style
It's easy to capture life in superb style wherever you go with the slim, colourful 16 Megapixel PowerShot A2600 - thanks to a large LCD, 5x zoom, instant HD movies (720p) and Smart Auto.
  • 16.0 Megapixels
  • 28mm wide, 5x zoom lens;10x ZoomPlus
  • 7.5 cm (3.0") LCD
  • Slim body with metal exterior
  • HD movies (720p) with movie button
  • Smart Auto plus Help button
  • Digital IS
  • Face Detection, Live View Control
  • Eco mode
  • Fun and creative effects
  • 16.0-megapixel image sensor with DIGIC 4 image processor
    With the PowerShot A2600 digital camera's 16.0-megapixels of resolution, your images are rich and clear, with textures and tiny details faithfully reproduced even at the long end of the 5x optical zoom. This high level of resolution is ideal for creating the largest prints, and allows you the flexibility to blow up and crop any section of an image to express your creativity. The DIGIC 4 image processor powers the camera's advanced systems and features, ensuring fast, reliable performance with low battery consumption.
  • Smart AUTO
    Photographers of all levels appreciate a camera - especially a go-anywhere compact digital - that takes the hassle out of capturing beautiful images. The PowerShot A2600 gives you Smart AUTO - sophisticated Canon technology that makes getting that great shot as simple as pressing the shutter button. Smart AUTO automatically detects scenes by assessing various factors in both the background and the subject. Detected scenes are analyzed using 32 predefined shooting situations. The camera then makes optimal settings to ensure the best possible image capture when shooting still images. Smart AUTO also includes advanced subject detection, which allows the camera to detect and track non-human moving subjects like animals and vehicles. With Smart AUTO, all you have to do is frame your shot and capture away.
  • 720p HD video
    You can shoot high definition video anytime, anywhere right from the pocket-sized PowerShot A2600 digital camera. With a simple push of the dedicated movie button, you'll be able to instantly record every moment in motion. 720p HD video is smooth, vivid, and beautifully lifelike, making it an ideal way to capture special memories. In addition to being able to shoot 720p HD video at 25 frames per second, the PowerShot A2600 can also shoot 640 x 480 VGA video at 30 frames per second.
  • Dedicated movie button for easy video capture
    It's never been easier to shoot videos with a PowerShot digital camera. To make shooting video as natural as snapping pictures, the PowerShot A2600 has a dedicated movie button. No need to plan ahead, no need to search through menus on the LCD screen; when you feel a moment would be best captured in 720p HD, simply press the button and recording begins. The camera is always ready to shoot stills or video whenever you want.
  • Eco mode helps reduce power consumption for longer battery life
    The PowerShot A2600 takes energy conservation to the next level with eco mode, which provides more shots per single charge through LCD monitor and camera power management. Eco mode can be activated via a dedicated button for easy power preservation when an outlet is unavailable or the moment is too exciting to put the camera down. Eco mode quickly wakes the camera from sleep when a button is pressed so you won't miss the moment. When the fun with family and friends runs late into the evening, eco mode on the PowerShot A2600 makes sure your camera keeps up.
  • Help button
    The PowerShot A2600 digital camera is designed to be fun and easy to use, even for beginners. A help button on the camera's exterior brings up the help menu any time you need it, right on the LCD screen. From here, you can scroll through a variety of topics that answer your questions with clear explanations, offer helpful shooting advice, and show you diagrams highlighting the position of any buttons you'll need.
