This beautifully compact All-in-One lets you print, scan and copy superb photos and crisp documents at home. It has a 7.5 cm touchscreen, 5 single inks and comes ready to use with smart wireless and cloud connectivity.
Smart connectivity
Connect easily to smart devices via a range of options including Bluetooth for easy Wi-Fi print and scan using the Canon PRINT app. -
Touch and tap control
Fun printing is just a fingertip away with a 7.5 cm color touchscreen and shortcut buttons. A simplified interface mirrors the Canon PRINT app for a seamless experience. -
Compact quality
Beautifully small All-in-One with Canon's enhanced print head technology and 5 single inks for high quality borderless printing and scanning in any home environment. -
Versatile and cost effective
Only change the color you need with individual inks and handle both photo and paper media with dual feeders. Save with XL or XXL tank options and auto 2-sided printing.
- Canon PIXMA TS6150 - multifunction printer - colour
- Multifunction printer
- Printing Technology
- Ink-jet (colour)
- Inkjet Technology
- Canon FINE (Full-lithography inkjet Nozzle Engineering) - 5-ink
- Max Copying Speed
- 6.5 ppm (colour)
- Max Printing Speed
- Up to 15 ipm (mono) / up to 10 ipm (colour)
- Max Printing Resolution
- 4800 x 1200 dpi (colour)
- Scanning
- 1200 x 2400 dpi
- Display
- 3"
- Original Size
- 216 x 297 mm (max)
- Original Type
- Sheets
- Media Size
- Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
- Media Type
- Envelopes, plain paper, photo paper, glossy paper, matte paper, high resolution paper, luster paper, semi-gloss paper
- Standard Media Capacity
- 120 sheets
- Automatic Duplexing
- Yes (printing)
- Connection Availability
- Interface
- USB 2.0, Wi-Fi(n), Bluetooth LE
- AirPrint Enabled
- Office Machine Features
- PIXMA Cloud Link, access point mode
- Power
- AC 120/230 V (50/60Hz)
- 37.2 cm x 31.5 cm x 13.9 cm
- 6.2 kg
- Enclosure Colour
- Black
- Ink-jet - colour
- Display Diagonal Size
- 3"
- Display Colour Support
- Display Features
- Touch screen
- Interface
- AirPrint Enabled
- Enclosure Colour
- Black
Copying
- Max Copying Speed
- 6.5 ppm (colour)
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 99
- Copying Features
- 2 on 1, 4 on 1, fit to page, ID Card Copy, Frame Erase Copy, Borderless copy
Printing
- Inkjet Technology
- Ink Cartridge Configuration
- 5 individual ink tanks
- Ink Palette Supported (Colours)
- Cyan, magenta, yellow, black, pigment black
- 5-ink
- Ink Type
- Canon ChromaLife100
- Colour Management Features
- Mopria
Scanning
- Scan Element
- CIS
- Optical Resolution
- 1200 x 2400 dpi
- Grayscale Depth
- 8-bit
- Colour Depth
- 8-bit
- Colour Depth (Internal)
- 16-bit
Document & Media Handling
- Max Original Size
- 216 x 297 mm
- Original Type
- Sheets
- Max Media Size
- A4/Legal
- Min Media Weight
- 64 g/m²
- Max Media Weight
- 300 g/m²
- Supported Media Type
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), 100 x 150 mm, 130 x 180 mm, 200 x 250 mm, 130 x 130 mm
- Supported Envelope Sizes
- International DL (110 x 220 mm), Com-10 (105 x 241 mm)
- Borderless Photo Sizes
- ANSI A (Letter) (216 x 279 mm), A4 (210 x 297 mm), 100 x 150 mm, 130 x 180 mm, 200 x 250 mm, 130 x 130 mm
- 120 sheets
- Input tray - 20 sheets size: 100 x 150 mm - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 64 g/m² - 300 g/m² , Paper cassette - 100 sheets - Letter A (216 x 279 mm)/A4 (210 x 297 mm) weight: 64 g/m² - 105 g/m²
- Speed Details
- Printing: up to 15 ipm - B/W , Printing: up to 10 ipm - colour , Printing: 37 sec (10 x 15 cm (4"x6")) - photo , Copying: up to 6.5 ipm - colour , Scanning: 14 sec (A4) - colour
- 1 x USB 2.0 - 4 pin USB Type B
- WEP, WPA-PSK, WPA2-PSK
- Operating System Support
- MS Windows 7 SP1, Android, iOS, Windows 8.1, Windows 10, Windows 10 Mobile, macOS 10.12, Apple Mac OS X 10.10.5 - 10.11
- Software Included
- Drivers & Utilities, Canon Easy-WebPrint EX, Canon Full HD Movie Print, Canon My Image Garden, Quick Menu, MP Driver including Scanning Utility
- Voltage Required
- 14 Watt
- Power Consumption Standby
- 1.6 Watt
- Direct Printing Specifications
- PictBridge
- First Copy Out Time Colour
- 19 sec
- Consumables Included
- 1 x ink tank (pigmented black) , 1 x ink tank (black) , 1 x ink tank (cyan) , 1 x ink tank (magenta) , 1 x ink tank (yellow)
- 37.2 cm
- 31.5 cm
- 13.9 cm
- 6.2 kg
- Sound Emission
- 46 dBA (operating)
- 15 °C
- 30 °C
- 10 - 80% (non-condensing)
