The Canon PIXMA TS7450i is the perfect fit for versatile home use and effective home working: print, scan and copy from any device. It's so easy to connect and operate using the Canon PRINT app: this all-in-one home printer offers mobile printing at its best. Stylish, affordable and simple to use, the PIXMA TS7450i offers the ability to print on many kinds of media from your computer, tablet or smartphone: print on photo paper, iron-on transfers, magnetic paper or restickable paper. With ADF technology, you can scan and copy multiple sheets in double-quick time, making home working faster and simpler. When work is over, the PIXMA TS7450i is as inventive as you are. It's ideal for artistic endeavours with children, or even for the big kid in you.
Effortless connectivity
With options like AirPrint, Mopria Print Service, and Wireless PictBridge, the Canon PIXMA TS7450i offers seamless connectivity for a variety of devices, ensuring you can print from almost anywhere in your home or office. -
Versatile media handling
The device's advanced media handling capabilities support a wide range of sizes and types, from glossy photo paper to envelopes, making it ready for both personal and professional projects. -
High-quality printing
Leveraging Canon FINE technology and a maximum resolution of 4800 x 1200 DPI, the PIXMA TS7450i delivers crisp, vibrant prints, whether it's documents or photos. -
Convenient scanning and copying
With features like a 35-sheet ADF, 2 on 1 copying, and a high-resolution CIS scan element, this all-in-one printer simplifies document management and digitization tasks. -
Eco-friendly design
Automatic duplexing not only saves time but also paper, making the Canon PIXMA TS7450i an environmentally friendly choice for your printing, scanning, and copying needs.
- Canon PIXMA TS7450i - multifunction printer - colour
- Multifunction printer
- Printing Technology
- Ink-jet (colour)
- Inkjet Technology
- Canon FINE (Full-lithography inkjet Nozzle Engineering) - 4-ink
- Max Printing Speed
- Up to 13 ipm (mono) / up to 6.8 ipm (colour)
- Max Printing Resolution
- 4800 x 1200 dpi (colour)
- Scanning
- 1200 x 2400 dpi
- Display
- 1.44"
- Original Size
- A4 (210 x 297 mm), Legal (216 x 356 mm) (max)
- Original Type
- Sheets
- Document Feeder Capacity
- 35 sheets
- Media Size
- 55 x 89 mm (min) - 215.9 x 676 mm (max)
- Media Type
- Envelopes, plain paper, iron-on transfers, greeting cards, card stock, glossy paper, matte paper, high resolution paper, luster paper, semi-gloss paper, photo stickers, magnetic photo paper, photo paper pro platinum
- Standard Media Capacity
- 200 sheets
- Automatic Duplexing
- Yes (printing)
- Connection Availability
- Interface
- USB 2.0, Wi-Fi(n)
- AirPrint Enabled
- Office Machine Features
- PIXMA Cloud Link
- Power
- AC 120/230 V (50/60Hz)
- 40.3 cm x 36.4 cm x 20.6 cm
- 8.2 kg
- Enclosure Colour
- Black
- 2-year warranty
- Ink-jet - colour
- Display Diagonal Size
- 1.44"
- Display Features
- OLED display
- Interface
- USB 2.0, Wi-Fi(n)
- AirPrint Enabled
- PIXMA Cloud Link
- Enclosure Colour
- Black
Copying
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 99
- Copying Features
- 2 on 1, fit to page, collation copy, two-sided copy, document copy
Printing
- Inkjet Technology
- Ink Cartridge Configuration
- 1 black cartridge, 1 colour cartridge (cyan, magenta, yellow)
- Ink Palette Supported (Colours)
- Cyan, magenta, yellow, black
- 4-ink
Scanning
- Scan Element
- CIS
- Optical Resolution
- 1200 x 2400 dpi
- Grayscale Depth
- 8-bit
- Colour Depth
- 8-bit
- Colour Depth (Internal)
- 16-bit
Document & Media Handling
- Max Original Size
- Supported Original Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm)
- Original Type
- Sheets
- 35 sheets
- Min Media Size
- 55 x 89 mm
- Max Media Size
- A4/Legal
- Min Media Weight
- 64 g/m²
- Max Media Weight
- 300 g/m²
- Supported Media Type
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), 100 x 150 mm, 130 x 180 mm, 200 x 250 mm, 130 x 130 mm, 215.9 x 676 mm, 55 x 89 mm, 89 x 89 mm, 91 x 55 mm
- Supported Envelope Sizes
- International DL (110 x 220 mm), Com-10 (105 x 241 mm)
- Borderless Photo Sizes
- ANSI A (Letter) (216 x 279 mm), A4 (210 x 297 mm), B5 (176 x 250 mm), 100 x 150 mm, 130 x 180 mm, 200 x 250 mm, 130 x 130 mm, 89 x 89 mm, 91 x 55 mm
- 200 sheets
- Paper cassette - 100 sheets size: 148 x 210 mm - 215.9 x 297 mm weight: 64 g/m² - 105 g/m² , Input tray - 100 sheets size: 55 x 89 mm - 215.9 x 676 mm weight: 64 g/m² - 300 g/m²
- Speed Details
- Printing: up to 13 ipm - B/W , Printing: up to 6.8 ipm - colour , Printing: 43 sec (10 x 15 cm (4"x6")) - photo , Copying: up to 4 ipm
- 1 x USB 2.0 - 4 pin USB Type B
- WEP, WPA-PSK, WPA2-PSK
- Operating System Support
- MS Windows 7 SP1, Android, iOS, Windows 8.1, Windows 10, Chrome OS, iPadOS, Windows 11, macOS 10.12.6 - macOS 13
- Software Included
- Drivers & Utilities, MP Driver including Scanning Utility, Canon Easy-PhotoPrint Editor
- Voltage Required
- 14 Watt
- Power Consumption Standby
- 1.7 Watt
- Direct Printing Specifications
- PictBridge
- First Copy Out Time Colour
- 20 sec
- Consumables Included
- 1 x ink cartridge (black) - up to 180 pages - Canon PG-560 , 1 x ink cartridge (colour) - up to 180 pages - Canon CL-561
- Limited warranty - 2 years
- 40.3 cm
- 36.4 cm
- 20.6 cm
- 8.2 kg
- Sound Emission
- 42.5 dBA (operating)
- 15 °C
- 30 °C
- 10 - 80% RH (non-condensing)
Canon SG-201 - 20x25cm Photo Paper | In Stock | £8.62 |
Canon PP201 A4 Paper 20 Sheets | In Stock | £12.58 |
Canon Photo Paper Plus SG-201 - Semi-gloss satin - 101.6 x 152.4 mm - 260 g/m2 - 50 sheets | In Stock | £11.24 |
Canon Photo Paper Plus SG-201 - Semi-gloss photo paper - A4 (210 x 297 mm) - 260 g/m2 - 20 sheets | In Stock | £12.34 |
Canon Luster Paper A4 20 Sheets | In Stock | £11.61 |
Canon PG560 Black Ink Cartridge 7.5ml | In Stock | £14.09 |
