Canon PIXMA TS7750i A4 Colour MFP Inkjet
Quicklinx: HYZVWS00 Mfr#: 6258C008
45 In Stock
£109.64 ex VAT
£131.56 inc VAT
This intuitive, high-performance all-in-one printer fits easily into any home environment. It supports PIXMA Print Plan, saving up to 50 percent on ink costs.
  • Tilting screen
    The color touch screen is always easy to view and access, as it is located on a tilting panel on the front of the printer, which can be set to vertical or at a 45-degree angle.
  • Easy-access drawer
    Positioned on the front for easy access, the drawer can hold up to 100 sheets of A4 plain paper.
  • Automatic Document Feeder (ADF)
    Scan and copy multi-page documents quickly and easily with the 35-sheet automatic document feeder.
  • Automatic Document Feeder (ASF)
    Save time and effort by loading different media, such as photo paper, into the rear tray of the automatic document feeder.
  • Touch User Interface
    Provides optimal selection of functions based on use: work, study or lifestyle. Quick access to the functions you want to use.
  • Maintenance tray
    Reduce downtime with a user-replaceable maintenance cartridge.
Canon PIXMA TS7750i - multifunction printer - colour
Multifunction printer
Printing Technology
Ink-jet (colour)
Inkjet Technology
Canon FINE (Full-lithography inkjet Nozzle Engineering) - 4-ink
Max Printing Speed
Up to 15 ipm (mono) / up to 10 ipm (colour)
Max Printing Resolution
1200 x 1200 dpi (colour)
Scanning
1200 x 2400 dpi
Display
2.7"
Original Size
Legal (216 x 356 mm) (max)
Original Type
Sheets
Document Feeder Capacity
35 sheets
Media Size
Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Plain paper, labels, coloured paper, photo paper, photo paper pro platinum, luster paper, glossy photo paper, matte photo paper, iron-on transfers
Standard Media Capacity
200 sheets
Automatic Duplexing
Yes (printing)
Connection Availability
USB 2.0, Wi-Fi(n)
AirPrint Enabled
Office Machine Features
PIXMA Cloud Link
AC 100-240 V (50/60Hz)
37.4 cm x 35 cm x 20.8 cm
7.3 kg
Printing Technology
Ink-jet - colour
Display Diagonal Size
2.7"
Display Colour Support
Display Features
Touch screen
USB 2.0, Wi-Fi(n)
AirPrint Enabled
PIXMA Cloud Link
Copying
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
99
Copying Features
Fit to page, document copy, photo copy, Borderless copy, 2 on 1, 4 on 1, Frame Erase Copy, ID Copy, collation copy
Printing
Inkjet Technology
Max Printing Speed
Ink Cartridge Configuration
1 pigment black cartridge, 1 colour cartridge (cyan, magenta, yellow)
Ink Palette Supported (Colours)
Cyan, magenta, yellow, pigment black
4-ink
Automatic Duplexing
Scanning
Scan Element
CIS
Optical Resolution
1200 x 2400 dpi
Grayscale Depth
8-bit
Colour Depth
8-bit
Colour Depth (Internal)
16-bit
Document & Media Handling
Max Original Size
Supported Original Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm)
Original Type
Sheets
35 sheets
Max Media Size
A4/Legal
Min Media Weight
64 g/m²
Max Media Weight
300 g/m²
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), 127 x 127 mm, 89 x 89 mm, 55 x 91 mm, 101.6 x 152.4 mm, 127 x 177.8 mm, 177.8 x 254 mm, 203.2 x 254 mm
Supported Envelope Sizes
International DL (110 x 220 mm), Com-10 (105 x 241 mm)
Borderless Photo Sizes
ANSI A (Letter) (216 x 279 mm), A4 (210 x 297 mm), B5 (176 x 250 mm), 127 x 127 mm, 89 x 89 mm, 55 x 91 mm, 101.6 x 152.4 mm, 127 x 177.8 mm, 203.2 x 254 mm
200 sheets
Paper cassette - 100 sheets size: B5 (176 x 250 mm) - Letter A (216 x 279 mm) weight: 64 g/m² - 105 g/m² , Rear input tray - 100 sheets size: 55 x 89 mm - 215.9 x 1200 mm weight: 64 g/m² - 300 g/m² , ADF - 35 sheets - Legal (216 x 356 mm)
Speed Details
Printing: up to 15 ipm - B/W , Printing: up to 10 ipm - colour , Printing: 16 sec (10 x 15 cm (4"x6")) - photo
1 x USB 2.0 - 4 pin USB Type B
Security Protocols & Features
WEP, WPA-PSK, WPA2-PSK
Operating System Support
Windows 10, Windows 11, Windows 8.1, MS Windows 7 SP1, macOS 10.15.7 - 13, iOS, iPadOS, Android, Chrome OS
Software Included
Drivers & Utilities, Canon Easy-PhotoPrint Editor, Canon Print Service Plug-in for Android
22 Watt
Power Consumption Standby
1.5 Watt
First Copy Out Time Colour
18 sec
Consumables Included
1 x ink cartridge (pigmented black) , 1 x ink cartridge (colour)
37.4 cm
35 cm
20.8 cm
7.3 kg
Sound Emission
48 dBA (operating)
15 °C
30 °C
10 - 80% RH (non-condensing)
Brand: Canon
