Powerful All-In-One delivering premium quality photo printing, multiple wireless connectivity options and an easy-to-use 10.8 cm (4.3") touchscreen, all from a stylish and compact body.
Bring your memories to life:
Produce beautiful photographs complete with vivid colours and stunning detail. Canon's FINE inkjet print system, enhanced print head technology and 6 single inks - including grey - mean improved shading, reduced graininess, deeper black tones, and photos that look better than ever.
Compact, stylish design:
Experience a lean, space-saving form factor 30% smaller than previous equivalent models. Clever contrasting textures, rounded corners and tapering contours make the printer's already-small frame appear even smaller. A superb printer inside and out.
Easy smartphone printing:
Get connected, get printing. With Wi-Fi and mobile printing support for Mopria™ for Android, Apple AirPrint™, Google Cloud Print™, Windows 10 Mobile™ and the Canon PRINT app means easy printing from a range of devices. NFC-equipped Android devices can print and scan with just a touch, while the SD card slot and support for Wi-Fi cameras adds further photo printing options.
Intuitive operation and large touchscreen:
Every function is just a tap away with the automatic tilting panel with integrated 10.8 cm (4.3") touchscreen and simple user interface. The touchscreen provides access to everything you need, from basic printer functions to selecting images to print from an SD card.
Mobile and cloud printing:
Using PIXMA Cloud Link from the Canon PRINT app or the printer's touchscreen, you can print from popular social network and cloud services including Facebook, Instagram, Google Drive, Dropbox, OneDrive and many more. You can even upload scanned documents and photos to Google Drive, OneDrive and Dropbox.
Reduced printing costs:
Using the optional high-capacity Canon XL ink cartridges means you can save as much as 30% per page compared to their standard equivalents. Auto 2-sided printing means you'll also save on paper.
Multifunction print, copy and scan:
More than just a printer, it's a versatile All-In-One for printing, scanning and copying documents quickly and simply. Packed with easy-to-use features for printing lab-quality photos and crisp text documents.
Powerful bundled software:
Canon's CREATIVE PARK PREMIUM lets you and the kids get creative. Select from a huge catalogue of fun, colourful and educational pieces - from beautiful birthday cards to jaw-dropping 3D paper craft animals, toys and architectural landmarks*.
Print square photos:
Inject new life into your social snaps - access Instagram via PIXMA Cloud Link and print your favourite shots using Canon's 13x13 cm (5"x5") Photo Paper Plus Glossy II square media.
This model has replaced the PIXMA MG7750
Produce beautiful photographs complete with vivid colors and stunning detail. Canon's FINE inkjet print system, enhanced print head technology and 6 single inks - including grey - mean improved shading, reduced graininess, deeper black tones, and photos that look better than ever. -
Experience a lean, space-saving form factor 30% smaller than previous equivalent models. Clever contrasting textures, rounded corners and tapering contours make the printer's already-small frame appear even smaller. A superb printer inside and out. -
Get connected, get printing. With Wi-Fi and mobile printing support for Mopria for Android, Apple AirPrint, Google Cloud Print, Windows 10 Mobile and the Canon PRINT app means easy printing from a range of devices. NFC-equipped Android devices can print and scan with just a touch, while the SD card slot and support for Wi-Fi cameras adds further photo printing options.
