Canon PIXMA TS7650i A4 Colour MFP Inkjet
Quicklinx: HYZTWS00 Mfr#: 6256C008
More than 50 In Stock
£86.14 ex VAT
£103.36 inc VAT
The Canon PIXMA TS7650i is a versatile multifunction printer that caters to all your office and home printing needs. With its robust connectivity options including AirPrint, Wi-Fi(n), and PIXMA Cloud Link, it offers the convenience of printing from virtually anywhere. The device supports a wide range of media types and sizes, from glossy photo paper to envelopes and labels, making it suitable for various printing tasks. Its advanced copying features ensure high-quality reproductions of documents and photos, while the automatic duplexing function promotes efficient, two-sided printing. The touchscreen display enhances user experience by providing intuitive control and navigation. Whether you're printing detailed reports, vibrant photos, or scanning important documents, the Canon PIXMA TS7650i delivers performance and quality in one compact package.
  • Effortless connectivity
    With options like AirPrint, Wi-Fi(n), and PIXMA Cloud Link, this Canon PIXMA TS7650i offers seamless connectivity, allowing you to print from almost anywhere in your home or office.
  • Versatile media handling
    From glossy photo papers to envelopes and labels, the Canon PIXMA TS7650i handles a wide range of media types and sizes, making it suitable for various printing needs.
  • High-quality copying features
    With functionalities such as 2 on 1, 4 on 1, and borderless copy, the device ensures your documents and photos are reproduced with clarity and precision.
  • Advanced printing technology
    Leveraging Canon FINE technology and a 4-color cartridge system, the PIXMA TS7650i delivers crisp, vibrant prints, whether it's documents or photos.
  • Convenient scanning capabilities
    A high optical resolution of 1200 x 2400 DPI and a color depth of 16-bit internally ensure your scans are detailed and color-accurate, perfect for digitizing photos or important documents.
Canon PIXMA TS7650i - multifunction printer - colour
Multifunction printer
Printing Technology
Ink-jet (colour)
Inkjet Technology
Canon FINE (Full-lithography inkjet Nozzle Engineering) - 4-ink
Max Printing Speed
Up to 15 ipm (mono) / up to 10 ipm (colour)
Max Printing Resolution
1200 x 1200 dpi (colour)
Scanning
1200 x 2400 dpi
Display
2.7"
Original Size
Legal (216 x 356 mm) (max)
Original Type
Sheets
Media Size
Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Plain paper, labels, coloured paper, photo paper, photo paper pro platinum, luster paper, glossy photo paper, matte photo paper, iron-on transfers
Standard Media Capacity
200 sheets
Automatic Duplexing
Yes (printing)
Connection Availability
USB 2.0, Wi-Fi(n)
AirPrint Enabled
Office Machine Features
PIXMA Cloud Link
AC 100-240 V (50/60Hz)
37.4 cm x 35 cm x 16.8 cm
6.3 kg
Printing Technology
Ink-jet - colour
Display Diagonal Size
2.7"
Display Colour Support
Display Features
Touch screen
USB 2.0, Wi-Fi(n)
AirPrint Enabled
PIXMA Cloud Link
Copying
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
99
Copying Features
Fit to page, document copy, photo copy, Borderless copy, 2 on 1, 4 on 1, Frame Erase Copy, ID Copy, collation copy, two-sided copy
Printing
Inkjet Technology
Max Printing Speed
Ink Cartridge Configuration
1 pigment black cartridge, 1 colour cartridge (cyan, magenta, yellow)
Ink Palette Supported (Colours)
Cyan, magenta, yellow, pigment black
4-ink
Automatic Duplexing
Scanning
Scan Element
CIS
Optical Resolution
1200 x 2400 dpi
Grayscale Depth
8-bit
Colour Depth
8-bit
Colour Depth (Internal)
16-bit
Document & Media Handling
Max Original Size
Supported Original Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm)
Original Type
Sheets
Max Media Size
A4/Legal
Min Media Weight
64 g/m²
Max Media Weight
265 g/m²
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), 127 x 127 mm, 89 x 89 mm, 55 x 91 mm, 101.6 x 152.4 mm, 127 x 177.8 mm, 177.8 x 254 mm, 203.2 x 254 mm
Supported Envelope Sizes
International DL (110 x 220 mm), Com-10 (105 x 241 mm)
Borderless Photo Sizes
ANSI A (Letter) (216 x 279 mm), A4 (210 x 297 mm), B5 (176 x 250 mm), 127 x 127 mm, 89 x 89 mm, 55 x 91 mm, 101.6 x 152.4 mm, 127 x 177.8 mm, 203.2 x 254 mm
200 sheets
Paper cassette - 100 sheets size: B5 (176 x 250 mm) - Letter A (216 x 279 mm) weight: 64 g/m² - 105 g/m² , Rear input tray - 100 sheets size: 55 x 89 mm - 215.9 x 1200 mm weight: 64 g/m² - 265 g/m²
Speed Details
Printing: up to 15 ipm - B/W , Printing: up to 10 ipm - colour , Printing: 19 sec (10 x 15 cm (4"x6")) - photo
1 x USB 2.0 - 4 pin USB Type B
Security Protocols & Features
WEP, WPA-PSK, WPA2-PSK
Operating System Support
Windows 10, Windows 11, Windows 8.1, MS Windows 7 SP1, macOS 10.15.7 - 13, iOS, iPadOS, Android, Chrome OS
Software Included
Drivers & Utilities, Canon Easy-PhotoPrint Editor, Canon Print Service Plug-in for Android, Canon PRINT App, Canon Creative Park
21 Watt
Power Consumption Standby
1.5 Watt
First Copy Out Time Colour
18 sec
Consumables Included
1 x ink cartridge (pigmented black) , 1 x ink cartridge (colour)
37.4 cm
35 cm
16.8 cm
6.3 kg
Sound Emission
48 dBA (operating)
15 °C
30 °C
10 - 80% RH (non-condensing)
Type: Printer / copier / scanner
Functionality: Scanner
Functionality: Copier
Functionality: Printer
Max Paper Size: A4 (210 x 297 mm)
Brand: Canon
