Canon PIXMA TS9550 Colour Inkjet Multifunction Printer
Quicklinx: FRZVWS00 Mfr#: 2988C008
With A3 print capability, clever cloud-storage printing and advanced connectivity, PIXMA TS9550 benefits from professional precision. Add 20-sheet ADF and booklet-making functions, and you have a true business tool.
  • Compact A3 solution
    Enjoy easy operation, auto 2-sided printing and A3 production in a compact model with a large 10.8cm (4.3 inch) touchscreen
  • Smart and connected
    Print, scan and copy with the Canon PRINT app or print with AirPrint (iOS) and Mopria (Android). You can also benefit from Ethernet connectivity or work without any internet using Wireless Direct.
  • Cloud connectivity
    Simplify printing and scanning to and from cloud accounts such as Google Drive, OneDrive and Evernote with direct access using the PIXMA Cloud Link via the Canon PRINT app.
  • Best for business
    Create booklets, copy A3 documents using the oversized copy feature, and multi-task with PIXMA TS9540's 2-way paper feeder and 20-sheet ADF.
  • Professional production
    Rely on the dedicated pigment black ink for truly professional documents with crisp, clear text. Optional XL and XXL cartridges can cut costs per page and increase time between cartridge changes.
Canon PIXMA TS9550 - multifunction printer - colour
Multifunction printer
Printing Technology
Ink-jet (colour)
Inkjet Technology
Canon FINE (Full-lithography inkjet Nozzle Engineering) - 5-ink
Max Copying Speed
8 ppm (colour)
Max Printing Speed
Up to 15 ipm (mono) / up to 10 ipm (colour)
Max Printing Resolution
4800 x 1200 dpi (colour)
Scanning
1200 x 2400 dpi
Display
4.3"
Original Size
A4 (210 x 297 mm), Legal (216 x 356 mm) (max)
Original Type
Sheets
Document Feeder Capacity
20 sheets
Media Size
55 x 89 mm (min) - A3 (297 x 420 mm), CD (120 mm), 215.9 x 676 mm (max)
Media Type
Envelopes, plain paper, photo paper, printable CD/DVD/BD disk, glossy paper, matte paper, luster paper, semi-gloss paper, fine art paper, photo stickers
Standard Media Capacity
200 sheets
Automatic Duplexing
Yes (printing)
Connection Availability
USB 2.0, LAN, Bluetooth, Wi-Fi(n)
AirPrint Enabled
Office Machine Features
PIXMA Cloud Link, access point mode
AC 120/230 V (50/60Hz)
46.8 cm x 36.6 cm x 19.3 cm
9.7 kg
Enclosure Colour
2-year Limited Warranty
Printing Technology
Ink-jet - colour
Display Diagonal Size
4.3"
Display Colour Support
Display Features
Touch screen
AirPrint Enabled
Enclosure Colour
Supported Flash Memory
SD Memory Card, SDHC Memory Card, SDXC Memory Card
Copying
Max Copying Speed
8 ppm (colour)
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
99
Copying Features
2 on 1, 4 on 1, fit to page, ID Card Copy, Frame Erase Copy, disc label copy, Borderless copy
Printing
Inkjet Technology
Max Printing Speed
Ink Cartridge Configuration
5 individual ink tanks
Ink Palette Supported (Colours)
Cyan, magenta, yellow, black, pigment black
5-ink
Ink Type
Canon ChromaLife100
Automatic Duplexing
Scanning
Scan Element
CIS
Optical Resolution
1200 x 2400 dpi
Grayscale Depth
8-bit
Colour Depth
8-bit
Colour Depth (Internal)
16-bit
Document & Media Handling
Max Original Size
Supported Original Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), 216 x 297 mm
Original Type
Sheets
20 sheets
Min Media Size
55 x 89 mm
Max Media Size
A3
Min Media Weight
64 g/m²
Max Media Weight
300 g/m²
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A3 (297 x 420 mm), 100 x 150 mm, 130 x 180 mm, 100 x 100 mm, 200 x 250 mm, 250 x 300 mm, 130 x 130 mm, 300 x 300 mm, 175 x 250 mm, 215.9 x 676 mm, 55 x 89 mm, 89 x 89 mm
Supported Envelope Sizes
International DL (110 x 220 mm), Com-10 (105 x 241 mm)
Borderless Photo Sizes
ANSI A (Letter) (216 x 279 mm), A4 (210 x 297 mm), A3 (297 x 420 mm), 100 x 150 mm, 130 x 180 mm, 100 x 100 mm, 200 x 250 mm, 250 x 300 mm, 130 x 130 mm, 300 x 300 mm, 175 x 250 mm, 89 x 89 mm
200 sheets
Input tray - 100 sheets size: 55 x 89 mm - 215.9 x 676 mm weight: 64 g/m² - 300 g/m² , Paper cassette - 100 sheets size: 148 x 210 mm - Letter A (216 x 279 mm)/A4 (210 x 297 mm) weight: 64 g/m² - 105 g/m² , CD/DVD/BD tray
Speed Details
Printing: up to 15 ipm - B/W , Printing: up to 10 ipm - colour , Printing: 21 sec (10 x 15 cm (4"x6")) - photo , Copying: up to 8 ipm - colour
1 x USB 2.0 - 4 pin USB Type B , 1 x LAN - RJ-45
Security Protocols & Features
WEP, WPA-PSK, WPA2-PSK
Operating System Support
MS Windows 7 SP1, Android, iOS, Windows 8.1, Windows 10, Windows 10 Mobile, Apple Mac OS X 10.10.5 - 10.11, macOS 10.12 - macOS 10.13
Software Included
Drivers & Utilities, Canon Easy-WebPrint EX, MP Driver including Scanning Utility
14 Watt
Power Consumption Standby
2 Watt
Direct Printing Specifications
PictBridge
First Copy Out Time Colour
19 sec
Consumables Included
1 x ink tank (pigmented black) , 1 x ink tank (black) , 1 x ink tank (cyan) , 1 x ink tank (magenta) , 1 x ink tank (yellow)
46.8 cm
36.6 cm
19.3 cm
9.7 kg
Sound Emission
49.5 dBA (operating)
15 °C
30 °C
10 - 80% (non-condensing)
FRZV Canon CLI581XLM Magenta Ink Cartridge In Stock £12.19
FRZV Canon CLI-581BK Black Ink Cartridge In Stock £8.52
FRZV Canon PGI-580GBK XL Ink Tank - Black In Stock £13.43
FRZV Canon INK CLI-581Y XL Ink Tank - Yellow In Stock £12.19
FRZV Canon CLI-581C XL Ink Tank - Cyan In Stock £11.92