- Canon PIXMA TS8050 - multifunction printer - colour
- Multifunction printer
- Printing Technology
- Ink-jet (colour)
- Inkjet Technology
- Canon FINE (Full-lithography inkjet Nozzle Engineering) - 6-ink
- Max Copying Speed
- 6.5 ppm (colour)
- Max Printing Speed
- Up to 15 ipm (mono) / up to 10 ipm (colour)
- Max Printing Resolution
- 9600 x 2400 dpi (colour)
- Scanning
- 2400 x 4800 dpi
- Display
- 4.3"
- Original Size
- 216 x 297 mm (max)
- Original Type
- Sheets
- Media Size
- Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
- Media Type
- Envelopes, plain paper, photo paper, printable CD/DVD/BD disk, glossy photo paper, matte photo paper, high resolution paper, luster paper, semi-gloss photo paper, fine art paper
- Standard Media Capacity
- 120 sheets
- Automatic Duplexing
- Yes (printing)
- Connection Availability
- Interface
- USB 2.0, Wi-Fi(n), NFC
- AirPrint Enabled
- Office Machine Features
- PIXMA Cloud Link, access point mode
- Power
- AC 120/230 V (50/60Hz)
- 37.2 cm x 32.4 cm x 13.9 cm
- 6.5 kg
- Enclosure Colour
- Black
- Ink-jet - colour
- Display Diagonal Size
- 4.3"
- Display Features
- Touch screen
- Interface
- AirPrint Enabled
- Enclosure Colour
- Black
- Supported Flash Memory
- SD Memory Card, SDHC Memory Card
Copying
- Max Copying Speed
- 6.5 ppm (colour)
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 99
- Copying Features
- 2 on 1, 4 on 1, fit to page, ID Card Copy, Frame Erase Copy, disc label copy, Borderless copy
Printing
- Inkjet Technology
- Ink Cartridge Configuration
- 6 individual ink tanks
- Ink Palette Supported (Colours)
- Cyan, magenta, yellow, black, pigment black, grey
- 6-ink
- Ink Type
- Canon ChromaLife100
Scanning
- Scan Element
- CIS
- Optical Resolution
- 2400 x 4800 dpi
- Grayscale Depth
- 8-bit
- Colour Depth
- 24-bit
- Colour Depth (Internal)
- 48-bit
Document & Media Handling
- Max Original Size
- 216 x 297 mm
- Original Type
- Sheets
- Max Media Size
- A4/Legal
- Min Media Weight
- 64 g/m²
- Max Media Weight
- 300 g/m²
- Supported Media Type
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), 100 x 150 mm, 130 x 180 mm, CD (120 mm), 200 x 250 mm, 130 x 130 mm
- Supported Envelope Sizes
- International DL (110 x 220 mm), Com-10 (105 x 241 mm)
- Borderless Photo Sizes
- ANSI A (Letter) (216 x 279 mm), A4 (210 x 297 mm), 100 x 150 mm, 130 x 180 mm, 200 x 250 mm, 130 x 130 mm
- 120 sheets
- Paper cassette - 100 sheets - Letter A (216 x 279 mm)/A4 (210 x 297 mm) weight: 64 g/m² - 105 g/m² , Input tray - 20 sheets size: 100 x 150 mm - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 64 g/m² - 300 g/m² , CD/DVD/BD tray
- Speed Details
- Printing: up to 15 ipm - B/W , Printing: up to 10 ipm - colour , Printing: 21 sec (10 x 15 cm (4"x6")) - photo , Copying: up to 6.5 ipm - colour , Scanning: 14 sec (A4) - colour
- 1 x USB 2.0 - 4 pin USB Type B
- WEP, WPA-PSK, WPA2-PSK, Wi-Fi Direct
- Operating System Support
- MS Windows 7, MS Windows Vista SP2, MS Windows 7 SP1, Windows 8, Windows RT, Android, iOS, Windows 8.1, Windows 10, Windows 10 Mobile, Apple Mac OS X 10.8.5 - 10.11
- Software Included
- Drivers & Utilities, Canon Easy-WebPrint EX, Canon Full HD Movie Print, Canon My Image Garden, Quick Menu, MP Driver including Scanning Utility
- Voltage Required
- 16 Watt
- Power Consumption Standby
- 1.8 Watt
- Direct Printing Specifications
- PictBridge
- First Copy Out Time Colour
- 19 sec
- Consumables Included
- 1 x ink tank (pigmented black) , 1 x ink tank (black) , 1 x ink tank (cyan) , 1 x ink tank (magenta) , 1 x ink tank (yellow) , 1 x ink tank (grey)
- 37.2 cm
- 32.4 cm
- 13.9 cm
- 6.5 kg
- Sound Emission
- 49 dBA (operating)
- 15 °C
- 30 °C
- 10 - 80% (non-condensing)