Canon PowerShot A2600 - digital camera
Digital camera - 720p - compact
Memory Card Slot
SD card
Image Processor
DIGIC 4
Sensor Resolution
16.0 Megapixel
Max Video Resolution
1280 x 720
Lens System
Zoom lens - 5x zoom - 5 - 25 mm - f/2.8-6.9
Focus Adjustment
Automatic
Min Focus Distance
3 cm
Digital Zoom
4x
Image Stabiliser
Electronic
Camera Flash
Built-in flash
Display
LCD display - 3"
Supported Battery
Canon NB-11L Li-ion rechargeable battery - 680 mAh (included)
Composite video/audio, USB 2.0
Silver
9.77 cm x 1.98 cm x 5.6 cm
135 g
Enclosure Colour
Silver
Sensor Resolution
16.0 Megapixel
Optical Sensor Type
CCD
Total Pixels
16,600,000 pixels
Effective Sensor Resolution
16,000,000 pixels
Optical Sensor Size
1/2.3"
ISO (Max)
6400
Optical Zoom
5x
Digital Zoom
4x
Image Processor
DIGIC 4
Image Stabiliser
Electronic
Face Detection
Print Standard
Direct print, DPOF support, Exif Print support, PictBridge support
Auto Focus
TTL contrast detection
Auto Focus Points (Zones) Qty
9
AE/AF Control
Face-priority AF, Subject-tracking AF
Face Detection
Face Detection AF/AE/FE/WB, Face Detection Self-timer
Digital Video Format
H.264, MOV
Image Recording Format
JPEG
1280 x 720
Exposure & White Balance
Light Sensitivity
ISO 100, ISO 800, ISO 400, ISO 200, ISO 1600, ISO 6400, ISO auto
Exposure Metering
Evaluative, centre-weighted, spot
Exposure Modes
Programme, automatic
Shooting Programs
Portrait mode, slow shutter, fireworks, low light, snow
Special Effects
Fisheye, monochrome, miniature, Toy camera, Posterisation, Super Vivid
White Balance
Custom, automatic, presets
White Balance Presets
Fluorescent, cloudy, tungsten light, daylight, fluorescent light (daylight)
Max Shutter Speed
1/2000 sec
Min Shutter Speed
15 sec
Exposure Compensation
±2 EV range, in 1/3 EV steps
Lens System
Focal Length Equivalent to 35mm Camera
28 - 140mm
Focus Adjustment
Automatic
Min Focus Distance
3 cm
Macro Focus Range
3-50cm
Zoom Adjustment
Motorised drive
Lens Construction
5 groups / 6 elements
Built-in lens shield, aspherical lens, UA lens
Camera Flash
Camera Flash
Built-in flash
Flash Modes
Fill-in mode, slow synchro, auto mode, flash OFF mode, red-eye reduction
Red-Eye Reduction
AF illuminator
Effective Flash Range
0.5 m - 3 m (wide lens) , 1.2 m - 2 m (tele lens)
Additional Features
Continuous Shooting Speed
0.8 frames per second, 2.9 frames per second (4MP)
Self-Timer Delay
10 sec, 2sec
Additional Features
Built-in speaker, auto power save, digital image rotation, camera orientation detection, histogram display, AE lock, AF lock, resizing an image, i-Contrast (Intelligent Contrast Correction) system, in-camera red-eye fix, face detection, built-in help guide, Smart AUTO, Live View Control
Display
3" LCD display
Display Format
230,000 pixels
Display Form Factor
Built-in
Display Features
Display brightness control
Microphone
Microphone Operation Mode
Mono
Connector Type
USB 2.0 , Composite video/audio output
Software
Software
Drivers & Utilities, Canon PhotoStitch, Canon ImageBrowser EX
Battery charger, carrying case, wrist strap
Battery Type
Canon NB-11L Lithium Ion
Details
Battery Life Details
Photo shooting - 220 shots , Playback - 5 hours , Photo shooting - 300 shots (ECO mode)
Memory / Storage
Memory Card Slot
SD card
Supported Memory Cards
SD Memory Card, SDXC Memory Card, SDHC Memory Card
Memory Card
4 GB SDHC
Image Storage
JPEG 4608 x 3456 , JPEG 4608 x 2592 , JPEG 3264 x 2448 , JPEG 1600 x 1200 , JPEG 640 x 480
Video Capture
H.264 - 1280 x 720 - 25 fps , H.264 - 640 x 480 - 30 fps
9.77 cm
1.98 cm
5.6 cm
135 g
10 - 90%
