Canon PIXMA TS7450i Multifunction Printer
Quicklinx: HYZSWS00 Mfr#: 5449C008
£87.44 ex VAT
£104.92 inc VAT
The Canon PIXMA TS7450i is the perfect fit for versatile home use and effective home working: print, scan and copy from any device. It's so easy to connect and operate using the Canon PRINT app: this all-in-one home printer offers mobile printing at its best. Stylish, affordable and simple to use, the PIXMA TS7450i offers the ability to print on many kinds of media from your computer, tablet or smartphone: print on photo paper, iron-on transfers, magnetic paper or restickable paper. With ADF technology, you can scan and copy multiple sheets in double-quick time, making home working faster and simpler. When work is over, the PIXMA TS7450i is as inventive as you are. It's ideal for artistic endeavours with children, or even for the big kid in you.
  • Effortless connectivity
    With options like AirPrint, Mopria Print Service, and Wireless PictBridge, the Canon PIXMA TS7450i offers seamless connectivity for a variety of devices, ensuring you can print from almost anywhere in your home or office.
  • Versatile media handling
    The device's advanced media handling capabilities support a wide range of sizes and types, from glossy photo paper to envelopes, making it ready for both personal and professional projects.
  • High-quality printing
    Leveraging Canon FINE technology and a maximum resolution of 4800 x 1200 DPI, the PIXMA TS7450i delivers crisp, vibrant prints, whether it's documents or photos.
  • Convenient scanning and copying
    With features like a 35-sheet ADF, 2 on 1 copying, and a high-resolution CIS scan element, this all-in-one printer simplifies document management and digitization tasks.
  • Eco-friendly design
    Automatic duplexing not only saves time but also paper, making the Canon PIXMA TS7450i an environmentally friendly choice for your printing, scanning, and copying needs.
Canon PIXMA TS7450i - multifunction printer - colour
Multifunction printer
Printing Technology
Ink-jet (colour)
Inkjet Technology
Canon FINE (Full-lithography inkjet Nozzle Engineering) - 4-ink
Max Printing Speed
Up to 13 ipm (mono) / up to 6.8 ipm (colour)
Max Printing Resolution
4800 x 1200 dpi (colour)
Scanning
1200 x 2400 dpi
Display
1.44"
Original Size
A4 (210 x 297 mm), Legal (216 x 356 mm) (max)
Original Type
Sheets
Document Feeder Capacity
35 sheets
Media Size
55 x 89 mm (min) - 215.9 x 676 mm (max)
Media Type
Envelopes, plain paper, iron-on transfers, greeting cards, card stock, glossy paper, matte paper, high resolution paper, luster paper, semi-gloss paper, photo stickers, magnetic photo paper, photo paper pro platinum
Standard Media Capacity
200 sheets
Automatic Duplexing
Yes (printing)
Connection Availability
USB 2.0, Wi-Fi(n)
AirPrint Enabled
Office Machine Features
PIXMA Cloud Link
AC 120/230 V (50/60Hz)
40.3 cm x 36.4 cm x 20.6 cm
8.2 kg
Enclosure Colour
Printing Technology
Ink-jet - colour
Display Diagonal Size
1.44"
Display Features
OLED display
USB 2.0, Wi-Fi(n)
AirPrint Enabled
PIXMA Cloud Link
Enclosure Colour
Copying
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
99
Copying Features
2 on 1, fit to page, collation copy, two-sided copy, document copy
Printing
Inkjet Technology
Max Printing Speed
Ink Cartridge Configuration
1 black cartridge, 1 colour cartridge (cyan, magenta, yellow)
Ink Palette Supported (Colours)
Cyan, magenta, yellow, black
4-ink
Automatic Duplexing
Scanning
Scan Element
CIS
Optical Resolution
1200 x 2400 dpi
Grayscale Depth
8-bit
Colour Depth
8-bit
Colour Depth (Internal)
16-bit
Document & Media Handling
Max Original Size
Supported Original Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm)
Original Type
Sheets
35 sheets
Min Media Size
55 x 89 mm
Max Media Size
A4/Legal
Min Media Weight
64 g/m²
Max Media Weight
300 g/m²
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), 100 x 150 mm, 130 x 180 mm, 200 x 250 mm, 130 x 130 mm, 215.9 x 676 mm, 55 x 89 mm, 89 x 89 mm, 91 x 55 mm
Supported Envelope Sizes
International DL (110 x 220 mm), Com-10 (105 x 241 mm)
Borderless Photo Sizes
ANSI A (Letter) (216 x 279 mm), A4 (210 x 297 mm), B5 (176 x 250 mm), 100 x 150 mm, 130 x 180 mm, 200 x 250 mm, 130 x 130 mm, 89 x 89 mm, 91 x 55 mm
200 sheets
Paper cassette - 100 sheets size: 148 x 210 mm - 215.9 x 297 mm weight: 64 g/m² - 105 g/m² , Input tray - 100 sheets size: 55 x 89 mm - 215.9 x 676 mm weight: 64 g/m² - 300 g/m²
Speed Details
Printing: up to 13 ipm - B/W , Printing: up to 6.8 ipm - colour , Printing: 43 sec (10 x 15 cm (4"x6")) - photo , Copying: up to 4 ipm
1 x USB 2.0 - 4 pin USB Type B
Security Protocols & Features
WEP, WPA-PSK, WPA2-PSK
Operating System Support
MS Windows 7 SP1, Android, iOS, Windows 8.1, Windows 10, Chrome OS, iPadOS, Windows 11, macOS 10.12.6 - macOS 13
Software Included
Drivers & Utilities, MP Driver including Scanning Utility, Canon Easy-PhotoPrint Editor
14 Watt
Power Consumption Standby
1.7 Watt
Direct Printing Specifications
PictBridge
First Copy Out Time Colour
20 sec
Consumables Included
1 x ink cartridge (black) - up to 180 pages - Canon PG-560 , 1 x ink cartridge (colour) - up to 180 pages - Canon CL-561
40.3 cm
36.4 cm
20.6 cm
8.2 kg
Sound Emission
42.5 dBA (operating)
15 °C
30 °C
10 - 80% RH (non-condensing)
HYZS Canon SG-201 - 20x25cm Photo Paper In Stock £8.41
HYZS Canon PP201 A4 Paper 20 Sheets In Stock £10.81
HYZS Canon Photo Paper Plus SG-201 - Semi-gloss satin - 101.6 x 152.4 mm - 260 g/m2 - 50 sheets In Stock £10.99
HYZS Canon Photo Paper Plus SG-201 - Semi-gloss photo paper - A4 (210 x 297 mm) - 260 g/m2 - 20 sheets In Stock £12.04
HYZS Canon Luster Paper A4 20 Sheets In Stock £10.81
HYZS Canon PG560 Black Ink Cartridge 7.5ml In Stock £14.54
Brand: Canon
